Yamaha AEROX water problem
carl1997
PostPosted: 23:13 - 09 Feb 2015    Post subject: Yamaha AEROX water problem Reply with quote
Hi, earlier I checked my coolant on my aerox 2008 50cc it was dry I topped it up to the max mark started it up revved it to make sure it was returning as usual it was but the water coming through the return pipe is s black colour does anyone have any ideas what this could be?
Thanks in advance [/code][/list]
CE
SQL
PostPosted: 23:57 - 09 Feb 2015    Post subject: Reply with quote
Dirty water?
Taught2BCauti...
PostPosted: 11:05 - 10 Feb 2015    Post subject: Reply with quote
Sounds like someone has put just water in the cooling system, and as you would expect, it has started rotting the engine away from the inside.
Flush it through with clean water until all the black stuff has gone, then drain and refill with the recommended mixture of anti-freeze, and hope you caught it in time.
Keep some of the mixture to one side, and only use this for topping-up when needed.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Iain.
PostPosted: 13:00 - 10 Feb 2015    Post subject: Reply with quote
My moneys on head gasket/cracked cylinder.
Two stroke oil is black when it's been through the engine and set on fire and all sorts. When my CR head gasket failed, there was black sludge dripping down the side of the cylinder.
Is there any excessive white smoking, power loss or overheating?
evoboy
PostPosted: 20:05 - 10 Feb 2015    Post subject: Reply with quote
This.
Dirty water, really?
Itll be a dead headgasket.
APT Motorcycles
The last post was made 11 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 3.82 - MySQL Queries: 13 - Page Size: 43.71 Kb
