Brakes & Cold
Alpha-9
PostPosted: 18:11 - 02 Feb 2015    Post subject: Brakes & Cold Reply with quote
Anything I should be wary of when the weather is fucking freezing outside with hydraulic brakes?
This morning the brake was fucking shit, but the way back it was fine. Was well cold though and had to scrape the ice off the bike again.
I don't even - surely fluid can't freeze? I was braking a bunch before hitting the proper road to try and warm it up, but at one point I could pull the lever all the way into touching the grip.
Seems the cap has come a little loose and needs tightening - I Imagine moisture would seep in and fuck it right up? Mechanic did the front brake about a month or two ago
Also got an indicator lense because it was smashed, screwed it on, get to work. it's gooooooooooooone Crying or Very sad Was gonna super glue it on but forgot Rolling Eyes
Fzr-600 1999
monkeybiker
PostPosted: 18:39 - 02 Feb 2015    Post subject: Reply with quote
What cap was loose?
Sounds like you had spongy brakes. You need to get them checked out. Not sure what you mean by loose cap, were the brakes leaking fluid? Did the mechanic leave something loose? Would it be possible that someone may have tampered with your bike?
Seriously I would not recommend you ride the bike until the brakes have been checked out.
Alpha-9
PostPosted: 18:48 - 02 Feb 2015    Post subject: Reply with quote
monkeybiker wrote:
What cap was loose?
The brake reservoir cap, as it was drilled out and bodge screwed together
Spongy brakes it is then. I thought him stripping and new seals would have solved it?
Nah i'll ride it, got work innit Laughing
Fzr-600 1999
PostPosted: 18:51 - 02 Feb 2015    Post subject: Re: Brakes & Cold Reply with quote
Rubber seals in the master cylinder shrunk just enough to let fluid seep past?
Probably not, just shooting the breeze.
dydey90
PostPosted: 19:16 - 02 Feb 2015    Post subject: Reply with quote
Are you saying your brakes are held together by tape and wishful thinking, then wondering why they're not razor sharp? Wink
Alpha-9
PostPosted: 19:19 - 02 Feb 2015    Post subject: Reply with quote
Reservoir cap /= brakes
It was screwed on with washers actually and was tight to begin with Thumbs Up
Tape and wishful thinking may be the next step though Laughing
I don't want razor sharp, I just want functional, does have EBC pads as if they make much of a difference other than probably wearing quicker
Fzr-600 1999
Dalemac
PostPosted: 19:25 - 02 Feb 2015    Post subject: Reply with quote
Buy a new reservoir/cap, replace, rebleed brakes, job jobbed.
YBR125 -> GPZ500S -> SL1000
Alpha-9
PostPosted: 19:26 - 02 Feb 2015    Post subject: Reply with quote
Waahh bleeding brakes, I can't fucking do it I always fuck the whole thing up every time Crying or Very sad
Fzr-600 1999
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
pits
PostPosted: 19:28 - 02 Feb 2015    Post subject: Re: Brakes & Cold Reply with quote
No fluid can't freeze, ever in fact that is the main requisite of fluid is that it doesn't freeze, it is why lakes etc don't freeze over..
Brake fluid can freeze, in these temps no I would put it down to you being shit and therefore your bike being shit Thumbs Up
PostPosted: 19:31 - 02 Feb 2015    Post subject: Reply with quote
Brake fluid doesn't freeze in Norway at -35, so why would it freeze in the UK at -2?
Replace the fluid, and if you can't manage that simple task yourself, I recommend paying a mechanic to do it before you die on the bike.
Or die, either way I guess...
Alpha-9
PostPosted: 19:35 - 02 Feb 2015    Post subject: Reply with quote
Was all done by a mechanic not long over a month ago which is why i'm confused
Was food for thought, wasn't saying it was definitely moisture Rolling Eyes Figured it was just shit brakes from the cold.
Will give him a call, thanks for being nice helpful guys about it as ever Wink Trying to save a bit of money, something always comes up every damn month.
Fzr-600 1999
Alpha-9
PostPosted: 09:04 - 03 Feb 2015    Post subject: Reply with quote
Wellll no brake at all this morning, straight to the mechanics Rolling Eyes Thumbs Up
Fzr-600 1999
Atomic Punk
PostPosted: 15:33 - 03 Feb 2015    Post subject: Reply with quote
Check your brake pads, the ware could be close to the end of life.
I may have lost my way but I'm way ahead of schedule.
ride_to_die
PostPosted: 15:46 - 03 Feb 2015    Post subject: Reply with quote
Which mechanic are you using?
I'm not here for a long time, I'm here for a good time.
Pie-Roe
PostPosted: 16:24 - 03 Feb 2015    Post subject: Reply with quote
My friend noticed his brakes were a little spongy recently and decided with this extra cold, wet and miserable weather he needed tip top razor sharp brakes.
He bled them, had a massive improvement. First ride out he applied as much front brake as he normally would, locked it and slid his er6 down the road.
I can imagine this to be an alpha thing to do, in the nicest possible way.
bikertomm
PostPosted: 16:32 - 03 Feb 2015    Post subject: Reply with quote
inb4 Alpha does this on way to work:
https://www.youtube.com/watch?v=ZMZpttgMnbE&list=LLAXMYELFQFlrLs-ttOLeqvQ
Laughing Thumbs Up
Alpha-9
PostPosted: 18:42 - 03 Feb 2015    Post subject: Reply with quote
Had crossed my mind bro Thumbs Up
OK so update!
Mechanics was closed - and it was J&C in barwell, he's a good dude, I think it's the shitty resevoir screw drilling out and sealing up which my mate did causing the seepage of moisture...
Anyway!
So mechanics was closed, winter opening times, opened the reservoir cap to find - slush! Little bit of fluid and an icy sludge... so scraped it out and topped up the fluid, brake works but isn't amazing
Will see how it is tomorrow morning, I've resealed the reservoir with "tape and goodwill"
Safety nazis will love I rode it to work and back today Laughing
Honestly I think its ok but not as good as I'd like it, it's probably minimal
Much better now I've put more fluid in and got the slosh out lol, hoping the tape will keep the frosty leak out
This basically needs to be done Thumbs Up
Fzr-600 1999
trevor saxe-coburg-gotha
PostPosted: 18:56 - 03 Feb 2015    Post subject: Reply with quote
https://www.reclaimingthemind.org/blog/wp-content/uploads/2013/03/darwin.gif
Rogue_Shadow
PostPosted: 19:00 - 03 Feb 2015    Post subject: Reply with quote
So you've now got watered down brake fluid?
I'd be inclined to drain the lot, add new and bleed the system.
It's really not that complicated, even I manage to do it.
Me, who go distracted & picked up the brake fluid before continuing to add a capful into my coolant reservoir.
Fun times Embarassed
monkeybiker
PostPosted: 20:10 - 03 Feb 2015    Post subject: Reply with quote
Don't be stupid, get the brakes sorted. I'd bleed and replace all the fluid if it was me.
Alpha-9
PostPosted: 23:27 - 03 Feb 2015    Post subject: Reply with quote
Aye, will do Thumbs Up
Fzr-600 1999
CaNsA
PostPosted: 04:11 - 04 Feb 2015    Post subject: Reply with quote
bikertomm wrote:
Alpha is a alpha does is.
https://www.facebook.com/video.php?v=10151926661180790&set=vb.820015789&type=3
https://www.facebook.com/video.php?v=10151926643555790&set=vb.820015789&type=3
https://www.facebook.com/video.php?v=10151926669780790&set=vb.820015789&type=3
Eddie Hitler
PostPosted: 04:16 - 04 Feb 2015    Post subject: Reply with quote
Bleeding brakes on a motorcycle is a piece of piss. It sounds so much more daunting than it actually is, honestly.
Skudd
PostPosted: 05:29 - 04 Feb 2015    Post subject: Reply with quote
If you had linked ABS brakes like my Varadero does you would have a VERY different opinion.
The last post was made 11 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 129.91 Kb
