Unpowered garage battery charging
LaurenceR46
PostPosted: 14:27 - 28 Jan 2015    Post subject: Unpowered garage battery charging Reply with quote
Hi all,
My garage has no mains power but I have plenty of larger leisure batteries I could use to keep my bike battery topped up over the winter - I could take these indoors once and a while to charge.
I am having trouble thinking of a way to safely keep the motorcycle battery topped up from these.
Am I right in thinking that I need a 12V input lead acid battery charger? Does anyone know where you can find them with a low standby power draw or if anyone has any better ideas.
I would like for the battery to remain in the bike and use fused leads to top-it-up with.
Thanks
Yamaha R6 (R46) Rossi Replica Edition
PostPosted: 14:51 - 28 Jan 2015    Post subject: Reply with quote
Assuming your bike is there during the day I would go solar.
PostPosted: 15:01 - 28 Jan 2015    Post subject: Reply with quote
Just do what I do and bring the battery into the house.
Matt B
PostPosted: 15:30 - 28 Jan 2015    Post subject: Reply with quote
This ^^^
R6, battery under the seat? So simple and easy to remove, literally a couple of minutes work so why not?
Taught2BCauti...
PostPosted: 15:35 - 28 Jan 2015    Post subject: Reply with quote
Solar is probably best for you - a leisure battery would just equalise it's voltage with the bike battery.
You can get bike chargers with a DC input, that have a separate mains adapter, but these usually need 16-18v going in to the charger.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
pdg
PostPosted: 15:47 - 28 Jan 2015    Post subject: Reply with quote
Do it really efficiently by getting a cheap inverter to run off the leisure battery, then plug in a normal battery charger.
What could possibly go wrong?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
LaurenceR46
PostPosted: 16:15 - 28 Jan 2015    Post subject: Reply with quote
The bike has an alarm system which I wish to remain armed (in addition to other garage alarms).
Pdg I did think of that I have an inverter but as you mentioned I'm not so sure about the efficiency of such a set-up plus the safety of use unsupervised(?).
Thanks
Fizzer Thou
PostPosted: 16:38 - 28 Jan 2015    Post subject: Reply with quote
A friend has one of these from Amazon and says that it works well
https://www.amazon.com/Sunforce-50032-Solar-Battery-Charger/dp/B0006JO0X8
Always have a 'Plan B'
Baffler186
PostPosted: 18:02 - 28 Jan 2015    Post subject: Re: Unpowered garage battery charging Reply with quote
Just putting this out there, but is installing mains an option? Take away the money you'd spend on solar/other options, and it might cost you a couple hundred. Plus, fit the charging leads to the battery so you wouldn't have to keep taking the battery out.
If it's any help, this is what I did:
Drill hole in the exterior wall to route your cable. Dig up the garden to lay cable, get sparky to wire it up both ends and fit consumer unit etc. I got the cable for free, and it only cost £130 extra including consumer unit and sparky's labour.
just a thought, I find a plug socket very useful.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
LaurenceR46
PostPosted: 18:05 - 28 Jan 2015    Post subject: Reply with quote
I would love to but the garage is in a block not located within cabling distance Sad. Thank you though
PostPosted: 18:19 - 28 Jan 2015    Post subject: Reply with quote
Get some sick solar going on.
PostPosted: 20:39 - 28 Jan 2015    Post subject: Reply with quote
Pikeys will nick the panels though, right?
PostPosted: 20:57 - 28 Jan 2015    Post subject: Reply with quote
You'd probably be ok to connect the two batteries directly.
You could get a battery to battery charger.
Or a balance charger as used for RC stuff etc - about £15 will get you one that will run off 12v and has all sorts of configuration options.
Or about £35 will get you a 20w solar panel and a 10a PWM charge controller. Can also use this on a leisure battery.
t121anf
PostPosted: 21:14 - 28 Jan 2015    Post subject: Reply with quote
Could you not charge one in the house and have another attached.
Iirc my alarm meta 357? Lasted a whole winter without charging.
1198
PostPosted: 21:17 - 28 Jan 2015    Post subject: Reply with quote
I had this problem previously. I would simply wheel the bike to the house and plug in a proper charger for a hour two, until the charger showed the battery was full.
(My preferred routine is actually to ride my bikes regularly - I was out on the 1198 at the weekend for instance. I don't like and don't leave a battery floating for days on end.)
The last post was made 11 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 86.19 Kb
