Seating the Bead on a Seated Tyre
b422063
PostPosted: 15:52 - 18 Jan 2015    Post subject: Seating the Bead on a Seated Tyre Reply with quote
Whilst fitting my tyre, I noticed that the bead didn't quite seat properly in one tiny area. Foamy water produces bubbles from that area.
Am I best breaking the bead and inflating the tyre or is there something else I should do?
Thanks
SQL
PostPosted: 16:32 - 18 Jan 2015    Post subject: Reply with quote
While inflating it bounce the tyre, and after go for a spin round the block to seat it.
Source
Bandit was leaking on the bead slightly, ride round the block, problem fixed.
Fizzer Thou
PostPosted: 17:48 - 18 Jan 2015    Post subject: Reply with quote
Best to break the bead all of the way round and to use some diluted washing up liquid (if no tyre soap available) and swab therim and the bead of the tyre -then reinflate it to 50 psi Thumbs Up
Always have a 'Plan B'
b422063
PostPosted: 04:20 - 19 Jan 2015    Post subject: Reply with quote
I'll give them both a go. Smile
Thanks Thumbs Up
DrDonnyBrago
PostPosted: 11:52 - 19 Jan 2015    Post subject: Reply with quote
I bounce mine as I inflate them, always seems to set them properly. There is usually a line around the edge of the bead that should be an equal distance from the rim all the way round. More pressure and/or some bouncing should do it.
The last post was made 11 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 43.16 Kb
