After some basic work....Time to tackle something harder
Simba76
PostPosted: 10:08 - 12 Feb 2015    Post subject: After some basic work....Time to tackle something harder Reply with quote
Basics so far;
I've managed to fit a new front brake lever, heated grips, adjusted the chain (So far so good) and Replaced the innertube on the front wheel after the last owner put a rear tube into the front wheel Shocked .
But now from the sounds of the bike and reading through loads of threads on here, it looks like I'm going to have to clean the carb.
Easy? Pitfalls to look out for? Essentials I will need?
I've got a haynes manual, loads of tools, a dry indoor space to work with and a clapped out Gn125.
Cheers Chaps and Chapesses.
If you can keep your head while all around are loosing theirs....you're probably in some sort of Zombie movie!
-Current bike ......
PostPosted: 10:17 - 12 Feb 2015    Post subject: Reply with quote
A rear tube? Its a tube... I don't think it matters if its front or back.
Carb, get the right screwdriver, take pictures, do it over a bowl so any loose bits fall in there.
DrSnoosnoo
PostPosted: 10:49 - 12 Feb 2015    Post subject: Reply with quote
Are the rims different diameters? Could that affect the choice of intardtube?
PostPosted: 11:15 - 12 Feb 2015    Post subject: Reply with quote
I have a 2.75 tube in a 2.50 tyre and a 3.00 tube in a 2.75 tyre... seems fine Laughing
Simba76
PostPosted: 12:22 - 12 Feb 2015    Post subject: Reply with quote
It was a 3.50 in a 2.75.
It was folder over in two places and causing a wheel wobble.
wr6133
PostPosted: 13:47 - 12 Feb 2015    Post subject: Re: After some basic work....Time to tackle something harder Reply with quote
Easy, easier than levering the tyre on and off which you've done successfully. It's one of those jobs people worry about because there are so many stories of clowns that did it half arsed, messed with the settings and then ended up with a potato running bike.
Do it after you finish work tonight, you'll be posting a "much success" before you go to bed.
PostPosted: 14:09 - 12 Feb 2015    Post subject: Reply with quote
Well damn Laughing
The last post was made 11 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.68 Sec - Server Load: 4.54 - MySQL Queries: 13 - Page Size: 57.5 Kb
