XJ600 (pre-diversion) brake discs compatibility
snodge182
PostPosted: 16:05 - 05 Feb 2015    Post subject: XJ600 (pre-diversion) brake discs compatibility Reply with quote
Hi guys!
Just a quick post asking if anyone knows if any other brake discs from other bikes is compatible with an XJ600 pre-diversion (the bike is a J reg 1991)
It failed its MOT yesterday on a slightly warped front left brake disc and I need to get a replacement one for a very low price.
Thanks!
PostPosted: 17:36 - 05 Feb 2015    Post subject: Reply with quote
Remove warped disc and caliper. MoT sorted.
Don't buy cheap brake discs, don't just replace one.
Fizzer Thou
PostPosted: 21:17 - 05 Feb 2015    Post subject: Reply with quote
Pattern discs are £75 on https://www.wemoto.com/bikes/yamaha/xj_600/91-92/
To double check the disc runout,draw a wavy line on the swept area of the disc using a dark coloured white board marker pen (black works best) then turn the front wheel without applying the brakes.If all of the marker is wiped off,then it may well be that the pistons in the caliper are not moving back into the caliper when the brake lever is released.If some of the marker is removed by the pad removing it,then it will show the highs and lows of the surface of the disc.
Some people say that the disc can be skimmed.But if the thickness of the disc is already on the borderline of the service limit specified in the manual,then it is better to replace them as a pair.This is worth doing if you intend to keep the bike Wink Thumbs Up
Always have a 'Plan B'
Snod Blatter
PostPosted: 11:47 - 06 Feb 2015    Post subject: Reply with quote
https://www.allbikeengineering.co.uk/fitment_guides/fitment_guide_20141101.pdf
Yours looks to be disc 2541, plenty of bikes sharing the same Thumbs Up
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
The last post was made 11 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 40 Kb
