Help needed :( I want to Brat seat my Honda CM125 ?!?!?!
simonizer
PostPosted: 14:51 - 10 Feb 2015    Post subject: Help needed :( I want to Brat seat my Honda CM125 ?!?!?! Reply with quote
I want to Brat seat my Honda CM125 , I really don't like the seats they come with so thought id Brat style it but don't know how, I cant even get the old seat off, can anyone help/advice??
PostPosted: 15:18 - 10 Feb 2015    Post subject: Reply with quote
If it's like the copybikes then the bolts run from the luggage rack through the seat then the mudguard and into the subframe above the wheel. Unbolt both sides, tip up and pull backwards and there you go.
Chances are that a few decades of muck will have accumulated up there so you may have to do a bit of excavation in order to even find the inner fastenings.
You can make your own seat from a bit of plastic or wood, foam and any covering material you want. I used a bit MDF, a cut up cheap closed-cell exercise/camping mat and an offcut of brown leatherette vinyl from eBay, stapled down. Looked OK, worked as a seat. I slotted it in at the front and just held it down with a cable tie at the back.
https://www.diymotorcycleseat.com/ is probably TMI.
simonizer
PostPosted: 15:28 - 10 Feb 2015    Post subject: Reply with quote
Thanks Rogerborg I will go and have a look and another go with your advice the thing is the frame shape to get a flat seat I would have to chop just after the back shocks and I'm guessing this in dangerous without extra support from welding a loop on (I have no welder)
Yes I shall look forward to the 30 years of muck.. its in amzing condition as never left outside but I just don't like the seat shape
PostPosted: 15:48 - 10 Feb 2015    Post subject: Reply with quote
Depends how flat you want it and how long you want the seat. This is my copybike with the subframe left intact. If you do chop it, then you'll need to find another location for the number plate anyway.
I neatened the seat up a bit later, but seat is as seat does.
https://i47.tinypic.com/28asu2d.jpg
Incidentally, a mudguard is a C&U requirement, but I'm well gangsta. Whistle
simonizer
PostPosted: 16:24 - 10 Feb 2015    Post subject: Reply with quote
Ah cool, looks really good , I've just been out and got the seat off fine ...Thanks for that ! it was two long bolts like you said going thro the indicators and seat, I couldn't take the back rail off as the indicators go thro and not sure if I want to keep them or not as new to biking, can they be snipped and re twisted together and maybe some electrical tape over or is that bodge lol
Have you no mudguard on that? I was thinking of trying to chop the standard on down and moving the rear light up
simonizer
PostPosted: 16:26 - 10 Feb 2015    Post subject: Reply with quote
Oh just read the mudguard bit at the bottom haha
pdg
PostPosted: 16:32 - 10 Feb 2015    Post subject: Reply with quote
You have to keep indicators - depending on the year of manufacture (and sometimes design) of the bike.
MOT manual wrote:
need not be fitted to a machine which:
. cannot exceed 30mph / 50kph, or
. was first used before 1 August 1986, or
. 'off road' machines which are designed
to carry only the rider.
. 'off road' machines with side car designed to carry the rider and one passenger in the side car.
off road machines are constructed or adapted primarily for use off roads (whether by reason of its tyres, suspension, ground clearance or otherwise).
That's a bodge.... Get some connectors of some sort.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Northern Monkey
PostPosted: 20:55 - 11 Feb 2015    Post subject: Reply with quote
Snip, slide over some heat shrink, strip the wires back, solder, then shrink the heat shrink
simonizer
PostPosted: 08:08 - 12 Feb 2015    Post subject: Reply with quote
Ok thanks for your help , I think they should have a box connector am checking today , the bike is 85 so just squeezed in tho have decided to keep them , just change them for much smaller ones , thank s again
The last post was made 11 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 63.62 Kb
