Safest helmets, EC and DOT certified
charliefirpo
PostPosted: 23:17 - 14 Feb 2015    Post subject: Safest helmets, EC and DOT certified Reply with quote
Hi,
I am getting a bike soon and I need a helmet.
The way I approached this is that I looked at the SHARP test page and went for the best ones I want to afford: up to £300
A few things would be ideal:
internal sun visor
I have been tool that a sun visor makes the helmet more expensive and less save because there is less space for padding.
Should I not consider this option if safety is my highest priority? Or is the difference not such a huge deal?
DOT certification
I have been told that it will be very difficult to find a helmet with both EC and DOT certification. Is that true? Should I forget about a dual certification? (I will be moving to North America within the life span of a helmet I am about to buy).
About the SHARP test:
I have been told at a shop that the SHARP test doesn't actually mean shit because some manufacturers build their helmets just for the test and reinforce them in the areas that get tested. Is that true? I figure the people at the shop who told me that said that to me so that I buy their in stock helmets which were either not tested or not rated with a perfect score as the ones I asked about.
Generally there are many helmets that I would like and that fit me but some of them are either not rated at all or not rated highly by SHARP. Would that deter you guys?
I kinda feel I'm making buying a helmet a really big complicated process with a lot of research which it might not have to be. Should I not worry too much get what I like (feature wise), what fits and feels high quality?
So far I found that the Schubert S2 fits me best. Is that a good helmet? It's actually expensive for my taste (£350) but it feels good. I was told by a shop that this one still has the proper amount of padding even though it has the internal sun visor. Schubert created the fore head area on the helmet so that it is bigger to accommodate for the visor which pretty much none other manufacturers do.
(Btw I need to find a helmet until the end of next week)
mentalboy
PostPosted: 00:11 - 15 Feb 2015    Post subject: Reply with quote
The shop said helmet manufacturers designed helmets just to fit the SHARP testing regime - possibly but it might be better for a cheapo manufacturer to make you a helmet that will protect your head in an accident rather than having them skimp on safety and build in stuff like great soundproofing.
The more you spend the better the all round features but don't just ignore SHARP because a shop monkey wants to sell you a fancy pink lid that'll split when you slide down the road.
Look at SHARP, compare the kind of models you're interested in and are within budget and go for those. It is a bit of a ballache navigating the SHARP site though!
I think inbuilt sun-visor models are only found in the cheapo models and don't recall ever checking their safety rating but seem to recall hearing that they don't factor very well
Make mine a Corona.
PostPosted: 00:12 - 15 Feb 2015    Post subject: Reply with quote
It's difficult to choose a particular helmet without wearing it first. When I say wear it, I mean put it on... go wander the shop for 5 mins.
General rule is you shouldn't be able to poke a finger between helmet and forehead.
See if you can tilt it backways and frontway<<sorry about that off your head. Cheeks should look slightly hamster(ish). No pressure points.
Do the air vents feel solid or are they flimsy?
Has it an ACU sticker(for use on tracks). My Schuberth R1 (with sunvisor) didn't.
Has it a removable lining? They can get sweaty at times.
Does it have a pinlock system?
Then...What is it's rating. Wink
mentalboy
PostPosted: 00:18 - 15 Feb 2015    Post subject: Reply with quote
...and just make sure it's a little tighter than comfy as the lining will compact fairly quickly and loosen the fit
Make mine a Corona.
charliefirpo
PostPosted: 00:39 - 15 Feb 2015    Post subject: Reply with quote
OK, thank you guys, so I will not ignore the SHARP test and go for one with a good rating (+ of course a good fit)
Now the most important thing for me is: Are there helmets with DOT and ECE certification? This is really what will decide about the helmet because from what I can tell there are only a hand full of helmets on the market which actually serve both standards. Is that even possible or did I read that wrong? It will be a lot easier to just find a good ECE helmet because there simple are way more available.
Andy_Pagin
PostPosted: 01:40 - 15 Feb 2015    Post subject: Reply with quote
The safest helmet is the one that's most comfortable and the best fit. Ie. the one that's least likely to impinge on you're riding safely.
lukamon
PostPosted: 02:16 - 15 Feb 2015    Post subject: Reply with quote
as far as I understand it, there is a certain logic to ignoring the sharp tests.
(one of the ) tests SHARP performs is a double impact on a helmet in the same spot. the lining (polesyer padding, not cloth interior lining) must not be completely deformed (therefore using up all its protective qualities ) by the first impact.
so, some people argue this means more shock is transmitted to your head than in a non- sharp approved helmet, where the lining may be squashed entirely by one impact, lessening the blow to your head. of course then IF you get whacked again in the same spot, its gonna be worse for you.
basically,
https://www.bestmoviesbyfarr.com/static-assets/images/articles/background/2014/05/2-1itkyn3.gif
personally, I think if I have a crash bad enough to deliver two potentially fatal head impacts in the same spot, youll probably be dead from something else anyway. Thumbs Up
killa wrote: Im an ass man myself
PostPosted: 03:12 - 15 Feb 2015    Post subject: Reply with quote
Fit is more important than the SHARP rating.
You'll only know if a lid is a good fit by trying on lots of other lids. You can order a lid online, try it on when it arrives and be thinking 'yeah this fits good' but given the number of lid on the market to choose from, it would be very lucky if the one you picked from the picture on some website turns out to be the one which really does fit you best.
A £50 cheapo lid from Lidl that fits you well will protect you better in a crash than the latest and greatest, most expensive, highest SHARP rated lid with go faster stripes on it.
Go to a bike shop and try lots of lids on.
mentalboy
PostPosted: 04:21 - 15 Feb 2015    Post subject: Reply with quote
This article might help clear up a few misconceptions you may have about the two standards (and interestingly enough, how SHARP is factored in as well)
Make mine a Corona.
PostPosted: 08:21 - 15 Feb 2015    Post subject: Reply with quote
This is how I would see it too mostly. Importance for me:
1. Fit. I'd rather stick my head into a 1 star helmet that fits correctly than a 5 star that doesnt.
2. Sun Visor (I love these things but make sure they are tinted well enough. HJC is pants for tint)
3. Pinlock. Best helmet invention since breathing.
4. Removable lining, as above. They get rather stinky.
5. Star rating.
To be road legal you only have to have ECE22.05 rated helmets. DOT is American (I think) and the ACU Sticker HT mentions is race legal. The race legal ones have gone through even more tests than the ECE rated ones.
wr6133
PostPosted: 10:17 - 15 Feb 2015    Post subject: Reply with quote
Most things that are ECE are also DOT and vice versa. Manufacturers often only label them up for the market they will be sold in. You can see it on US store webpages, helmets that are sold here as ECE are sold there as DOT often with no mention made of the other.
PostPosted: 13:03 - 15 Feb 2015    Post subject: Re: Safest helmets, EC and DOT certified Reply with quote
How fortunate that you went to a shop staffed by people who had left so many helmet manufacturers in disgust after seeing their shady practices first hand. Rolling Eyes
No, here's the "truth" (my opinion being as valid as theirs). Some of the most expensive helmets do poorly in side impact tests because in their experience there aren't a lot of side impacts on the race track.
Also, carbon fibre shells are light, and do relatively well in very heavy impacts - relatively in the sense that you'll still be dead, but not as dead. The cheaper thermoplastic shells actually protect you better in survivable impacts.
It did for my first lid, but I'm a bit more blasé now. They should all be BSI or ECE 22.05 rated, and the different between 3 and 5 SHARP stars is minimal. You'll have to hit at just the right (or wrong) angle and speed and location for it to be potato or non-potato.
I'd say so. Fit and comfort, then features, then price. Heck, I ride in a 3 star flip-front with a sun visor that the doomsayers will be delighted to tell you will break my neck, pulp my brain stem and then disintegrate faster than a politician's promise. Whistle
Fibreglass, so middle of the road in tech, piss poor side impact as noted above, but again that's relative. If it's the best fit, have it.
There's apparently a DOT version that weighs slightly more, but do you reckon you'll find a copper who will know that or give a stuff?
mentalboy
PostPosted: 13:18 - 15 Feb 2015    Post subject: Reply with quote
Aah, so this bloke I quoted earlier is absolutely full of shit?...
https://www.webbikeworld.com/eicma-2010/nolan-helmets/dot-vs-ece-helmet-safety-standards.htm
Make mine a Corona.
wr6133
PostPosted: 19:00 - 15 Feb 2015    Post subject: Reply with quote
I skim read that he is talking about the differences in the standards? Maybe I was unclear earlier the standards may be different but helmets can pass both standards (I currently have a lid labelled both ECE and DOT), some confusion occurs because some manufacturers label their lids for the market they are going to be sold in so you may find a lid in Europe labelled as ECE and then find the exact same lid in the US labelled as DOT.
SQL
PostPosted: 00:34 - 16 Feb 2015    Post subject: Reply with quote
https://www.ebay.co.uk/itm/DOT-helmet-sticker-regulation-decal-/180874565587?pt=LH_DefaultDomain_0&hash=item2a1cf6d7d3
talkToTheHat
PostPosted: 01:16 - 16 Feb 2015    Post subject: Reply with quote
Fit is everything, a lid is no use if it comes off and is dangerous moves so as to interfere with concentration or vision. Don't wear a lid that doesn't fit.
A sunvisor must block enough sun without impacting face - shark 900 visor smacks me in the nose, speed r is ok if a little high at the sides.
Pinlocks are great unless you're carrying a pinlocked clear visor in a visor bag around your waist because no sunvisor. Fit of pinlock to visor can be compromised. Great on helmets with sunvisors. Especially the newer maxvision style which is fits really well.
A removable liner and anti-odor technology is important. A lot of time is spent with your head stuffed into a lid. Consider helmets with permanent liners an expensive toy.
Then start considering sharp score.
Also consider performance of vents, are they easily operated with a gloved hand? How well do they work, are they strong enough to survive several years use, or are they flimsy as hell. I'd argue the vent that falls off on the slightest impact is safer than a big external mechanism until the former falls apart.
Bandit. does. everything.
stigger
PostPosted: 04:04 - 16 Feb 2015    Post subject: Reply with quote
You need to remember that the DOT testing is "Self-compliance"
Which means that the manufacturers to the testing and tell you that they passed.
So it's worthless.
mentalboy
PostPosted: 04:42 - 16 Feb 2015    Post subject: Reply with quote
So it's worthless.
Not quite, although if the helmet model is found to be short of DOT standards that doesn't little Johnny much good if he's already bounced down the road!!!
from the article I posted earlier was wrote:
...from the NHTSA page entitled "Importation and Certification FAQs", Section 9, comes this statement: "NHTSA enforces the standard by randomly selecting and purchasing motorcycle helmets from the marketplace and testing to the requirements of the standard at independent test labs".
For example, in 2006, after re-testing an unknown number of helmet brands and types, 13 formal performance investigations were initiated and ended with 7 recalls covering 42,125 helmets (From "Counterfeit and Noncompliant Safety Equipment - Motorcycle Helmets (.pdf)).
Make mine a Corona.
PostPosted: 09:24 - 16 Feb 2015    Post subject: Reply with quote
A question that I've oft pondered is: who enforces helmet markings?
Quite aside from the issue of manufacturers submitting one lot of lids for ECE or BSI testing and then producing quite another, what's to stop Whang Dong Industrial Plastic Sundries Co. from just slapping ECE 22.05P or BSI whatevs stickers on some novelty toys, and selling 10,000 of them to a European distributor?
How would I as a buyer verify that any similar lid has been tested by the claimed standards body. Say, E13 (Luxembourg). Can you find a way?
One of the big deals about SHARP is that tests are run on lids bought at retail, not provided by the manufacturer.
talkToTheHat
PostPosted: 11:25 - 16 Feb 2015    Post subject: Reply with quote
So much this ^^^^
The last post was made 11 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.43 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 121.9 Kb
