Triumph Tiger Recall....
Entertwainer
PostPosted: 13:03 - 02 Feb 2015    Post subject: Triumph Tiger Recall.... Reply with quote
thought it may be prudent to share this info incase anyoneon here owns one.
Product recall for the following:
Category: Motor vehicles
Product: Motorcycle
Brand: Triumph
Type/number of model: Tiger Explorer and Tiger Explorer XC
Batch number/Barcode: Build dates are 01/11/11 – 01/06/14
OECD Portal Category: 77000000 - Automotive
Description: Motorcycle.
Country of origin: United Kingdom
No pictures are available
Injuries
The side stand pivot bolt may fracture under abusive loads.
Voluntary measures:
Recall of the product from end users
i imagine owners should have been contacted. but if you havent, you may want to get in touch.
Honda CG 125 W - Turkish - 1998 - 2015 RIP
PostPosted: 13:18 - 02 Feb 2015    Post subject: Reply with quote
Seems pretty stupid, you would have thought in this day an age a manufacturer would have learnt what strength bolt to use for a side stand .
ScaredyCat
PostPosted: 13:19 - 02 Feb 2015    Post subject: Reply with quote
"abusive loads"? - Those "abusive loads" are your customers...
Very Happy
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 14:31 - 02 Feb 2015    Post subject: Reply with quote
Just trying to keep up with BMW. Whistle
PostPosted: 14:37 - 02 Feb 2015    Post subject: Reply with quote
Too many fat riders Very Happy
If mine didn't break under my 'abusive load' I think they are pretty safe!
Triumph Trophy Launch Edition
Mudshark
PostPosted: 15:24 - 02 Feb 2015    Post subject: Reply with quote
they don't allow it
"The side stand is designed
to support only the weight
of the motorcycle.
Do not lean or sit on the
motorcycle with the side stand
extended."
R1250RS
XT660X
iginge
PostPosted: 16:27 - 02 Feb 2015    Post subject: Reply with quote
of the motorcycle.
extended."
Yes you may buy our very expensive motorbikes but please read the small prints as it's advised you shouldn't weigh more than a feather and shouldn't actually ride the bike rather lock it away in a garage and clean it Laughing
I've heard that triumph like taking messing their customers around but this is the best I've read yet, it's honestly what I'd expect from a chinese manufacture (poor build quality), my side-stand nut was loose, simply tightened.. problem solved..
To brake under load.. so the bike wasn't stress tested enough during manufacture, one key feature to prevent it from falling over was designed incorrectly, words fail me.
I struggle to understand what exactly an "abusive load" bar the customers is.. their either insulting people or stating their machines poorly designed..
PostPosted: 16:34 - 02 Feb 2015    Post subject: Reply with quote
Wut?
They probably mean a 25 stone man flipping the sidestand down and then falling onto it from upright. I'd class that as an 'abusive load'.
Somehow because they made this mistake it makes them worse than chinese bike manufacturers? Evil corporate entity, how dare you make a tiny mistake in the engineering of a product I'm not even going to buy? It sounds a bit pathetic to be honest.
iginge
PostPosted: 16:38 - 02 Feb 2015    Post subject: Reply with quote
You're making words up here.. I stated "I'd expect from a chinese manufacture (poor build quality)".. read the above, I didn't call them worse than.. so yeah.
And it's not even stated what the cause of an "abusive load" is therefore again assuming it's the rider.
Also how have you not picked up on the above quote my original message was in response to, if correct.. how as a manufacture are you expected to be taken seriously when advising "don't sit on the bike with the sidestand down"..
PostPosted: 16:43 - 02 Feb 2015    Post subject: Reply with quote
Do you own a Tiger 800?
iginge
PostPosted: 16:45 - 02 Feb 2015    Post subject: Reply with quote
You've missed all three of my points there, irrelevant question is irrelevant and off-topic, my opinion is my opinion of which you're clearly not happy with.
Each to their own Thumbs Up
PostPosted: 16:58 - 02 Feb 2015    Post subject: Reply with quote
No I'm pretty sure you don't have a clue what you are going on about.
mentalboy
PostPosted: 17:05 - 02 Feb 2015    Post subject: Reply with quote
I think the only 'person' I've heard advocating posing on their bike with the sidestand down is Bodyguard. Just because enough people do it doesn't mean that it's designed to take the weight of a bike and a 400 pound porker bouncing up and down on it
Make mine a Corona.
PostPosted: 17:08 - 02 Feb 2015    Post subject: Reply with quote
How long have you been a member of this forum?
Mr_T
PostPosted: 18:29 - 02 Feb 2015    Post subject: Reply with quote
The problem comes from people repeated overloading the stands, i.e. standing on the footpeg while the bike is on the stand to get onto the bike, often when it's already loaded with luggage and a pillion.
Try doing that with your chinese bike and see how long it lasts...
PostPosted: 18:53 - 02 Feb 2015    Post subject: Reply with quote
Took him about 5 minutes to get on my *PLONK* list.
Nemo
PostPosted: 20:08 - 02 Feb 2015    Post subject: Reply with quote
I've lost count of the amount of these I've done.
It's obviously a better safe than sorry thing. A couple of bikes have fallen over so they change all of them.
It's the same as suzuki last year, two front master cylinders failed in america within something like ten months of each other, so they decided to recall around 25,000 of them.
I should also mention to not forget it isn't the manufacturer (most of the time) who decide to implement a recall in the UK, it's vosa I think.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
PostPosted: 22:04 - 02 Feb 2015    Post subject: Reply with quote
Iginge you are a prat, and a wanker!
Mudsharks reference was to BMW not Triumph.
I always used to stand on the footpeg of my explorrer when getting on the bike, it never collapsed.
Recalls show whether a manufacturer is willing to support his product. My Trophy has had a new cylinder head. I had a courtesy bike while it was being done.
You really dont have a clue comparing Triumph to chinese.
-Monty-
PostPosted: 22:28 - 02 Feb 2015    Post subject: Reply with quote
Why would not being able to sit on your bike while the side stand is down prevent you from riding your bike? Confused
Not quite sure how this relates to the topic at hand. The side stand nut being loose is not really anything to do with the strength on the side stand itself.
Some nice quoting there. It actually states "abusive" load. Whilst it seems Triumph haven't stated what an "abusive load" consists of, I think we can be fairly sure it is not simply the weight of the bike on it's own.
Also, regarding the comment comparing Triumph to Chinese brands. Do you honestly think if a Chinese manufacturer realised they had incorrectly designed their side stands, that they would do a product re-call to put the affected bikes right? Not only would they not carry out the recall, but I strongly suspect they would dig in their heels if a customer tried to claim on the warranty in the event of a side stand failing.
Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition]
iginge
PostPosted: 22:41 - 02 Feb 2015    Post subject: Reply with quote
Sarcasm, just seemed a very strange issue to justify a recall (although depends again on what the "abusive loads" are).
-Monty- wrote:
some nice quoting there. It actually states "abusive" load. Whilst it seems Triumph haven't stated what an "abusive load" consists of, I think we can be fairly sure it is not simply the weight of the bike on it's own.
Agreed, the reasons behind "abusive loads" are not stated therefore is anyone's guess at who and or what would cause the problem with the stand.
And probably, dependant on rider knowledge and dealership a chinese bike may get fixed but chinese bikes have more problems than I have time to list so it's hard to compare.
And if the earlier quote regarding not being able to sit on the bike while the sidestand is down is about BMW's as opposed to Trimuph's then my mistake on interrupting what manufacture it was about.
PostPosted: 22:42 - 02 Feb 2015    Post subject: Reply with quote
I just find it tremendously amusing that iginge finds Triumph to be so objectionable for supposedly not adequately testing their product, when he doesn't own said product, or has any intention of buying one?
Japanese manufacturers issue recalls all the time. Suzuki has had a few recently with brake pads, master cylinders, head bearings, frame strengthening etc etc.
The recalls are performed for free, and in fact, I had a recall on my Street Triple for the Regulator Rectifier. Interestingly the reg rec blew and took out my alternator windings too. Triumph repaired the entire thing for free and I didn't even have to ask them to do it. They just handed me the keys and said "all done". If that isn't good customer service, then what is? They technically only had to replace the reg rec, whereas they replaced a whole different component too free of charge.
It would amuse me immensely if it turns out iginge has never owned a Triumph. In fact, he sounds very much like he falls into one of two camps:
1.) An occupational complainer who enjoys nothing more than disparaging firms for their perceived but actually non existent corporate excesses
2.) A 17 year old with a Qonging and no actual clue about motorcycling.
1198
PostPosted: 23:22 - 02 Feb 2015    Post subject: Reply with quote
I now get really annoyed when I see folk posing on bikes resting on the stand, be it side stand or centre stand. They're designed to support the weight of the bike, not the bike AND a lardy ass!
It's a common thing by teenagers trying to look cool sat on their learner bikes as much as anything, perhaps my firm belief on this is due to my stand being buggered to the extent it would fall over (in front of the Police once when I'd been stopped) when used. I had to prop it on walls - not quite the look to attract the young ladies.
blackbosh
PostPosted: 23:42 - 02 Feb 2015    Post subject: Reply with quote
I would rather get a recall on something like this than risk my bike being one of the 3 that fails out of thousands. Triumph "your bike needs some work doing 3 bikes of 4 million had a fault and we don't want to take a chance"
Me "Thanks for calling it will give me an excuse to go out on my bike. Can I take that new XC out for a blast while its being done?"
Triumph "Certainly sir, we will have a brew ready as well, Tea milk no sugar as usual"
In my world this would happen.
recman
PostPosted: 23:54 - 02 Feb 2015    Post subject: Reply with quote
I hope this dodgy Tiger bolt is different to mine.
I always have to pivot the bike 180 degrees on the stand every time I come home and put it away.
Just_James
PostPosted: 00:38 - 03 Feb 2015    Post subject: Reply with quote
You tryin to say this aint cool? Eh?
https://upload.wikimedia.org/wikipedia/commons/f/f9/Overweight_biker.jpg
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
The last post was made 11 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 139.38 Kb
