| trevor saxe-coburg-gotha |
| finchy95 |
 finchy95 Scooby Slapper
| finchy95 |
| Iain. |
 Iain. Could Be A Chat Bot
| chris-red |
| finchy95 |
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| finchy95 |
| UnknownStuntm... |
| Iain. |
 Posted: 18:59 - 28 Jan 2015 Post subject: |
Okay.
You need 25mm of slack with suspension unloaded.
You had 30+mm of slack with the suspension fully loaded.
You are supposed to take this measurement when the bike has no load on the suspension as sitting on the bike tensions the chain.
With the suspension unloaded, at a guess thats going to work out at closer to double the amount of slack that is allowed as a maximum tolerance. If the sprockets are good, the chain hasn't snapped, and the chain was correctly tensioned it simply cannot come off without defying the laws of physics.
I strongly suspect you've been measuring it wrong, but by all means dissasemble the gearbox  |
| finchy95 |
| finchy95 |
| UnknownStuntm... |
| finchy95 |
 Posted: 16:03 - 29 Jan 2015 Post subject: |
That *is* strange. I've still got the OEM chain on mine and it's done nearly 10k. Imo, on this bike, power is so low that chain tension isn't that crucial. I mean sure, it being too tight is absolutely not a good thing, and being too slack risks it jumping off a sprocket. But as long as there's a bit of play, and providing there are no serious tight spots where links have tired, *and* if the chain is kept clean and lubricated, the bike will go about its business without any trouble.
And this is despite the fact that the OEM chain is seen as absolute rubbish by many owners (and an item that requires immediate upgrade to a heavy duty DID job - hint; with proper cleaning and lubrication it most certainly does NOT). Having said that, the OEM chain IS thin and insubstantial. Adequate is the best that can be said. Secondly, there is no cush drive either - so in theory the chain and sprockets can work against each other in a way that they might not on a bike with rubbers in the carrier.
However, and to repeat - this is a bike that makes so little power that none of these things really matter. What might prove to be dangerous oversights with more powerful engines (e.g. incorrectly tensioned chain, or overly worn / unlubricated chain etc.) will in all probability be forgiven by the small 4t 125 that powers the vanvan.
Nevertheless, IF the bike is continuously ridden harshly by an unsmooth rider, and IF the chain is very poorly maintained, and IF the chain is cheap shit, and the sprockets cheap and rusty, THEN problems may well be encountered.
But none of this seems to be the case (although chain brand remains unknown). Therefore, if adequate chain and sprocket maintenance can be assumed, perhaps the issue really does lie with the transmission. If something is badly awry in that part of the engine's guts, I suppose drive to the front sprocket could be uneven, jerky and problematic enough to stress the chain out to the point of being flipped off the sprocket.
Keep us updated. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
| finchy95 |
| UnknownStuntm... |
| finchy95 |
| Iain. |
 Posted: 10:03 - 30 Jan 2015 Post subject: |
So after the chain came off and got mashed up..then you just put it back on without inspecting the damage or looking for tight links?
Perhaps it would be wise to ask a mechanic at the dealer how to adjust the chain as all of this seems to be down to poor maintinance/lack of knowledge.  |
| finchy95 |
| Iain. |
| UnknownStuntm... |
| Iain. |
| finchy95 |
The last post was made 11 years, 267 days ago. Instead of replying here, would creating a new thread be more useful? |
