Is this an unhealthy exhaust? Suzuki GSX 600F
Is this exhaust ok?
Yes
12%
 12%  [ 1 ]
No
87%
 87%  [ 7 ]
Total Votes : 8
davidmason100
PostPosted: 20:03 - 17 Jan 2015    Post subject: Is this an unhealthy exhaust? Suzuki GSX 600F Reply with quote
Hi BCF People!
First time user abusing the forum for all your juicy technical knowledge I'm afraid.
I'm looking at buying a mates GSX 600F as a first bike, I'm just not sure about the exhaust. To me it sounds odd and I don't think there should be gases coming out of the area it is in the video:
https://www.youtube.com/watch?v=GiNG1Hz-Fxo&t=0m50s
I would really appreciate some feedback on what people think - is it ok? or do I need a mechanic to look at it?
A mate suggested it would cost £200 to fix as it's only the linkage between two parts of the exhaust (or something, I'm an idiot mechanically Embarassed) - somebody else suggested the gases could be coming from a drainage hole but I suspect that is in a different place on the exhaust.
Any thoughts would be much appreciated, as I would like to know if I need to negotiate with the seller.
Many Many Thanks Learned Peeps Thumbs Up
Snowdonia Rider
PostPosted: 20:24 - 17 Jan 2015    Post subject: Reply with quote
Has it rotted away? Or is the clamp loose and could do with tightening? Either way it needs a few quid knocking off the asking price Thumbs Up
RhynoCZ
PostPosted: 20:37 - 17 Jan 2015    Post subject: Reply with quote
Refit it properly. Thumbs Up
davidmason100
PostPosted: 20:47 - 17 Jan 2015    Post subject: Thanks people Reply with quote
RhynoCZ - thanks for the tip but I think it's a rust issue, the exhaust hasn't been changed and most of it is in tip top condition, it's just the section in the middle which gases seem to be coming from (I may be wrong!).
under_rated It might be a clamp - if it isn't how much would you be looking to knock off the price (it would be a garage doing the work Embarassed )
PostPosted: 20:53 - 17 Jan 2015    Post subject: Reply with quote
It's blowing at the link pipe joint. This means that either the collector is rotted away or the sleeve gasket is damaged/missing.
It's blowing badly, and being a teapot it's probably rotted. If he's a mate he should let you remove the silencer to look. As soon as you do that the cause will be obvious. Look at THIS one and zoom in on the end bit with the slots in it and you'll see where it's nearly rotted out.
£200 to fix is bullshit. I'd fix that in 2 hours so long as the header bolts didn't shear and that's making the new part too.
PostPosted: 20:55 - 17 Jan 2015    Post subject: Re: Thanks people Reply with quote
My '04 Bandit was 7 years old when I got it, the exhaust looked perfect but it had nearly rotted in half under the clamp.
temeluchus
PostPosted: 22:51 - 17 Jan 2015    Post subject: Reply with quote
Full stainless system brand new in fleabay for 300 quid.
pdg
PostPosted: 23:14 - 17 Jan 2015    Post subject: Reply with quote
£200 might not be a long way off and it might even be under seeing as OP will be getting a garage to do it...
2 or so hours labour at what, ~£40/hr, plus new parts (because garages don't usually make new pipes, they just fit new ones).
Better pray those header bolts don't shear in the head or you could be looking at another £3-400 to get that sorted.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Jewlio Iglesias This post is not being displayed because the poster is banned. Unhide this post / all posts.
RhynoCZ
PostPosted: 10:12 - 18 Jan 2015    Post subject: Reply with quote
Well, I'd try to refit it anyway, worth the try.
If you are gonna get a new one, then to get the headers off, use WD40 first. Spray the nuts, let it sit, then spray them again, let it sit and then take the nuts off. If you try to take off dry nuts that were not taken off in years, you are asking for trouble. Use a smaller ratchet and give it the initial impact to break the tension. Thumbs Up
hmmmnz
PostPosted: 11:25 - 18 Jan 2015    Post subject: Reply with quote
i had the same issue on my bandit 12,
stupid design really. i chopped the bipe back and welded a smaller pipe in its place so the link pipe would slide over it, rather than slide into the pipe
like this
https://www.banditmaniashop.co.uk/ekmps/shops/banditmania/images/collector-box-repair-with-fixing-kit-for-bandit-600-1200-mk1-and-mk2.-1646-p.jpg
header on the left, link pipe on the right,
the humans are dead
I kick arse for the lord
defblade
PostPosted: 12:14 - 18 Jan 2015    Post subject: Reply with quote
Looks the same as the Bandit - the whole system is stainless, except for the couple of inches where the 2 halves join, which is mild steel and rots out.
Chap in Longlife exhausts (in Swansea for me) welded in a stainless section for £80, didn't even need to take to downpipes off - just ride in, ride out Smile
RhynoCZ
PostPosted: 18:03 - 18 Jan 2015    Post subject: Reply with quote
People tend to have a can of wd40 laying around, so I suggested something that's available ''now''.
The last post was made 11 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.12 - MySQL Queries: 15 - Page Size: 92.46 Kb
