| Random13 |
 Random13 Scooby Slapper
| Iain. |
 Iain. Could Be A Chat Bot
| Random13 |
 Posted: 18:28 - 20 Jan 2015 Post subject: |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 18:36 - 20 Jan 2015 Post subject: |
You may have problems using a magnetic based gauge on an aluminium swing arm!
I too have never used a dial gauge on a bike (although I do have access to one). If you have a floating disc with removable rivets then just remove it from the wheel, remove the rivets and lay on a piece of glass. You'll soon see if it's flat.
Why not put some pics up of the disc? Makes life a lot easier to see what type of disc we're talking about
Edit: If the front disc then it'll be even trickier using a magnetic dial gauge on forks. ____________________ Make mine a Corona. |
 Posted: 18:38 - 20 Jan 2015 Post subject: |
Please don't use the term micrometres to refer to a measurement of distance. A micrometer is a tool.
In all but the finest of engineering measurements are done in millimetres and decimals thereof. 0.25mm is 0.25mm not 250 microns.
If you need to refer to something in microns you won't be asking about them. ____________________ a.k.a 'Geri'
 Posted: 18:43 - 20 Jan 2015 Post subject: |
For £20 you can't do much better. Get rid of that stupid adjuster in the middle of the rod and put the short rod in the clamp or you'll be fiddling with it for ages.
If you're turning the wheel to check runout you probably have it on a front paddock stand. if this is the case you could probably put the gauge on the tube of the stand. Otherwise bend a bit of flat metal and jubilee clip in to your fork, fix the dial to that. ____________________ a.k.a 'Geri'
| Random13 |
| DrDonnyBrago |
| Aff |
 Aff World Chat Champion
| Fizzer Thou |
| Ariel Badger |
 Ariel Badger Super Spammer
| Iain. |
| Aff |
 Posted: 13:32 - 21 Jan 2015 Post subject: |
| Iain. wrote: | | Pete. wrote: | Please don't use the term micrometres to refer to a measurement of distance. A micrometer is a tool. |
Google lies!
https://i.imgur.com/N7kQJa5.jpg
Which is bad, because I use google to convert all forms of measurement.  |
Google is American.
The correct spelling of the SI unit of measurement is the metre and the correct spelling of the suffix used for a measuring device is a meter.
So in the whole world except 'murica:
Micrometre = 1/1000000 metres
Micrometer = A device for measuring very small thicknesses.
In 'murica they spell the distance and the measuring device the same way, "meter", because they are too idle to English properly.
So once again, the Americans, who don't even USE the fucking metric system, screw it up for everyone else. Probably deliberately.
In any case, they should rename the tool because micrometer literally translates as "Very small measuring device". I think they should follow the convention of naming tools after their inventor and call it a Gascoigne calliper. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Scootaloo |
 Scootaloo Could Be A Chat Bot
| Ariel Badger |
The last post was made 11 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
