Do I need to oil new clutch cover gasket?
Mikedz
PostPosted: 21:57 - 18 Jan 2015    Post subject: Do I need to oil new clutch cover gasket? Reply with quote
I took off the clutch cover on my 2008 ybr125 to clean the oil filter. In my ignorance I put the existing gasket back on and it leaks when I turn the engine on. I have ordered a new gasket. Do I need to oil it or put some sort of sealant on before installation? Also do I need to clean the surfaces where the cover meets the clutch case? Best way to do this?
Cheers,
Mike
mentalboy
PostPosted: 23:42 - 18 Jan 2015    Post subject: Re: Do I need to oil new clutch cover gasket? Reply with quote
Cheers,
Mike
Cleaning the oil filter??? Inside the clutch cover??? New ones on me!!
I always oil new gaskets, some people do, some don't - I'm old school. And yes you need to clean the mating surfaces, a Stanley knife blade is good for a novice just be careful not to nick the surface. I use a 1/4" wood chisel that is very sharp but I wouldn't recommend it to anyone who doesn't use chisels in a professional capacity.
Make mine a Corona.
DJP
PostPosted: 09:08 - 19 Jan 2015    Post subject: Reply with quote
Modern gaskets are meant to be used dry (although I doubt it matters if you oil it or not).
The most important thing is to clean the gasket face thoroughly.
I'd be very wary of using a chisel to do this unless you're very good: A sharp steel chisel will easily gouge the gasket face.
You'd be better off getting a piece of copper pipe, hammering one end flat and then filing that to a chisel point: The softer copper is much less likely to mark the gasket face.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
Suntan Sid
PostPosted: 11:13 - 19 Jan 2015    Post subject: Re: Do I need to oil new clutch cover gasket? Reply with quote
Many small 4T engines have an internal oil pump/filter mechanism.
Just make sure the mating surfaces are cleaned thouroughly and not damaged! Personally, I wouldn't oil new gaskets. What does the manual for your bike say?
Mikedz
PostPosted: 20:38 - 20 Jan 2015    Post subject: Reply with quote
Gasket arrived. Will put it on this weekend. The manual doesn't describe how to remove/install the clutch cover and the Haynes manual simply says to install new gasket but doesn't describe how.
Let's see how it goes! :s
Commuter_Tim
PostPosted: 20:53 - 20 Jan 2015    Post subject: Reply with quote
These fellas just told you how! Laughing
I ride a Bandit 600... badly.
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 57.53 Kb
