| simonizer |
 simonizer Derestricted Danger
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:18 - 10 Feb 2015 Post subject: |
If it's like the copybikes then the bolts run from the luggage rack through the seat then the mudguard and into the subframe above the wheel. Unbolt both sides, tip up and pull backwards and there you go.
Chances are that a few decades of muck will have accumulated up there so you may have to do a bit of excavation in order to even find the inner fastenings.
You can make your own seat from a bit of plastic or wood, foam and any covering material you want. I used a bit MDF, a cut up cheap closed-cell exercise/camping mat and an offcut of brown leatherette vinyl from eBay, stapled down. Looked OK, worked as a seat. I slotted it in at the front and just held it down with a cable tie at the back.
https://www.diymotorcycleseat.com/ is probably TMI. ____________________ Biking is 1/20th as dangerous as horse riding.
| simonizer |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:48 - 10 Feb 2015 Post subject: |
Depends how flat you want it and how long you want the seat. This is my copybike with the subframe left intact. If you do chop it, then you'll need to find another location for the number plate anyway.
I neatened the seat up a bit later, but seat is as seat does.
https://i47.tinypic.com/28asu2d.jpg
Incidentally, a mudguard is a C&U requirement, but I'm well gangsta.  ____________________ Biking is 1/20th as dangerous as horse riding.
| simonizer |
| simonizer |
| pdg |
 pdg World Chat Champion
| Northern Monkey |
 Northern Monkey World Chat Champion
| simonizer |
The last post was made 11 years, 250 days ago. Instead of replying here, would creating a new thread be more useful? |
