| marytappenden |
 marytappenden L Plate Warrior
 Posted: 12:17 - 23 Jan 2015 Post subject: motorcycle project |
I am currently completing an end of course project and could do with some guidance, my idea is to create an appliance charger that runs of the motion of the wheel. my initial idea of attaching the charger was to the swingarm of the bike and then run a lead/usb up. I was wondering if anyone has any advice or better ways of completing this project safely and successfully.
Any advice will be greatly appreciated feel free to message or email me  ____________________ Many Thanks
Mary Tappenden |
| Taught2BCauti... |
 Posted: 12:32 - 23 Jan 2015 Post subject: |
You could start by trying one of those tyre-driven bicycle dynamos, but most of them are 6V @ 3W, so you would probably need to use it to charge a Li-Po battery and use an inverter to get higher voltages. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:35 - 23 Jan 2015 Post subject: |
Correct me if I'm wrong, but don't motorcycles usually come with electrical systems? Even my Enfield has one, of sorts.
It seems a very curious project, is my drift, I'm wondering about the actual purpose of it. Is it to show that you can do a solid implementation of a nonsensical requirement? ____________________ Biking is 1/20th as dangerous as horse riding.
| finniee |
 finniee Spanner Monkey
| Taught2BCauti... |
 Posted: 13:07 - 23 Jan 2015 Post subject: |
Roger is correct - but then again, a lot of college projects are designed to challenge your thinking, not to end up with a practical outcome.
One of my college projects was to calculate the cost of building a car from scratch, using the parts catalogue - another was to modify a single-cylinder 4 stroke engine to run on compressed air!
I'm sure OP is aware that a tyre-driven dynamo requires more power to drive it, than it will give out in electrical energy, so the value in the challenge would come from the design and implementation, rather than the practicality.
You could introduce a solenoid to disengage it from the tyre when the Li-Po battery was fully charged, but would also need to match the gearing to allow for the difference in the range of rotational speeds, between bicycle and motorcycle tyres. ____________________ Honda Varadero XL125(V8)
| truslack |
 truslack World Chat Champion
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| Taught2BCauti... |
| map |
 map Mr Calendar
| Rogerborg |
 Rogerborg nimbA
| Taught2BCauti... |
| dolly3900 |
 dolly3900 Traffic Copper
 Posted: 14:30 - 23 Jan 2015 Post subject: |
OP.
Something I have looked at as a practical application for an Eco car project in school and one of the ideas I had was this.
Tight coils of wire, wound around the fork leg (using the leg {assuming a FE base leg} as a central FE core)
Magnets mounted on the wheel spoke/rim.
Action of magnetic field across the coil of wire (secondary magnet
mounted behind the coil) should induce current flow.
Simple rectifier and regulator should give usable power source.
I'll be honest, this did not make it past the theoretical stage as we went for a solar solution to power/charge the ancillaries in the end, but might be worth a punt even for process of elimination purposes.
Give me a shout if you do, I'd be interested if the theory was sound.
Mike ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 14:37 - 23 Jan 2015 Post subject: |
| Northern Monkey |
 Northern Monkey World Chat Champion
| Baffler186 |
 Baffler186 World Chat Champion
| Phoenix |
 Phoenix Twisted Firestarter
| pits |
 pits World Chat Champion
 Posted: 13:12 - 25 Jan 2015 Post subject: |
This is a somewhat retarded project with a lot of downfalls and fails.
Bicycle dynamo, I will be honest I can't be arsed to do the maths here it's far too much effort, but a bicycle dynamo at 12v (we have moved on in the past 3000 years since 6v) will rarely be rated to spin at 30mph, now a bike is going to average around 30mph constantly, add in jaunts of up to 70mph on motorway the likely thing that is going to happen is it will set on fire as the bearings collapse and overheat, that kinetic energy needs to go somewhere, do you want the end of that dynamo flinging around at several thousand rpm?
Then there's all the other gay things that have been mentioned which have already been done.
Magnets and coil on front suspension, not exactly a brilliant idea, how would you secure it? How would you stop it from getting tangled up in the brakes?
Dynamo on the front wheel was mentioned, thing is to be able to withstand the heat, force, rotation it would have to be a cross between an old car generator and a bike one, if you mounted that on the front of a bike you are going to drastically alter the handling characteristics of your bike, now granted if you have a Bandit it probably wont matter as they are shit and ghey, but besides the point. You will be weighting the front end of your bike, the balance would have to be right, you would have to consider different oils, springs etc in the forks.
This is completely besides the point that this is your project, not ours so do it yourself, we're not here to do it for you.
 ____________________ Stinkwheel: You have no right to free speech
00:33:00 Blau Zedong: the CB400 is my favourite road bike |
| dolly3900 |
 Posted: 14:42 - 26 Jan 2015 Post subject: |
| pits wrote: | This is a somewhat retarded project with a lot of downfalls and fails.
Here is a novel thought, rather than slagging off those of us who are willing to help,how about offering something constructive yourself, or just shake your head quietly to yourself and STFU. ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
| lihp |
 lihp World Chat Champion
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 18:57 - 26 Jan 2015 Post subject: |
Magnet on the wheel, induction coil on fork/swing arm.
https://www.instructables.com/id/Magnetic-Induction-Bike-Lights/ ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| andyscooter |
 andyscooter World Chat Champion
| Suntan Sid |
 Posted: 20:46 - 26 Jan 2015 Post subject: |
This was my immediate thought, but I CBA'd googling! ____________________ "Everybody needs money, that's why they call it money!"  |
| pits |
 Posted: 20:50 - 26 Jan 2015 Post subject: |
| dolly3900 wrote: | | pits wrote: | This is a somewhat retarded project with a lot of downfalls and fails.
Here is a novel thought, rather than slagging off those of us who are willing to help,how about offering something constructive yourself, or just shake your head quietly to yourself and STFU. |
Or not, because we are not here to do his homework, this is a task set to him to find a solution to, now don't be upset that I pointed out all the floors in the task because the idea in general is stupid and serves no purpose.
If you read what I had posted, it is constructive I am telling him that he should do his own work, think for himself, not get others to do shit for him and think of something that isn't stupid or has been done already.
I could stfu, but I am a massive cunt so that kinda rules that one out  ____________________ Stinkwheel: You have no right to free speech
| lihp |
 Posted: 21:04 - 26 Jan 2015 Post subject: |
The best way of charging from a bike is possibly to use some kind of magentic generator attached to the crankshaft, that then gets passed a rectifier and regulator to keep the power to a usable voltage.  ____________________ covent.gardens: lihp is my most favourite member ever |
| Northern Monkey |
The last post was made 11 years, 273 days ago. Instead of replying here, would creating a new thread be more useful? |
