dropped the bike. Now I need to climb hills in a lower gear
Simba76
PostPosted: 10:59 - 29 Jan 2015    Post subject: dropped the bike. Now I need to climb hills in a lower gear Reply with quote
Hi Guys and Girls,
I dropped my Gn 125 this morning on its right side. No damage except the brake leaver is bent.
The brake lightr is not on so I dont think its sticking......but I had to take the hills on the way to work in a lower gear than normal.
3rd instead of 4th.
2nd in places that I've never need to change down before.
Also it seems like its going to die on me on a particularly steep hill.
Any suggestions?
I've ordered a new brake lever as I dont fancy trying to bend it back.
Cheers for your help in adavance...
If you can keep your head while all around are loosing theirs....you're probably in some sort of Zombie movie!
-Current bike ......
pdg
PostPosted: 11:04 - 29 Jan 2015    Post subject: Reply with quote
Put it on the centre stand (or get someone to hold the back end in the air, they only weigh about 1/2 pound) and try to spin the back wheel in neutral.
I bet it doesn't spin freely (well, as freely as something with a chain on can anyway)...
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
PostPosted: 12:48 - 29 Jan 2015    Post subject: Reply with quote
Go for a longish ride, spit on the rear brake, if it hisses it is sticking. Laughing Thumbs Up
monkeybiker
PostPosted: 13:45 - 29 Jan 2015    Post subject: Reply with quote
Sounds very much like the back brake is sticking. You might have bent something.
Simba76
PostPosted: 13:53 - 29 Jan 2015    Post subject: Reply with quote
Cheers Guys.
Havent managed to get out to check the free wheeling of the wheel yet.
If it is the rear brake....easy fix?
I'm not too bad with mending things myself but not tackled brakes yet.
andym
PostPosted: 15:10 - 29 Jan 2015    Post subject: Reply with quote
Might be worth checking around the spark plug area as I dropped my 125 a few years ago (v-twin), the bike would start and idle fine and was kind of normal on flat roads.... but when I got to a hill it ran like a bag of shit.... couldn't even manage it in first. Then I noticed 1 of the spark plug caps had come off, after that it ran fine.
Just saying as it only takes a second or 2 to check it is secure enough
PostPosted: 15:41 - 29 Jan 2015    Post subject: Reply with quote
Gn is a single, it wouldn't run with the plug cap off.
monkeybiker
PostPosted: 15:49 - 29 Jan 2015    Post subject: Reply with quote
You may get away with simply adjusting the back brake by turning the adjuster nut.
PostPosted: 16:01 - 29 Jan 2015    Post subject: Reply with quote
Dat.
It looks like you have the typical arrangement of a rod running back from the pedal to the drum brake actuator arm. There should be a tiny bit of play in that arm.
At the very end of the rod is a nut. Turn it anticlockwise, spin wheel, repeat until wheel spins freely.
Then find your rear brake light switch. That'll most likely be a pull switch attached by a wire to the brake lever. Firstly, pull down on the wire manually to check that the brake light does come on at some point. If it does, you'll need to move the switch away from the lever, likely by unscrewing it from whatever it's mounted in so that it moves upwards. Ensure that you don't twist any wiring while you're doing this!
PostPosted: 17:00 - 29 Jan 2015    Post subject: Reply with quote
Before you adjust anything have a good look at it, something may be bent/stuck whatever. If the brake was adjusted correctly to start with I wouldn't adjust it to fix without looking at it properly.
Commuter_Tim
PostPosted: 18:02 - 29 Jan 2015    Post subject: Reply with quote
Or post a photo here so someone more knowledgeable can tell him if something is broken?
It's hard to know if something is out of place, if you don't know what it should look like. Smile
I ride a Bandit 600... badly.
talkToTheHat
PostPosted: 14:32 - 01 Feb 2015    Post subject: Reply with quote
When I threw my GZ (cruiserified GN) down on wet leaves, I thought I'd bent the brake lever but it turns out it was the stop for the brake pedal so it threw my brake adjustment out. Needed a hammer to fix. It is possible your rear brake light adjustment is out, brake lights and absence of does not mean braking. Mine are set so in can flash brake lights without braking.
Bandit. does. everything.
jof
PostPosted: 22:50 - 01 Feb 2015    Post subject: Re: dropped the bike. Now I need to climb hills in a lower g Reply with quote
you may have bent the rod that would tighten up the brake
The last post was made 11 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 77.98 Kb
