CB125 Superdream - Pilot Screw
richjp
PostPosted: 16:23 - 18 Jan 2015    Post subject: CB125 Superdream - Pilot Screw Reply with quote
Hi all
As reported in a separate thread a week or so ago, I have been trying to get my rebuilt engine started again after a couple of years sitting. The electrics are all fine, turns over nicely, with puffs of exhaust coming out, but doesn't catch.
Sparks look good (white, not blue - is that an issue?), fuel flowing OK from tank, so I decided to strip carburettors again to see if anything was blocked. All looks OK. However, I have a question on the pilot screws - the manual says screw in fully and then screw out by 1.25 turns. When it says '1 turn', is that the screw head going through 360 degrees, or 180? If I take the latter, I get the head of the pilot jet appearing as shown in the attached picture. If I a assume 360 degrees = 1 turn, then the head of the pilot jet is barely visible above the inner face of the carb.
cheers
Richard
Paddy Blake
PostPosted: 16:32 - 18 Jan 2015    Post subject: Reply with quote
360.
You need to replace that O ring seal.
richjp
PostPosted: 17:22 - 18 Jan 2015    Post subject: Reply with quote
Thanks - yes, already done
cheers
Richard
Teflon-Mike
tl;dr
PostPosted: 19:04 - 18 Jan 2015    Post subject: Reply with quote
360 Deg... Five 1/4 turns.
Fisty
PostPosted: 19:17 - 18 Jan 2015    Post subject: Reply with quote
You fucking what?
Seriously mike your advice is quite often wrong and sometimes downright dangerous but seriously this is the single most potato thing you have ever posted.
No wonder Sammy is spanner dyslexic.
Fatter and faster than Fret
CaNsA
PostPosted: 19:36 - 18 Jan 2015    Post subject: Reply with quote
Sig'd
Fisty
PostPosted: 19:38 - 18 Jan 2015    Post subject: Reply with quote
CaNsA wrote:
Sig'd
Sig'd? It wants etching on his gravestone after he ends up blowing himself up one day after following his own advice.
Teflon-Mike
tl;dr
PostPosted: 19:54 - 18 Jan 2015    Post subject: Reply with quote
You didn't read the question did you, Fisty?, that's two answers to two questions; but hey; if it another opportunity to waste band width contributing nothing of relevance, but makes you feel superior, being able to point out apparent error, rather than offering actual answer to OP... carry on... the irony in the 'waste of bandwidth' comments to my rambling posts is quite delicious.
CaNsA
PostPosted: 19:58 - 18 Jan 2015    Post subject: Reply with quote
I only see 1 question from the OP.
Why are you inventing new questions?
Fisty
PostPosted: 20:01 - 18 Jan 2015    Post subject: Reply with quote
I happily give advice when I know the answer and know it will be helpful. You just seem to spout whatever is on your mind at the time and call it advice.
It does not make me feel superior at all, it just amazes me that you continue to spout incorrect and sometimes dangerous advice that people who do not know any wiser will follow one day and end up getting hurt or damaging their bikes.
I'm still clearing up the mess of advice you gave smiler on how to run a motorbike.
Remind me again Mike, how many shocks does a CB125 have?
Jewlio Iglesias This post is not being displayed because the poster is banned. Unhide this post / all posts.
ferrisio
PostPosted: 22:33 - 18 Jan 2015    Post subject: Reply with quote
All made sense to me, one turn is 360 deg, he needs to screw the screw out 5 quarter turns. Could have been made clearer in Mr Mike's post but it was right though?
BMW R1100R
Paddy Blake
PostPosted: 20:27 - 19 Jan 2015    Post subject: Reply with quote
You need to turn it 450 deg or 2.5 1/2 turns. Smile
richjp
PostPosted: 08:09 - 20 Jan 2015    Post subject: Reply with quote
cheers all - got it!
PostPosted: 09:31 - 20 Jan 2015    Post subject: Reply with quote
Metric or imperial?
trevor saxe-coburg-gotha
PostPosted: 11:09 - 20 Jan 2015    Post subject: Reply with quote
A/F
Scootaloo
PostPosted: 11:41 - 20 Jan 2015    Post subject: Reply with quote
So to clarify, How Mike should have communicated his point for the greatest accuracy and least confusion:
"360 Degrees, so that will be five 1/4 turns from the current position."
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
Matt B
PostPosted: 12:08 - 20 Jan 2015    Post subject: Reply with quote
Tef should not have mentioned the 360 bit at all, just said:
"Screw out by 1.25 turns means five 1/4 turns"
PostPosted: 12:21 - 20 Jan 2015    Post subject: Reply with quote
Or for simplicity, 7.854 radians (at sea level).
ferrisio
PostPosted: 13:53 - 20 Jan 2015    Post subject: Reply with quote
Nope, the only question in the OP was
BMW R1100R
Paddy Blake
PostPosted: 02:03 - 21 Jan 2015    Post subject: Reply with quote
The thing is if you were a way above sea level it would be 1.1/2 because of the low density of the air.
Even if it is cold up there your engine may over heat because of
low fuel to air ratio.
Just saying.
PostPosted: 08:51 - 21 Jan 2015    Post subject: Reply with quote
Paddy Blake wrote:
The thing is if you were a way above sea level...
Do please Tef me more about how carbs work.
CaNsA
PostPosted: 00:28 - 23 Jan 2015    Post subject: Reply with quote
https://giant.gfycat.com/ZestyConcernedAfricanrockpython.gif
PostPosted: 00:39 - 23 Jan 2015    Post subject: Reply with quote
Laughing Laughing Laughing Laughing Laughing Laughing
bikenut
PostPosted: 12:33 - 23 Jan 2015    Post subject: radians Reply with quote
may be he has eaten 2 and a half pies......boom boom :D
nuts about bikes
The last post was made 11 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 132.07 Kb
