| RocketJoey |
 RocketJoey Derestricted Danger
 Posted: 09:57 - 12 Jan 2015 Post subject: Broke my ZZR400, what now? |
Hey everyone, so a pretty crappy thing happened. I bought a 98 ZZR400 a couple of days ago, it has several problems with it but it was cheap, and for my first bike I knew I wanted something I wouldn't mind banging up, but I did not expect what would happen. Today I was making sure all the lights worked and the headlight worked only to find out the battery was dead, I then went to set the bike down, but forgot the kick stand was down, so as a result my left footrest and gearshifter literally bent off of the bike, it's still attached with the lever to the transmission, but I can spin the shifter like a clock. Anyone know how much this would be to fix? |
| fatjames |
 fatjames World Chat Champion
| wr6133 |
 wr6133 World Chat Champion
| RocketJoey |
 Posted: 11:22 - 12 Jan 2015 Post subject: |
Here Ya go, the piece attaching to the bike is really lose but didn't fall off.
https://postimg.org/image/klo7n63i9/
I have no idea why the picture flipped |
| wr6133 |
| RocketJoey |
| wr6133 |
| RocketJoey |
| pdg |
 pdg World Chat Champion
| pdg |
| RocketJoey |
| pdg |
| RocketJoey |
| pdg |
| RocketJoey |
| Vincent |
 Vincent Banned
| RocketJoey |
 Posted: 13:48 - 12 Jan 2015 Post subject: |
Yeah from that point I can rotate the entire assembly
Is that part the only thing I need https://m.ebay.ie/itm/371140679753?nav=SEARCH
| Vincent |
 Vincent Banned
 Posted: 14:08 - 12 Jan 2015 Post subject: |
It could be expensive I'm afraid That part sits on the end of the gear selecter shaft and is kept in place by splines. If they have worn off the actual shaft, it's not that easy to sort....there are repairs, but they don't always work too well. However, if the selecter has either snapped or the splines on that have gone, you'll just need a new gear lever....or just the part that fastens on the shaft. You need to get it off and have a closer look. If the lever has snapped, it'll be cheap to put right. ____________________ Space Is Deep |
| pdg |
| Raffles |
 Raffles World Chat Champion
 Posted: 14:20 - 12 Jan 2015 Post subject: |
| Vincent wrote: | It could be expensive I'm afraid  That part sits on the end of the gear selecter shaft and is kept in place by splines. If they have worn off the actual shaft, it's not that easy to sort....there are repairs, but they don't always work too well. However, if the selecter has either snapped or the splines on that have gone, you'll just need a new gear lever....or just the part that fastens on the shaft. You need to get it off and have a closer look. If the lever has snapped, it'll be cheap to put right. |
I think that the OP's description may be causing some confusion. I reckon that he is referring to the ball and socket joint that is above the splined parts that you're referring to.
Edit: beaten to it by pdg. ____________________ A good loser will always be a loser.
| wr6133 |
 Posted: 14:21 - 12 Jan 2015 Post subject: |
| pdg |
| wr6133 |
 Posted: 16:02 - 12 Jan 2015 Post subject: |
| RocketJoey |
 Posted: 17:38 - 12 Jan 2015 Post subject: |
Yup guys it's fine, sorry for the confusion.
Is this part the only thing I need?
| wr6133 |
The last post was made 11 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
