Speedfight 2 100cc standard variator roller weight?
piggoy
PostPosted: 21:30 - 14 Jan 2015    Post subject: Speedfight 2 100cc standard variator roller weight? Reply with quote
Does anyone know the standard variator roller weight for a Speedfight 2 100cc?
Looking to buy some aftermarket rollers but the weights available vary considerably from 8g to 14g.
Also, dry or greased variator? Manufacturer recommends greasing but forum users say otherwise.
Thanks,
Sam
mospeed
PostPosted: 22:13 - 14 Jan 2015    Post subject: rollers Reply with quote
Hi Speedfight 100 comes with 2 variations of rollers.
If they are 18 x 14 weight std is 12.8g
If they are 19 x 13.5 weight std is 8.8g
Personally I would use heat resistant grease on the shaft only.
Fit the actual rollers dry to avoid dust etc causing them to stick.
Hope this helps.
Pete
piggoy
PostPosted: 22:39 - 14 Jan 2015    Post subject: Re: rollers Reply with quote
Hope this helps.
Pete
I found useful information at the following link:
https://www.scooterhouse.net/downloads/rolki-razmer-pdf.pdf
Speedfight 1 100cc - 19 x 13.5 weight std is 8.8g
Speedfight 2 100cc - 18 x 14 weight std is 12.8g
piggoy
PostPosted: 17:45 - 15 Jan 2015    Post subject: Reply with quote
It seems my reference in the previous post is wrong. The distinction between the two weights/sizes of rollers is whether the bike is fitted with a catalyst, pre-cat or cat. Pre-cat has lighter rollers, and cat has heavier rollers. Speedfight2 100cc comes in both variants! Anyone know how to tell the difference?
mospeed
PostPosted: 23:21 - 15 Jan 2015    Post subject: Reply with quote
You could try weighing or measuring them..
piggoy
PostPosted: 12:00 - 16 Jan 2015    Post subject: Reply with quote
I've resigned myself to having that as the only option Sad . I was hoping to have the parts ready before I dismantled the transmission. But there doesn't seem to be any reliable well of telling whether the scoot is catalysed or not. No one seems to know if you can tell from the shape of the exhaust etc. All we know is that the transition occurred around the year 2000 but was confusingly applied to both the Speedfight1 100cc and Speedfight2 100cc. It's a complete minefield!
barrkel
PostPosted: 12:35 - 16 Jan 2015    Post subject: Reply with quote
Switching the rollers in a scooter is not a big or time consuming job. Pop all the bolts off the transmission cover, gently remove cover, apply a holder tool to the variator, undo the nut and slide off. That's it. You've probably spent more time on research than it takes to pop it open.
The last post was made 11 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 52.9 Kb
