| charliefirpo |
 charliefirpo Renault 5 Driver
| mentalboy |
 mentalboy World Chat Champion
| Howling TerrorOutOfOffice |
 Posted: 00:12 - 15 Feb 2015 Post subject: |
It's difficult to choose a particular helmet without wearing it first. When I say wear it, I mean put it on... go wander the shop for 5 mins.
General rule is you shouldn't be able to poke a finger between helmet and forehead.
See if you can tilt it backways and frontway<<sorry about that off your head. Cheeks should look slightly hamster(ish). No pressure points.
Do the air vents feel solid or are they flimsy?
Has it an ACU sticker(for use on tracks). My Schuberth R1 (with sunvisor) didn't.
Has it a removable lining? They can get sweaty at times.
Does it have a pinlock system?
Then...What is it's rating.  ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| mentalboy |
 Posted: 00:18 - 15 Feb 2015 Post subject: |
| HT wrote: | It's difficult to choose a particular helmet without wearing it first. When I say wear it, I mean put it on... go wander the shop for 5 mins.
See if you can tilt it backways and frontway <<sorry about that off your head. Cheeks should look slightly hamster(ish). No pressure points.
Then...What is it's rating.  |
...and just make sure it's a little tighter than comfy as the lining will compact fairly quickly and loosen the fit ____________________ Make mine a Corona. |
| charliefirpo |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| lukamon |
 lukamon World Chat Champion
 Posted: 02:16 - 15 Feb 2015 Post subject: |
| charliefirpo wrote: | OK, thank you guys, so I will not ignore the SHARP test and go for one with a good rating (+ of course a good fit)
Now the most important thing for me is: Are there helmets with DOT and ECE certification? This is really what will decide about the helmet because from what I can tell there are only a hand full of helmets on the market which actually serve both standards. Is that even possible or did I read that wrong? It will be a lot easier to just find a good ECE helmet because there simple are way more available. |
as far as I understand it, there is a certain logic to ignoring the sharp tests.
(one of the ) tests SHARP performs is a double impact on a helmet in the same spot. the lining (polesyer padding, not cloth interior lining) must not be completely deformed (therefore using up all its protective qualities ) by the first impact.
so, some people argue this means more shock is transmitted to your head than in a non- sharp approved helmet, where the lining may be squashed entirely by one impact, lessening the blow to your head. of course then IF you get whacked again in the same spot, its gonna be worse for you.
basically,
https://www.bestmoviesbyfarr.com/static-assets/images/articles/background/2014/05/2-1itkyn3.gif
personally, I think if I have a crash bad enough to deliver two potentially fatal head impacts in the same spot, youll probably be dead from something else anyway.  ____________________ killa wrote: Im an ass man myself |
| Ste |
 Ste Not Work Safe
| mentalboy |
| pinkyfloyd |
 pinkyfloyd Super Spammer
 Posted: 08:21 - 15 Feb 2015 Post subject: |
This is how I would see it too mostly. Importance for me:
1. Fit. I'd rather stick my head into a 1 star helmet that fits correctly than a 5 star that doesnt.
2. Sun Visor (I love these things but make sure they are tinted well enough. HJC is pants for tint)
3. Pinlock. Best helmet invention since breathing.
4. Removable lining, as above. They get rather stinky.
5. Star rating.
To be road legal you only have to have ECE22.05 rated helmets. DOT is American (I think) and the ACU Sticker HT mentions is race legal. The race legal ones have gone through even more tests than the ECE rated ones. ____________________ illuminateTHEmind wrote: I am just more evolved than most of you guys... this allows me to pick of things quickly which would have normally taken the common man years to master
Teflon-Mike:I think I agree with just about all Pinky has said. |
| wr6133 |
 wr6133 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:03 - 15 Feb 2015 Post subject: Re: Safest helmets, EC and DOT certified |
| charliefirpo wrote: | I have been told at a shop that the SHARP test doesn't actually mean shit because some manufacturers build their helmets just for the test and reinforce them in the areas that get tested. |
How fortunate that you went to a shop staffed by people who had left so many helmet manufacturers in disgust after seeing their shady practices first hand.
No, here's the "truth" (my opinion being as valid as theirs). Some of the most expensive helmets do poorly in side impact tests because in their experience there aren't a lot of side impacts on the race track.
Also, carbon fibre shells are light, and do relatively well in very heavy impacts - relatively in the sense that you'll still be dead, but not as dead. The cheaper thermoplastic shells actually protect you better in survivable impacts.
| charliefirpo wrote: | Generally there are many helmets that I would like and that fit me but some of them are either not rated at all or not rated highly by SHARP. Would that deter you guys? |
It did for my first lid, but I'm a bit more blasé now. They should all be BSI or ECE 22.05 rated, and the different between 3 and 5 SHARP stars is minimal. You'll have to hit at just the right (or wrong) angle and speed and location for it to be potato or non-potato.
| charliefirpo wrote: | I kinda feel I'm making buying a helmet a really big complicated process with a lot of research which it might not have to be. Should I not worry too much get what I like (feature wise), what fits and feels high quality? |
I'd say so. Fit and comfort, then features, then price. Heck, I ride in a 3 star flip-front with a sun visor that the doomsayers will be delighted to tell you will break my neck, pulp my brain stem and then disintegrate faster than a politician's promise.
| charliefirpo wrote: | So far I found that the Schubert S2 fits me best. Is that a good helmet? |
Fibreglass, so middle of the road in tech, piss poor side impact as noted above, but again that's relative. If it's the best fit, have it.
There's apparently a DOT version that weighs slightly more, but do you reckon you'll find a copper who will know that or give a stuff? ____________________ Biking is 1/20th as dangerous as horse riding.
| mentalboy |
| wr6133 |
 Posted: 19:00 - 15 Feb 2015 Post subject: |
I skim read that he is talking about the differences in the standards? Maybe I was unclear earlier the standards may be different but helmets can pass both standards (I currently have a lid labelled both ECE and DOT), some confusion occurs because some manufacturers label their lids for the market they are going to be sold in so you may find a lid in Europe labelled as ECE and then find the exact same lid in the US labelled as DOT. |
| SQL |
 SQL World Chat Champion
 Posted: 00:34 - 16 Feb 2015 Post subject: |
| talkToTheHat |
| stigger |
 stigger Crazy Courier
| mentalboy |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:24 - 16 Feb 2015 Post subject: |
A question that I've oft pondered is: who enforces helmet markings?
Quite aside from the issue of manufacturers submitting one lot of lids for ECE or BSI testing and then producing quite another, what's to stop Whang Dong Industrial Plastic Sundries Co. from just slapping ECE 22.05P or BSI whatevs stickers on some novelty toys, and selling 10,000 of them to a European distributor?
How would I as a buyer verify that any similar lid has been tested by the claimed standards body. Say, E13 (Luxembourg). Can you find a way?
One of the big deals about SHARP is that tests are run on lids bought at retail, not provided by the manufacturer. ____________________ Biking is 1/20th as dangerous as horse riding.
| talkToTheHat |
The last post was made 11 years, 246 days ago. Instead of replying here, would creating a new thread be more useful? |
