| keithm |
 keithm L Plate Warrior
| nighthawk250 |
 nighthawk250 Renault 5 Driver
| keithm |
| moonzoomer |
 moonzoomer World Chat Champion
| Teflon-Mike |
 Posted: 18:37 - 18 Jan 2015 Post subject: |
CD125 Benley Has Twin-Shock rear suspension; the CB125 has Mono-Shock rear suspension; CD has 17" wheels; CB 18" wheels; CD has drum brakes; CB has disc front, ad the list goes on....
Easier for me to list the bits that they share.... that will be; crank-cases; cylinder barel; cylinder head bare casting and valves, the cam-chain and cam-chain tensioner....
The crank in the Benly has 360 'Timing'; both pistons' up and down together; CB has 180 crank; one piston up, one down; which means that the cam-timing also has to be different; so dfferet cams; also different ignitions to give different spark timing; so a lot of electrical differences; The CB125 has a rev counter, so the oil-pump is different having an open casing to allow the rev counter drive to be taken off the end; CB motor can rev to 14K, and drives 18" wheel, so the gear ratios are all different in the gearbox, as Benly revs to nadge over 10K and turns a 17" wheel.. Rocker covers are different, carbs are different, air-boxes are different, exhausts are different, err... NOT much is the same.... tappet adjuster screws have the same part umber if that helps?
SO... they have very different chassis, with little interchangeability, except perhaps the odd light bulb or perhaps handle-bar grips; the engines are of the same basic design, based on the same crank casings, but internally, totally different designs; with again, little 'direct' interchangeability. To all extents and purposes they are completely different motorcycles.
B-U-T..its all pretty much in the Haynes Manual for the model.. And why are you interested? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| CaNsA |
 CaNsA Super Spammer
| keithm |
| pdg |
 pdg World Chat Champion
| Fisty |
 Fisty Super Spammer
 Posted: 18:47 - 18 Jan 2015 Post subject: |
Holy fuck and I thought his last post was potato. ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
| moonzoomer |
 Posted: 20:21 - 18 Jan 2015 Post subject: |
The 1984 CB125 uses a mono shock. |
| pdg |
 Posted: 21:07 - 18 Jan 2015 Post subject: |
| moonzoomer wrote: | The 1984 CB125 uses a mono shock. |
Yes, because I drew that picture of a 1984 CB125 with crayons. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
| Jewlio Iglesias |
 Jewlio Iglesias Banned
| pdg |
The last post was made 11 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
