Visor covered in tiny scratches.
KingLies
PostPosted: 13:42 - 31 Jan 2015    Post subject: Visor covered in tiny scratches. Reply with quote
As the title suggests, my visor seems to be covered in tiny scratches from where I wipe my visor with my glove. But my glove has a soft wiper on it and I can't imagine this would have scratched my visor to bits. When I look through it, it looks as though my visor has steamed up, but it's just the tiny scratches that make it look this way.
It's a HJC helmet, cost me a fair few quid. How come this is trashed in 3 months when my cheap ass Box helmet lasted nearly 2 years with a visor that's fine?
Any suggestions on a fix or do I just have to keep replacing my visor every 3 months? Sad
EDIT: Picture
https://imgur.com/IsfTMSt
handbasket
PostPosted: 13:43 - 31 Jan 2015    Post subject: Reply with quote
I bet it’s not the glove that’s scratched it, it’s the road grime.
KingLies
PostPosted: 13:47 - 31 Jan 2015    Post subject: Reply with quote
Well the road grime hasn't bothered anything else and the tiny scratches go left to right. I've added a picture so you can see.
PostPosted: 13:52 - 31 Jan 2015    Post subject: Reply with quote
I would partially agree.
Winter riding and wiping your visor even with a soft wiper is akin to rubbing it with very fine grinding paste.
My helmet visor I usually end up replacing every year come spring. I try never to wipe a dry dirty visor if I can help it, that's the worst for scratching.
Carry a good visor cleaning kit, stop and clean it when you have to with visor cleaner and it will last a lot longer. Thumbs Up
Triumph Trophy Launch Edition
KingLies
PostPosted: 13:53 - 31 Jan 2015    Post subject: Reply with quote
I guess that makes sense. Doesn't explain why my crappy Box helmet visor is intact when I used to ride that through winter too. Sad
PostPosted: 13:55 - 31 Jan 2015    Post subject: Reply with quote
Hadn't seen that picture when I wrote the above.
That looks very like someone has either tried to clean it with brasso or something similar. That's mechanical damage from what I can see.
KingLies
PostPosted: 13:57 - 31 Jan 2015    Post subject: Reply with quote
I clean it with Muc Off helmet and visor cleaner with soft tissue. I don't understand how it's got so bad. Sad
doggone
PostPosted: 14:07 - 31 Jan 2015    Post subject: Reply with quote
There was a change in BS standards many years ago now and before that they often scratched badly like that in normal use.
Something is dodgy about that visor it can't be up to UK spec.
PostPosted: 14:12 - 31 Jan 2015    Post subject: Reply with quote
Agreed. If you got the helmet from a reputable dealer or on line from someone like racevisors, go back to them and ask for their opinion. They might agree, or give you a discount on a replacement.
If you got it on ebay, Sad Probably out of luck.
I have HJC helmets and the visors have never gone like that.
PostPosted: 14:36 - 31 Jan 2015    Post subject: Reply with quote
All my visors go like that.
Had a brand new arai one look like that after 3 hours on the A1.
It's salt dust that causes it. Worst on motorways. Worst in conditions where the roqad is wet but it isn't raining.
The salty spray gets splashed onto your visor by wagons then dries in the airflow, leaving a film of salt. You see your visor splashed up, wipe it with your finger and it's fucked.
That's because salt is harder than polycarbonate and scratches it.
They don't do anything about it for the same reason they didn't make long lasting filament lightbulbs.
PostPosted: 15:58 - 31 Jan 2015    Post subject: Reply with quote
<rant>
Why would it be? It'll E13 or similar, 'tested' in Luxembourg, by which I mean stamped or stickered as such with no way of verifying that the design has actually passed any testing at all.
</rant>
You can try plastic polish like Meguiar's, heat or even a tiny bit of toothpaste and gentle polishing.
Any of them might make it worse. Or they might make it better. It's a hard life, and no mistake.
monkeybiker
PostPosted: 16:30 - 31 Jan 2015    Post subject: Reply with quote
You can get plastic polish. It takes some time and effort but does work. I've got a bottle somewhere but can't find it so don't know the brand but google it and you should find some.
PostPosted: 16:41 - 31 Jan 2015    Post subject: Reply with quote
Looks like what happens when you wipe your visor with tissues or kitchen roll. Never use tissues or kitchen roll (unless it's Bounty). A yellow duster, microfibre cloth or soft sponge with plenty of soapy water is what I use.
doggone
PostPosted: 17:06 - 31 Jan 2015    Post subject: Reply with quote
I haven't had one even need changing before the helmet did the last ten years at least.
In the 80s you needed a new visor every year.
They should not scratch in normal (careful) use if complying with current standards.
Skudd
PostPosted: 22:09 - 31 Jan 2015    Post subject: Reply with quote
I use plenty of water and soap with limited rubbing when cleaning visors, but still change them every year or sooner if needed. Just treat visors as a consumable like a lot of bike stuff. I always have a couple of spare visors, dark/clear for my lids.
monkeybiker
PostPosted: 08:18 - 01 Feb 2015    Post subject: Reply with quote
Where's the best place to buy visors. I got a aftermarket one off ebay but it was little off like a mm. It still fit but did not line up perfect like the original.
iooi
PostPosted: 09:33 - 01 Feb 2015    Post subject: Reply with quote
Crystalusion
Get some of this. Put it on your new visor and it works a treat.
Helps bead of water. Allows you to wipe a dirty visor and leaves no scratches.
You will find that, the soft patch will collect muck and scratch your visor far more than a harder surface.
I would go to somewhere like Racevisors for a new visor.
pay peanuts and you end up with a visor that may not be upto the job...
I have used this on my phone for 6 months now with great results. A added bonus was that the sheets were still wet enough to do 3 phones as well a my motorbike helmet visor. The results on the visor are just great. 6 months on and no new scratches despite being rubbed on a regular basis to remove flies and water. Even helps to keep water droplets from sticking to visor. All in all a great product.
My review. This is the 2nd batch of this I have used and the review was based on 1st batch.
It was applied to a 2 year old visor that was already scratched. Now on a new visor and not a mark on it since begining on November despite heavy usage.
Taught2BCauti...
PostPosted: 09:40 - 01 Feb 2015    Post subject: Reply with quote
It's called PolyWatch and is used for removing scratches from watch glasses.
Very effective on visors, leaving them with a super-smooth finish that helps repel rain.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
talkToTheHat
PostPosted: 02:06 - 02 Feb 2015    Post subject: Reply with quote
I was going through HJC HJ-09 visors at an alarming rate. They seem very soft. My Shark visor seems to be fairing much better.
I have used toothpaste on indicator lenses and suchlike and it works well, not tried it on visors but I might test such ideas on a retired hjc visor before daring to mess with my shark visor should it get scratched.
Bandit. does. everything.
PostPosted: 08:21 - 02 Feb 2015    Post subject: Reply with quote
What standards and why not?
andys675
PostPosted: 13:26 - 02 Feb 2015    Post subject: Reply with quote
visors are anti-scratch, not scratch proof
visor cleaner? =hello I've just put solvent all over my plastic visor
mr-jermy
PostPosted: 13:45 - 02 Feb 2015    Post subject: Reply with quote
sounds similar to what happens to car headlights after time, where they get scratches on due to the crap off the road, a tip i got told from a friend of mine whom is a professional valeter, try getting some toothpaste on it and rubbing that in it should help clear the scratches up, if your unsure try googling using toothpaste on headlights, cant guarantee it will work completely but should help Smile
currently rebuilding a Honda NS125RL Smile selling a baotian bt49 qt-9
Mudshark
PostPosted: 15:26 - 02 Feb 2015    Post subject: Reply with quote
brasso
R1250RS
XT660X
ws4936
PostPosted: 16:45 - 02 Feb 2015    Post subject: Reply with quote
Just remove the visor and wear glasses instead
If everything seems under control, you're just not going fast enough.
PostPosted: 22:30 - 02 Feb 2015    Post subject: Reply with quote
Methylene Chloride vapour cleans those headlights up a treat. Might work on a visor.
The last post was made 11 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 129.42 Kb
