Speedfight 2 brake hose replacement interval?
piggoy
PostPosted: 12:50 - 14 Jan 2015    Post subject: Speedfight 2 brake hose replacement interval? Reply with quote
Hi guys,
I've recently acquired an old X reg Speedfight 2 100cc that I'm planning to give a complete overhaul. I've also got a Haynes manual. The Haynes manual says that hydraulic brake lines need to be replaced every 3 years! As far as I'm aware they've never been replaced and the bike is 15 years old! They look in good condition and they are a steel braided type. Does the Haynes manual have it wrong assuming the hoses are standard rubber?
Thanks,
Sam
Iain.
PostPosted: 13:29 - 14 Jan 2015    Post subject: Reply with quote
Sounds weird.
I'd inspect for any cracks, bulges or leaks & if I diddn't find any forget about it.
piggoy
PostPosted: 13:43 - 14 Jan 2015    Post subject: Reply with quote
OK - I may have confused the hose braiding for steel, I don't think it is - in which case they are just standard hydraulic hoses. However a quick search online of other forums reveals no information about brake hoses replacement intervals on Peugeot scooters or any other manufacturer. I can only assume the Haynes manual instructions are OTT?
weasley
PostPosted: 14:30 - 14 Jan 2015    Post subject: Reply with quote
No doubt they follow OEM recommendations or industry norms. My bike is still on the OEM brake lines and it is 18 years old. I can feel what I believe to be a bit of bulge through the lever, but it still stops smartly and the lines are in good nick. I really WILL get around to fitting braided ones one day...
Andy_Pagin
PostPosted: 17:55 - 14 Jan 2015    Post subject: Reply with quote
It's more or less an industry standard thing to say change them every three years. I only ever change them (cars or bikes) if they're looking worn/damaged or I'm having some other braking problem.
Copycat73
PostPosted: 18:51 - 14 Jan 2015    Post subject: Reply with quote
for an old X reg Speedfight 2 100cc as follows..
if you can pull the lever to the bar & it don`t lock the front wheel .. then bleed or replace...Thumbs Up
I use a different criteria for other bigger bikes...
caveat emptor
The last post was made 11 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 47.82 Kb
