| sinedtomuch |
 sinedtomuch Banned
| sinedtomuch |
 sinedtomuch Banned
| monkeybiker |
 monkeybiker World Chat Champion
| Aff |
 Aff World Chat Champion
 Posted: 13:55 - 13 Jan 2015 Post subject: |
So this has only happened after fitting the grips?
If yes, then unplug them and see if it happens over the next few days.
If it doesn't just wire them in properly with a relay.
If it does, you probably have a dead battery. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| sinedtomuch |
 sinedtomuch Banned
| mentalboy |
 mentalboy World Chat Champion
| sinedtomuch |
 sinedtomuch Banned
| Nemo |
 Nemo Could Be A Chat Bot
 Posted: 14:20 - 13 Jan 2015 Post subject: |
With the multimeter (and ignition off) plug the red lead into the 10A fused hole on the meter, then set the dial to amps, I usually have it on 10.
Disconnect the negative lead of the battery and put the multimeter between the battery terminal and the negative lead.
There should be a draw of less than an amp, if there is more, you have something draining the battery. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| iooi |
 iooi Super Spammer
| sinedtomuch |
 sinedtomuch Banned
| pdg |
 pdg World Chat Champion
| pdg |
| sinedtomuch |
 sinedtomuch Banned
| sinedtomuch |
 sinedtomuch Banned
| monkeybiker |
| sinedtomuch |
 sinedtomuch Banned
| sinedtomuch |
 sinedtomuch Banned
 Posted: 14:08 - 16 Jan 2015 Post subject: |
bump  |
| monkeybiker |
| sinedtomuch |
 sinedtomuch Banned
| pdg |
| sinedtomuch |
 sinedtomuch Banned
| monkeybiker |
| sinedtomuch |
 sinedtomuch Banned
 Posted: 15:28 - 16 Jan 2015 Post subject: |
Yeah i'll examine this one first, don't like replacing parts that are fine you'd never stop spending money if anything went wrong.
I know they are dirt cheap but hey its 3 pints down the pub!  |
| mentalboy |
 Posted: 17:28 - 16 Jan 2015 Post subject: |
| monkeybiker wrote: | | sinedtomuch wrote: | 17,000, i'll change everything but the basket probably, this assuming if lubing and adjusting the cable doesn't fix.
its worth noting the lever isn't returning to the previous position and is getting stuck, this for sure means it needs lubed.
Will do this today after work |
I would get a new clutch cable if it's that bad. Cable may be broken and frayed so could end up snapping.
If it's sticking like that then that could be holding the clutch open. |
OP: Don't fall into the 'I don't know what it is so I'll replace everything in the region and hope it works' trap.
Firstly inspect your cable and lever end, remove the cable if you're not sure on it's condition - you'll soon work out if the cable actually needs replacing (although, again, if not sure apply WD-40 or similar work cable in it's sheath - rusty crud is never a good sign) if moving and clean then check your manual and see if it's a lube or non-lube type cable, if it says lube up then get a load of 3-in-1 oil in there.
If the cable and lever are all ok, then remove clutch cover (if you are lucky the gasket will stay in one piece, budget for a new gasket before you start). Then visually inspect clutch and see if anything is obviously knackered. Then you are into strip down territory, keep going until something is obvious or out of it's tolerance range.
Only then make a shopping list and visit your local friendly factor/go web surfing and purchase parts - don't purchase anything until you know what the problem is. ____________________ Make mine a Corona. |
| sinedtomuch |
 sinedtomuch Banned
The last post was made 11 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
