Homebrew version of hammerite rust remover dip ?
Ribenapigeon
PostPosted: 15:11 - 01 Feb 2015    Post subject: Homebrew version of hammerite rust remover dip ? Reply with quote
I bought some hammerite rust remover dip to get the rust off some tools in restoring. It works fine but is pricey. Is there a homebrew version? There's no clue on the bottle as to the active ingredients.
Cheers.
barrkel
PostPosted: 15:16 - 01 Feb 2015    Post subject: Reply with quote
Active ingredient is probably an acid. There's lots of articles on the web about using various acids to remove rust.
Of course, there's other techniques, like electrolysis.
PostPosted: 15:36 - 01 Feb 2015    Post subject: Reply with quote
I think there is some rather complex chemistry involving chelation and stuff like that, I doubt you could make some at home.
Ribenapigeon
PostPosted: 16:26 - 01 Feb 2015    Post subject: Reply with quote
I just cleaned up a piece after soaking it overnight. Its worked well. Something I noticed was a steel part had taken on some copper colour as if plated. Part of the thing I dipped is brass. So some sort of electrolytic process has occurred. If the solution is an acid would that have created copper salts then some potential difference between the brass and steel caused some electroplating?
DrSnoosnoo
PostPosted: 17:02 - 01 Feb 2015    Post subject: Reply with quote
Coca cola works well. Just soak shit in that. Carbonic acid knocks about which can work to get the rust away. In the hammerite gear, the stuff that turns rust black is apparently phosphoric acid.
PostPosted: 18:29 - 01 Feb 2015    Post subject: Reply with quote
Strong hydrochloric acid, (also marketed as spirit of salts) will remove rust (and dissolve metal).
Hot, strong phosphoric acid will remove rust and black anodise bare metal.
Electrolysis will loosen/remove rust very effectively but not in the way you think it does.
If you had something pretty rusty, you could do them one after the other. So electrolysis then HCl then Phosphoric acid.
A mate of mine pulled a rusty sidecar chassis out of a river estury. He did it in an electrolysis bath. Went from this:
https://www.ratbike.org/aarrgghh/SSOD/pic_0501.jpg
To this:
https://www.ratbike.org/aarrgghh/SSOD/Detail2.jpg
https://www.ratbike.org/aarrgghh/SSOD/Detail1.jpg
barrkel
PostPosted: 18:35 - 01 Feb 2015    Post subject: Reply with quote
Carbonic acid is fizzy water - it's carbon dioxide dissolved in water. Coke also contains phosphoric acid. Soaking in coke, you're relying more on the latter than the former.
PostPosted: 18:47 - 01 Feb 2015    Post subject: Reply with quote
Go for the electrolysis option. You'll most likely have nearly all the stuff needs lying about anyway and it's pretty much set up and forget and really does work.
Ribenapigeon
PostPosted: 18:55 - 01 Feb 2015    Post subject: Reply with quote
how do you homebrew electrolysis?
Moo.
PostPosted: 18:59 - 01 Feb 2015    Post subject: Reply with quote
Electrolysis is a bit fiddly, but for sit back a watch...
Look up Molasses rust removal.
Basically dissolve 1 part molasses sugar to 10 parts water, takes aaaages to soak, but its dirty cheap (£1.19 per 500g) forms an acidic solution which eats away...
If you want good results and are willing to spend a bit, look up Deox-C gel or crystals, made by a company called Bilt Hamber. Good results
Most acids will form salts on the surface of the metal afterwards though, these salts attract water, so if its not treated soon (painting, or rust protection) there will be surface rust soon..
A2 Passed 18/6/10
PostPosted: 19:17 - 01 Feb 2015    Post subject: Reply with quote
Here
Ribenapigeon
PostPosted: 19:29 - 01 Feb 2015    Post subject: Reply with quote
Bloody amazing https://m.youtube.com/watch?v=vq5IUiYMhRM
DrSnoosnoo
PostPosted: 19:39 - 01 Feb 2015    Post subject: Reply with quote
The amount of carbon dioxide dissolved in the water would give a high amount of this fizzy water, how much phosphoric acid do you propose is in coke?
barrkel
PostPosted: 20:16 - 01 Feb 2015    Post subject: Reply with quote
This Q&A looks interesting and relevant: https://chemistry.stackexchange.com/questions/2859/what-makes-coke-acidic
It seems there's not 100% agreement on whether the acidity is mostly carbonic or phosphoric acid. It would be great if we had a higher authority than a student's experiment to go on.
However, this wouldn't be relevant in practice. Use coke in a non-pressurized bath for anything with as many nucleation sites for bubbles as rusty metal, and it will be flat in short order. Then you'll be relying on the phosphoric acid.
DrSnoosnoo
PostPosted: 20:59 - 01 Feb 2015    Post subject: Reply with quote
It wasn't too long ago that I tried to find a declared level of phosphoric acid in coke but, hey, it's what helps their flavour so they don't go shouting about it.
Ribenapigeon
PostPosted: 21:46 - 01 Feb 2015    Post subject: Reply with quote
What if you kept carbonating it with a soda stream type arrangement?
bikenut
PostPosted: 12:38 - 02 Feb 2015    Post subject: rust Reply with quote
have heard that lemon juice is quite good.......used on the nazi fighter plane in cosford, from the channel..........
will post an article from a mag about home electrolysis......
phosphoric acid is in coke....also Jenolite rust remover........
carbonic acid ( as well as sulphuric and other stuff no doubt ) is in rain fall, acid rain.......
nuts about bikes
bikenut
PostPosted: 12:43 - 02 Feb 2015    Post subject: Reply with quote
TheBaldRevere...
PostPosted: 18:17 - 01 Feb 2015 Post subject: Reply with quote
Here
View user's profile Send private message Rate this post: Good Bad
that's the one, article shows rusty mess, the rust removed.......says it leaves the clean article with a black patena coating.......
now to find home electroplating stuff in tin.........or copper...... Karma
nuts about bikes
The last post was made 11 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 101.21 Kb
