motorcycle project
marytappenden
PostPosted: 12:17 - 23 Jan 2015    Post subject: motorcycle project Reply with quote
I am currently completing an end of course project and could do with some guidance, my idea is to create an appliance charger that runs of the motion of the wheel. my initial idea of attaching the charger was to the swingarm of the bike and then run a lead/usb up. I was wondering if anyone has any advice or better ways of completing this project safely and successfully.
Any advice will be greatly appreciated feel free to message or email me Smile
Many Thanks
Mary Tappenden
Taught2BCauti...
PostPosted: 12:32 - 23 Jan 2015    Post subject: Reply with quote
You could start by trying one of those tyre-driven bicycle dynamos, but most of them are 6V @ 3W, so you would probably need to use it to charge a Li-Po battery and use an inverter to get higher voltages.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 12:35 - 23 Jan 2015    Post subject: Reply with quote
Correct me if I'm wrong, but don't motorcycles usually come with electrical systems? Even my Enfield has one, of sorts.
It seems a very curious project, is my drift, I'm wondering about the actual purpose of it. Is it to show that you can do a solid implementation of a nonsensical requirement?
finniee
PostPosted: 12:48 - 23 Jan 2015    Post subject: Reply with quote
From my understanding OP means is using motion from the wheel to charge an external battery and using that external battery to power sat nav and things like that instead of wiring straight into the loom itself.
OP, look into hand crank generators.
Taught2BCauti...
PostPosted: 13:07 - 23 Jan 2015    Post subject: Reply with quote
Roger is correct - but then again, a lot of college projects are designed to challenge your thinking, not to end up with a practical outcome.
One of my college projects was to calculate the cost of building a car from scratch, using the parts catalogue - another was to modify a single-cylinder 4 stroke engine to run on compressed air!
I'm sure OP is aware that a tyre-driven dynamo requires more power to drive it, than it will give out in electrical energy, so the value in the challenge would come from the design and implementation, rather than the practicality.
You could introduce a solenoid to disengage it from the tyre when the Li-Po battery was fully charged, but would also need to match the gearing to allow for the difference in the range of rotational speeds, between bicycle and motorcycle tyres.
truslack
PostPosted: 13:23 - 23 Jan 2015    Post subject: Reply with quote
Double the gear ratio on the cam shaft, or make a symmetrical cam.
Not much of a project Laughing
Wonko The Sane
PostPosted: 13:28 - 23 Jan 2015    Post subject: Reply with quote
I can't even begin to think where it would fit on sports bikes due to space.
Will the power drop when I'm stopped or will there be a capacitor to keep power until the lights change and I move again?
Taught2BCauti...
PostPosted: 13:56 - 23 Jan 2015    Post subject: Reply with quote
It was was for a 17 year-old, and we could only use or adapt parts that were available in the workshop! Hardest part was finding crank and cam sprockets the same size - no practical use whatsoever, but it was a lot of fun.
map
Mr Calendar
PostPosted: 13:57 - 23 Jan 2015    Post subject: Reply with quote
Wonko The Sane wrote:
I can't even begin to think where it would fit on sports bikes due to space...
Hub dynamo/motor?
PostPosted: 14:01 - 23 Jan 2015    Post subject: Reply with quote
[insightful stuff]
True, but I ask specifically in the context of this:
marytappenden wrote:
my idea
Go back to the requirements. What is it that you are being asked to achieve, and why?
Not what you want to achieve, what has your 'customer' asked you to do?
Taught2BCauti...
PostPosted: 14:03 - 23 Jan 2015    Post subject: Reply with quote
There should be enough space to fit a bicycle dynamo on a sports bike, but most of them don't make enough power to charge a mobile phone or run a GPS directly.
You would need to add a charging circuit and a rechargeable battery for that, and no power would be generated when stopped.
You can get a solar-powered 'Power Bank' with a USB output for charging mobile phones or powering a GPS - I would have a look at one of those, using the bicycle dynamo in place of the solar panel.
dolly3900
PostPosted: 14:30 - 23 Jan 2015    Post subject: Reply with quote
OP.
Something I have looked at as a practical application for an Eco car project in school and one of the ideas I had was this.
Tight coils of wire, wound around the fork leg (using the leg {assuming a FE base leg} as a central FE core)
Magnets mounted on the wheel spoke/rim.
Action of magnetic field across the coil of wire (secondary magnet
mounted behind the coil) should induce current flow.
Simple rectifier and regulator should give usable power source.
I'll be honest, this did not make it past the theoretical stage as we went for a solar solution to power/charge the ancillaries in the end, but might be worth a punt even for process of elimination purposes.
Give me a shout if you do, I'd be interested if the theory was sound.
Mike
2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650
WD Forte
PostPosted: 14:37 - 23 Jan 2015    Post subject: Reply with quote
Wind generator?
As theres nothing new under the sun, I googled it and yep
someone's already done it
https://cdn.akihabaranews.com/sites/default/files/styles/akiba-custom/public/field/image/Thanko_Portable%20wind%20turbine%20generator_main.jpg?itok=KQ4TGlNR
bikers smell of wee
Northern Monkey
PostPosted: 15:33 - 23 Jan 2015    Post subject: Reply with quote
Could you keep a hamster, and a hamster wheel, in a top boxes. They run quite fast when they feel like it. Would that be enough energy to charge my iphone?
Baffler186
PostPosted: 16:02 - 23 Jan 2015    Post subject: Reply with quote
I was going to suggest this as well, basically like a stator. Having said that, wouldn't you have to adjust the wheel weights to compensate for weight of the magnet? If it's purpose is to be a consumer "plug and play" type widget, then it might be too complicated.
As Roger said, would depend on what the actual aims of the assignment were. If it's just looking at using motion to power a sat-nav then I'd go for this.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Phoenix
Twisted Firestarter
PostPosted: 16:43 - 23 Jan 2015    Post subject: Reply with quote
Can't see that generating much power and I also can't see the fork leg working as a 'core'. The project is a bit of a poor one due to it supplementing a power system that already exists on the bike but that's college projects for you, often totally useless and often the answer is already known 1000x over. If you really want to go with a dynamo of somekind, be it off the shelf or custom built then i'd have thought the best place to attach it is at the front of the rear wheel below the swingarm V (where the shock is), it could be spring loaded to run against the face of the tyre rather than the side and if it's got a rubber wheel then it won't wear the tyre either and if it breaks and falls off then you'll ride over it rather than have it jammed between the wheel and swingarm. Still totally pointless and likely to produce little power but as said it's about designing and implementing something rather than inventing a useful product. Either way you can't just run a usb cable from the power source, it needs regulating in some way or you would just over/under volt anything you connect to it.
pits
PostPosted: 13:12 - 25 Jan 2015    Post subject: Reply with quote
This is a somewhat retarded project with a lot of downfalls and fails.
Bicycle dynamo, I will be honest I can't be arsed to do the maths here it's far too much effort, but a bicycle dynamo at 12v (we have moved on in the past 3000 years since 6v) will rarely be rated to spin at 30mph, now a bike is going to average around 30mph constantly, add in jaunts of up to 70mph on motorway the likely thing that is going to happen is it will set on fire as the bearings collapse and overheat, that kinetic energy needs to go somewhere, do you want the end of that dynamo flinging around at several thousand rpm?
Then there's all the other gay things that have been mentioned which have already been done.
Magnets and coil on front suspension, not exactly a brilliant idea, how would you secure it? How would you stop it from getting tangled up in the brakes?
Dynamo on the front wheel was mentioned, thing is to be able to withstand the heat, force, rotation it would have to be a cross between an old car generator and a bike one, if you mounted that on the front of a bike you are going to drastically alter the handling characteristics of your bike, now granted if you have a Bandit it probably wont matter as they are shit and ghey, but besides the point. You will be weighting the front end of your bike, the balance would have to be right, you would have to consider different oils, springs etc in the forks.
This is completely besides the point that this is your project, not ours so do it yourself, we're not here to do it for you.
Rolling Eyes
dolly3900
PostPosted: 14:42 - 26 Jan 2015    Post subject: Reply with quote
Rolling Eyes
Here is a novel thought, rather than slagging off those of us who are willing to help,how about offering something constructive yourself, or just shake your head quietly to yourself and STFU.
lihp
PostPosted: 17:04 - 26 Jan 2015    Post subject: Reply with quote
This "project" is sounding a little like a university "project"
PostPosted: 18:57 - 26 Jan 2015    Post subject: Reply with quote
Magnet on the wheel, induction coil on fork/swing arm.
https://www.instructables.com/id/Magnetic-Induction-Bike-Lights/
andyscooter
PostPosted: 20:42 - 26 Jan 2015    Post subject: Reply with quote
Degos run faster Thumbs Up
Suntan Sid
PostPosted: 20:46 - 26 Jan 2015    Post subject: Reply with quote
WD Forte wrote:
This was my immediate thought, but I CBA'd googling!
pits
PostPosted: 20:50 - 26 Jan 2015    Post subject: Reply with quote
Rolling Eyes
Or not, because we are not here to do his homework, this is a task set to him to find a solution to, now don't be upset that I pointed out all the floors in the task because the idea in general is stupid and serves no purpose.
If you read what I had posted, it is constructive I am telling him that he should do his own work, think for himself, not get others to do shit for him and think of something that isn't stupid or has been done already.
I could stfu, but I am a massive cunt so that kinda rules that one out Thumbs Up
lihp
PostPosted: 21:04 - 26 Jan 2015    Post subject: Reply with quote
The best way of charging from a bike is possibly to use some kind of magentic generator attached to the crankshaft, that then gets passed a rectifier and regulator to keep the power to a usable voltage. Thinking
Northern Monkey
PostPosted: 21:17 - 26 Jan 2015    Post subject: Reply with quote
You might find that using an AC generator, or alternator, connected to the crank shaft, which charges a 12v lead acid battery stored under the seat via a regulator rectifier could also work. I'm not sure why no one has tried it before
The last post was made 11 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 139.79 Kb
