| Simba76 |
 Simba76 Renault 5 Driver
| pdg |
 pdg World Chat Champion
| chris-red |
 Posted: 12:48 - 29 Jan 2015 Post subject: |
Go for a longish ride, spit on the rear brake, if it hisses it is sticking.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| monkeybiker |
 monkeybiker World Chat Champion
| Simba76 |
| andym |
 andym World Chat Champion
| chris-red |
| monkeybiker |
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:01 - 29 Jan 2015 Post subject: |
| monkeybiker wrote: | You may get away with simply adjusting the back brake by turning the adjuster nut. |
Dat.
It looks like you have the typical arrangement of a rod running back from the pedal to the drum brake actuator arm. There should be a tiny bit of play in that arm.
At the very end of the rod is a nut. Turn it anticlockwise, spin wheel, repeat until wheel spins freely.
Then find your rear brake light switch. That'll most likely be a pull switch attached by a wire to the brake lever. Firstly, pull down on the wire manually to check that the brake light does come on at some point. If it does, you'll need to move the switch away from the lever, likely by unscrewing it from whatever it's mounted in so that it moves upwards. Ensure that you don't twist any wiring while you're doing this! ____________________ Biking is 1/20th as dangerous as horse riding.
| chris-red |
| Commuter_Tim |
 Commuter_Tim World Chat Champion
| talkToTheHat |
 talkToTheHat World Chat Champion
| jof |
 jof L Plate Warrior
The last post was made 11 years, 144 days ago. Instead of replying here, would creating a new thread be more useful? |
