Replacing rear shock UPDATED
Az
PostPosted: 00:02 - 01 Feb 2015    Post subject: Replacing rear shock UPDATED Reply with quote
Any tips on replacing the rear shock on my Bandit. Don't want the rear end collapsing on me or anything Shocked
What I plan to do:
Use a car jack on the frame to take tension off the rear shock (towards the rear end of the frame)
Brick under rear wheel
Undo bolts and take off standard rear shock, replace with new shock.
Nexus Icon
PostPosted: 00:06 - 01 Feb 2015    Post subject: Reply with quote
Can you not suspend the rear of the bike from a beam or A-frame? It would be my preferred option.
Greetings from Shitsville!
Az
PostPosted: 00:24 - 01 Feb 2015    Post subject: Reply with quote
Bikes lives in an underground car park, no beams or anything.
PostPosted: 00:43 - 01 Feb 2015    Post subject: Reply with quote
Mattress, lay it down.
Alternatively jack it up, axle stands under the foot peg/frame and have someone hold it whilst you undo the bolts fully, loosen them before jacking it up.
Az
PostPosted: 16:05 - 01 Feb 2015    Post subject: Reply with quote
All done, used a spare mattress Smile and it was surprisingly easy to do and having someone else helping made it a lot easier.
https://i789.photobucket.com/albums/yy178/AzAndBikes/967F6FE8-C407-483F-B5A0-89BC041FAEF8_zpsxxdvku0a.jpg
https://i789.photobucket.com/albums/yy178/AzAndBikes/BC99434E-D46A-4845-BCE0-3E8C97B6BC35_zps6sy76nhi.jpg
https://i789.photobucket.com/albums/yy178/AzAndBikes/C2A9D1A6-60CA-44AD-8215-FED11D63C686_zps3jgnobvf.jpg
Az
PostPosted: 16:33 - 01 Feb 2015    Post subject: Reply with quote
Shock is noticeably stiffer & im very certain that it's raised the seat height.
Took it for a quick spin & it feels too stiff.
I'm 9stone and about 40% of my riding is with a 9stone pillion.
What adjustments would u recommend?
Skudd
PostPosted: 16:43 - 01 Feb 2015    Post subject: Reply with quote
Pies.
DrSnoosnoo
PostPosted: 16:44 - 01 Feb 2015    Post subject: Reply with quote
Less damping. Loosen that nut at the top of the shock a bit.
CHR15
Turbo nutter bastard
PostPosted: 18:08 - 01 Feb 2015    Post subject: Reply with quote
phone the company you bought it from and ask them the setup for your weight and riding style.
Boris the spider
PostPosted: 18:12 - 01 Feb 2015    Post subject: Reply with quote
Nice gold sprocket. Razz
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
YBR Ric
But before you move the preload ring, just check for a grub screw down one of those holes that might need slackening off.
Some makes of shock have them and some don't - so if you can't find one don't panic, unless you can see threads but no screw!
Az
PostPosted: 18:13 - 01 Feb 2015    Post subject: Reply with quote
Second hand buy at £87, I have found a fairly local suspension specialist (Revs Suspenion in Birmingam) on the internet. Will give them a call tomorrow and see how much they'd charge to set it up. If it's cheap enough, I'll just let them do there thing Smile
CHR15
PostPosted: 18:17 - 01 Feb 2015    Post subject: Reply with quote
they're good at what they do. rebuilt all the suspension on my gk73a for a very reasonable price.
PostPosted: 18:23 - 01 Feb 2015    Post subject: Reply with quote
Well that seemed to have worked Laughing
Aff
PostPosted: 18:28 - 01 Feb 2015    Post subject: Reply with quote
Az wrote:
Electric Bike Project
Ed Case
PostPosted: 18:43 - 01 Feb 2015    Post subject: Reply with quote
I bought a Wilbers suspension unit for my ER6F off them...good people to deal with...recommended.
Az
PostPosted: 19:49 - 01 Feb 2015    Post subject: Reply with quote
Haha worked really well to, thanks for the suggestion Very Happy
Supersprox rear sprocket, very good when matched up with a DID x ring chain and JT front sprocket. It's been on for a while now and hasn't needed much adjustment at all Smile Thumbs Up
Also Revs Suspension sounds really good so I'm praying it's not too expensive to have the shock set up.
pdg
PostPosted: 16:11 - 02 Feb 2015    Post subject: Reply with quote
If you mean the big nut that sits against the spring, that has absolutely nothing whatsoever to do with damping -- it's for preload...
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
DrSnoosnoo
PostPosted: 16:14 - 02 Feb 2015    Post subject: Reply with quote
After reading, you're right - got my words wrong Thumbs Up
Az
PostPosted: 19:19 - 02 Feb 2015    Post subject: Reply with quote
Revs suspension quoted me £20 to adjust my shock so that it's suited for me. That's based on the assumption that the shock doesn't need to come off the bike to be adjusted (so all the adjustments points are accessible when the shock is on the bike).
Plan on taking it into them this Saturday to have it adjusted, as that price is a lot cheaper than I first thought it would be.
bikertomm
PostPosted: 20:27 - 02 Feb 2015    Post subject: Reply with quote
Az wrote:
Needs moar lows Laughing
evoboy
PostPosted: 21:56 - 02 Feb 2015    Post subject: Reply with quote
The plastic knob at the bottom of the shock is to adjust the rebound damping.
The ring at the top does the preload, it has grub screws to secure it.
Loosen the ring off as it appears to be wound up quite a way. You want it so that the bike has about 5-8mm of sag when held up without a rider.
APT Motorcycles
Snowdonia Rider
PostPosted: 07:12 - 03 Feb 2015    Post subject: Reply with quote
I wish I had a suspension specialist near me, amongst other things. There's nothing where I live Sad
reed
PostPosted: 17:30 - 03 Feb 2015    Post subject: Reply with quote
I used a car jack when i changed the shock on my 1999 Hornet. When i unbolted the shock, and took it off, the jack gave way and fell out from under the bike.
I the realised that i could easily support the bike with one hand by holding the pillion grab rail. The rear end was virtually weightless. So i slotted the new shock in and put the bolts through whilst holding the bike up. Was odd. Laughing
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
The last post was made 11 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.92 - MySQL Queries: 13 - Page Size: 126.25 Kb
