Heated grips getting power but not heating
TonyD
PostPosted: 12:09 - 13 Jan 2015    Post subject: Heated grips getting power but not heating Reply with quote
When I bought my K6 Bandit last year the original owner had installed Oxford Heated Grips and they worked like a dream until recently. However now they're just not getting hot at all on either side.
The unit is getting power - the LEDs light up and I've tested each connection for voltage from the battery - but the grips simply don't get warm. Any ideas what might be up with it?
https://i1236.photobucket.com/albums/ff448/MrTonymeister/IMG_3296_zps887b8983.jpg
Suzuki Marauder 125 (sold) --> Suzuki Bandit GSF650SA (for sale!) --> Triumph Daytona 600
Confusion
PostPosted: 12:37 - 13 Jan 2015    Post subject: Re: Heated grips getting power but not heating Reply with quote
The control unit of the Oxford grips is prone to failure.
Check all wiring. Check the resistance of the two grips. I don't know
the exact resistance value for this model, but most heated grips take
about two amps for each side, so the resistance should be approximately
6 ohms. Also check the battery voltage while the engine is running.
Some Oxford heated grips will shut off automatically if the supply voltage
is below ~13V.
If the supply voltage, wiring and grips are all ok, the problem
must be in the controller.
Bandit 650SA, ZZ-R1100
TonyD
PostPosted: 23:41 - 14 Jan 2015    Post subject: Reply with quote
Thanks for the reply. The battery is brand new a couple of days ago and fully charged so I know that's absolutely good. I'll measure the resistance on the grips but I know the voltage is getting to each of the connectors from the battery so it's not a power supply issue. The unit is designed to flash if the voltage across the battery is low so I know that's not the problem.
Anything else it could be or is it looking highly likely that the control unit has simply failed?
c_dug
PostPosted: 07:00 - 15 Jan 2015    Post subject: Reply with quote
Short of broken wires there isn't much that will make the grips themselves give up, there isn't much there to go wrong. If both have given up at the same time I would also guess at the control unit being at fault.
Matt B
PostPosted: 10:35 - 15 Jan 2015    Post subject: Reply with quote
Another vote for the controller.
Oxford control units are under £30 on ebay.
Taught2BCauti...
PostPosted: 10:45 - 15 Jan 2015    Post subject: Reply with quote
If you are sure that you have voltage at the grips, disconnect them from the controller and check the resistance with an ohm-meter on a low range.
You should see something between 5 and 10 ohms, otherwise the heating element has either burned out, or become disconnected from the wiring.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
TonyD
PostPosted: 22:29 - 17 Jan 2015    Post subject: Reply with quote
Thanks all. Since they were relatively old the unit is long discontinued so I've plumped that the newer version of the HotGrips will be the same. The connectors are exactly the same so hopefully the control unit will replace the one I have and all will be hunky-dory. Thanks for your responses.
The last post was made 11 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 52.75 Kb
