sh*t! bike won't start
ikeyfaz23
PostPosted: 23:47 - 03 Feb 2015    Post subject: sh*t! bike won't start Reply with quote
just riding home and it just wouldn't respond all of a sudden then cut out and wouldn't start, leaving me pushing a nice 180kg 125 for a mile.
extra info(might not be relevant at all?)
- bulb on speedo clock went
-battery fine
-it happened after me fairly giving it some on way home(rushing)
before anyone says it i didn't have kill switch on or out silly (not this time)
any ideas appreciated
CaNsA
PostPosted: 23:49 - 03 Feb 2015    Post subject: Reply with quote
Got fuel?
ikeyfaz23
PostPosted: 23:51 - 03 Feb 2015    Post subject: Reply with quote
CaNsA wrote:
Got fuel?
yeh about 1/3 of a tank at least, defo there
gt125 comet
PostPosted: 23:59 - 03 Feb 2015    Post subject: Reply with quote
Side stand switch
ikeyfaz23
PostPosted: 00:02 - 04 Feb 2015    Post subject: Reply with quote
Paddy. wrote:
Side stand switch
good thought, checked that before i walked it, connected fine
gt125 comet
J.M.
PostPosted: 00:05 - 04 Feb 2015    Post subject: Reply with quote
Checked all the fuses?
2004 R1 & 2018 XSR900
PostPosted: 00:17 - 04 Feb 2015    Post subject: Reply with quote
ikeyfaz23 wrote:
Paddy. wrote:
Side stand switch
Cut the wires going to it and join them. I had intermittent issues with the switch and joining completes the circuit.
moonzoomer
PostPosted: 00:22 - 04 Feb 2015    Post subject: Reply with quote
Is it a chinky?
Commuter_Tim
PostPosted: 00:24 - 04 Feb 2015    Post subject: Reply with quote
Which 125 weighs 180kg? that seems hefty, no? Thinking
I figure it only counts as extra information if you give the basic information first. Whistle
I ride a Bandit 600... badly.
Ed Case
PostPosted: 00:25 - 04 Feb 2015    Post subject: Reply with quote
Checked the handlebar cut-out switch, sly little buggers those ! ?.
ikeyfaz23
PostPosted: 00:31 - 04 Feb 2015    Post subject: Reply with quote
hyosung gt, 650 frame i believe
gt125 comet
ikeyfaz23
PostPosted: 00:33 - 04 Feb 2015    Post subject: Reply with quote
moonzoomer wrote:
Is it a chinky?
hyosung, so korean
gt125 comet
ikeyfaz23
PostPosted: 00:35 - 04 Feb 2015    Post subject: Reply with quote
you mean the kill switch? if so first thing i did was check haha
gt125 comet
moonzoomer
PostPosted: 00:38 - 04 Feb 2015    Post subject: Reply with quote
ikeyfaz23 wrote:
moonzoomer wrote:
Is it a chinky?
hyosung, so korean
as already mentioned check fuses, failing that pull the sparkplugs and clean as they may be fouled due to repeated attempts to start.
iginge
PostPosted: 00:39 - 04 Feb 2015    Post subject: Reply with quote
A "sh*t! bike" doesn't help us much in providing you with the help that you need to get your problem fixed however the model and year of the bike would.. also if it's new or second hand may help.
Follow the wires from the sidestand switch to where it connects and disconnected them, cable tie the loose wires or remove the side stand switch entirely.. if you still want it on then dose it in WD-40 and try to start the bike again (could be wet inside or shorting out).
Side-stand switches cause more problems than they do help, one rain storm or bad weather and problems can be had especially on chinese bikes.
Also please be sure that you haven't drained the battery in your attempts to get it re-started, and make sure that you haven't attempted to start it to many times and flooded it.
Leave the bike sitting and attempt to start in the morning with your usual start up routine that's when you'll know if there was a one of glitch and it was a panic on the roadside that prevented it from getting going again or if the issue is still there.
General rule of thumb I use;
- Don't hold the starter button for more than 5 seconds
- Be careful how many times you attempt a re-start (as with flooding fuel above).
What's your engine oil level at?
Raffles
PostPosted: 00:58 - 04 Feb 2015    Post subject: Reply with quote
Tell that to someone that set off without retracting their sidestand*
*Sidestands didn't always have cut-out switches attached.
iginge
PostPosted: 01:10 - 04 Feb 2015    Post subject: Reply with quote
I've done it once to luckily noticed half way down the road otherwise Shocked
For my bike and me at least i feel better knowing that if there is an electrical fault it's not because of the stand.
ikeyfaz23
PostPosted: 01:33 - 04 Feb 2015    Post subject: Reply with quote
ill have a look in morning, and if i disconect it, will it still start, because i seem to recall wanting to disconect it previously, will i have to remove the whole wire not just disconect?
and its a 56 reg hyosung gt125 comet, v twin, alot of gs500 parts interchange with this bike
oh, and grammer issue of my behalf, i meant "shit, my bike isn't starting" tbh the bikes decent, other than this, reliable
gt125 comet
Just_James
PostPosted: 09:00 - 04 Feb 2015    Post subject: Reply with quote
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
PostPosted: 10:31 - 04 Feb 2015    Post subject: Reply with quote
ikeyfaz23 wrote:
if i disconect [the side stand switch] will it still start
Depends. Some operate on open circuit, some on closed. You'll have to try it both ways.
I'd check the fuse(s) first though, and also get a basic multimeter.
Which reminds me, on what basis are you saying that the battery is "fine"?
Can you name three?
The frame is similar to a GS500, but I wouldn't infer anything from that.
bikenut
PostPosted: 12:14 - 04 Feb 2015    Post subject: non runner Reply with quote
as above!! see the wiring diagram on here for clarity...there is also a manual on here as well........does the ign work?? it has fuel ( you would be surprised how often its a fuel problem, especially with cars!! ) and compression..........?
post the wiring diagram so if you cant read it , someone will be able to help you........
nuts about bikes
pepperami
PostPosted: 14:18 - 04 Feb 2015    Post subject: Reply with quote
As A long time Hyosung owner, I can offer the following.
Side-stand switches can be in place and look in good order but not work.
I know this by experience Crying or Very sad
I disconnected mine and inserted a loop and my bike has been working fine since Thumbs Up
Just my Penny Coin Penny Coin
iginge
PostPosted: 21:20 - 04 Feb 2015    Post subject: Reply with quote
Any updates form the OP?
ikeyfaz23
PostPosted: 21:46 - 04 Feb 2015    Post subject: appy days, i think Reply with quote
disconnected side stand stwich and checked if out were sticking, cleaned it up abit and re connected and it worked fine,
thanks alot for the many reply's , very helpful Thumbs Up
gt125 comet
iginge
PostPosted: 22:25 - 04 Feb 2015    Post subject: Re: appy days, i think Reply with quote
ikeyfaz23 wrote:
cleaned it up abit and re connected and it worked fine.
Good to hear it's fixed, a quick ride within a handful of miles should make clear any issues (if any) that remain as you say though it's in working order so all in good Thumbs Up
If the same thing happens (out of the blue) again it may be worth just attempting to disconnect it on the roadside and see if it will work (to get you home).. might be worth including checking it's cleanliness as part of a regular maintenance check.
Always helpful to have your insurance recovery breakdown number at hand with a bit of spare credit, I've broken down miles away from home and didn't have either.. got home on a limb several miles away, the true weight of the bike soon becomes apparent when it wont start.
The last post was made 11 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 129.4 Kb
