Charging system not working
BikerMatt
PostPosted: 12:34 - 13 Jan 2015    Post subject: Charging system not working Reply with quote
Hi all..
Been dumped with a 2007 "Hyosung rx 125 sm" that wont charge the batt..
so far the alternator has been replaced and tested
as well as the reg/rec (replaced and tested)
and a new batt (charged fully before installed and holds charge)...
still wont charge..
I have checked the loom and nothing..
the battery is getting AC while running but not DC
I'm boned
RhynoCZ
PostPosted: 12:50 - 13 Jan 2015    Post subject: Reply with quote
First thing to check, did you set the multimeter to DC?
Second, how did you test the alternator? - Find 3 yellow wires coming out of the engine and measure one with another using AC, when the engine runs, there shall be voltage (from 40v to 60v).
Third, if you get AC on the battery, the rectifier is burned/corrupted.
Fourth, is this a magician's motorcycle?
BikerMatt
PostPosted: 13:00 - 13 Jan 2015    Post subject: Reply with quote
1. No I set the meter to detect magic pixy dust Laughing
2. Yup I measured the voltage whilst running and the ohms between the wires and then tested if it was shorting to engine/frame.. all normal.
3. Hmm perhaps I should just get one from Korea brand spanking new like the alt as it was from fleabay Rolling Eyes
4. Yes.
Wull
PostPosted: 15:55 - 13 Jan 2015    Post subject: Reply with quote
Biggest mistake was buying a Hyosung Very Happy
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
RhynoCZ
PostPosted: 16:03 - 13 Jan 2015    Post subject: Reply with quote
Alright, get a new reg/rec, don't run the bike like that, AC going into the battery will kill it. Thumbs Up
BikerMatt
PostPosted: 16:27 - 13 Jan 2015    Post subject: Reply with quote
It's not mine, just for the record
Thanks for being so useful though
BikerMatt
PostPosted: 18:13 - 13 Jan 2015    Post subject: Reply with quote
Would like to find out why this rec went dud before that, wouldn't wanna plug a new one in and have it go bang lol
RhynoCZ
PostPosted: 20:38 - 13 Jan 2015    Post subject: Reply with quote
To be honest, I've no idea.
The reg/rec may be even faulty right out of the box. The only two reasons why a reg/rec gets burned/corrupted are heat and vibrations. There are no mechanical parts in the reg/rec. Also there are no other electronic parts I could think of, that would be between the reg/rec and the alternator itself. The alternator is just a stator (coil made of copper wire) and a moving magnet.
TL; DR, if the alternator is alright, then buy a new reg/rec, or ask a mate to lend you his. I once did test with CBR919RR reg/rec in my CB-1 and vice versa, worked the same. Thumbs Up
ZebraDriver
PostPosted: 06:14 - 14 Jan 2015    Post subject: Reply with quote
This might help
https://www.crowitis.com/images/fault_finding.pdf
ZD
PostPosted: 08:51 - 14 Jan 2015    Post subject: Reply with quote
Biggest mistake was offering to help with a Hyosung.
I know them feels.
Wull
PostPosted: 16:03 - 14 Jan 2015    Post subject: Reply with quote
No worries mate,glad to be of great hep to you Very Happy
Tbf everyone on here is electrical geniuses so I thought it would be better to let them help you.
BikerMatt
PostPosted: 14:06 - 23 Jan 2015    Post subject: Reply with quote
Headaches and a half lol
Brand new rec/reg done nothing Rain Brick Wall Hurt Rain
PostPosted: 14:35 - 23 Jan 2015    Post subject: Reply with quote
Are you going to keep throwing more money down that hole? Sad
BikerMatt This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
bikenut
PostPosted: 16:20 - 23 Jan 2015    Post subject: Reply with quote
ok matt just seen.....wiring diagram have you.....have 250 twin wiring diagram for wire colours .....back 2morrow as time up nearly and stuff at home....is there a wiring diagram on here?? see suggestions for colours .............still ac at the battery??
its a 125 does the headlight have ac lighting with dc for the side lamps etc??
nuts about bikes
P.
PostPosted: 17:04 - 23 Jan 2015    Post subject: Reply with quote
BikerMatt wrote:
Are you going to help or talk more bs from yours? What a perfect example of an admin
Lol, proves you don't bother reading.
AC voltage output from stator when running, what are your readings from the output wires?
With reg rec, what is the voltage you are seeing between the + and -?
You are chundering £££ at something that is fairly simple to diagnose.
Stator needs to be giving out decent AC voltage across ALL wires, multimeter + on wire and - on bare metal/frame/engine.
Testing 1+2 1+3 and 2+3 of the wires in ohms, you should have zero or infinity, basically as close to nothing as poss.
If that checked out, wire the regulator back up and check output of that. Needs to be around 13.5>14 DC V
PostPosted: 17:45 - 23 Jan 2015    Post subject: Reply with quote
Crying or Very sad
Hindsight might turn that frown upside down.
ferrisio
PostPosted: 20:13 - 23 Jan 2015    Post subject: Re: Charging system not working Reply with quote
How much AC, 0.05V? 90V?
BMW R1100R
bikenut
PostPosted: 11:22 - 24 Jan 2015    Post subject: Reply with quote
https://i574.photobucket.com/albums/ss182/hmmmnz1/Hyosung/rx125.jpg
this is on this site in the manuals/wiring diagrams section ( brilliant to whoever put these on here, brilliant and amny many many thanks dude ) )
notice the charging wire from the reg/rec it fused...........no black load sensing wire..........
headlights appear to be dc powered not ac......
the only ac on this diagram is from genny to reg rec..........some from ign pickup but thats a different system........
I presume that the reg rec has 2 shrouded wire clusters coming from it.....one shrouded cluster of 3 yellow wires going to the genny....and the other shrouded cluster having 2 wires....one going to earth ( eventually ) and the other to the battery positive via the fuse......again I presume these wires are not "connected" to each other via heat and fusion and a bare yellow is not touching a bare red.......?
the diagram is not brilliantly clear on the vdu screen (or is that my old eyes ) and takes some following.....where else other than the reg/rec and genny could the battery experience ac??
print the diagram off and study.....save for future reference.....
does the eng start and run more or less perfectly?? so no feed back or noise from the cdi??
nuts about bikes
BikerMatt
PostPosted: 14:34 - 26 Jan 2015    Post subject: Reply with quote
Fixed Bounce!
bikenut
PostPosted: 11:28 - 27 Jan 2015    Post subject: cool Reply with quote
cool what was it in the end??
nuts about bikes
P.
PostPosted: 11:59 - 27 Jan 2015    Post subject: Re: cool Reply with quote
Sold it.
BikerMatt
PostPosted: 18:23 - 27 Jan 2015    Post subject: Reply with quote
Guy put the wrong alternator in.. looks like a suzuki one, guess they must've thought it'd be compatible since it's suzuki like Thinking
BikerMatt
PostPosted: 18:24 - 27 Jan 2015    Post subject: Re: cool Reply with quote
Paddy. wrote:
Sold it.
As if.. you'd be so lucky to even get a view on the ad Very Happy
bikenut
PostPosted: 11:22 - 28 Jan 2015    Post subject: sold it! nah! Reply with quote
well done matt!!!!
give your self a well deserved pat on the back!!
and another one for not giving in!
its a bike which now works, so enjoy. :karma:
nuts about bikes
The last post was made 10 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 130.75 Kb
