Replaced cam chain tensioner - fixed! (Honda CBR)
Jefr0
PostPosted: 23:00 - 15 Feb 2015    Post subject: Replaced cam chain tensioner - fixed! (Honda CBR) Reply with quote
Hi all
(Honda CBR 600 FM 1991)
So I've been having a bit of a rattling on the bike and decided to replace the Cam chain tensioner with another OEM CCT.
The bike has done 62k miles, every day riding, on the original CCT.
I replaced it, as per the Haynes manual and was a easy job.
The bike was still rattling after this which has eliminated the problem was the CCT, the original one is also fine and not damaged in any way.
Valve clearances I did at 50k miles and all was in tolerance (never been adjusted in it's life)
Now I'm thinking that it's the actual Cam Chain. I'm thinking it could have stretched and is past it's best.
Has anyone had any experience of this? Replacing a cam chain?
Reading in the Haynes, it's a long winded job, which will involve replacing the cam chain along with the sprockets.
I'm hoping that will cure the problem, but before I take on a big job like this, is there any other recommendations?
Thanks
Jeff
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
Jefr0
PostPosted: 23:05 - 15 Feb 2015    Post subject: Reply with quote
I had hunted on BCF and google before posting but nothing so much on replacing the cam chain.
But this has thrown a spanner in the works from Robby...exhaust header gaskets?
Robby wrote:
A worn CCT tends to show up as a rattle at idle, a touch more pronounced when the engine is cold but there all the time.
If the noise is a metallic tick, then exhaust gaskets are a possibility. You would expect them to sound more like air escaping, but in reality they tick a bit like a hot bike cooling down after a hard ride, just constantly.
Valave clearance way open would also be a possibility, but they go gradually.
Get your ear over to the exhaust headers with the bike idling when cold and see if you can hear the exhaust gasket going.
Also, a worn CCT is a fairly rare thing in modern engines. The only one I can think of that was fairly well known for it was the 90s CBR6, and I think the hornet had moved on from this engine by 2006. CCTs giving up was a fairly common problem in the 70s and 80s, but mostly fixed by the 90s. There's no good reason for one to give up, nor for a cam chain to stretch so much that the adjuster runs out of adjustment, it should take over 100k for a camchain to wear that much.
Check the exhaust gaskets, if you can still hear it then give it a really good oil change (engine very hot, drain for a long time, alter the angle of the bike a bit while it drains, maybe even turn it over once using the crank end bolt while draining to help expel any last old oil). Avoid engine flushing things, the oil contains enough detergent to clean up the engine.
If you do change the gaskets, a few tips:
1. Give the old studs a good soaking in proper penetrating oil for a few days before attempting the job.
2. When you take the old gaskets out, clean up the area they sit in. There will be some crap around the area that they sit in to scrape out, and around the area on the front of the head that they bolt to.
3. Get new studs before attempting the job, mild steel, not stainless. They don't need to be genuine Honda, I buy cheap car ones off ebay. Tends to be about a tenner for a set.
4. Reassemble with brass nuts. This is the most important bit. Brass nuts won't rust in place, nor will they put enough torque onto an old rusted stud to snap it on disassembly.
5. A bit of general purpose grease on the gaskets helps them stay in place while you manoeuvre the exhaust into position.
PostPosted: 23:14 - 15 Feb 2015    Post subject: Reply with quote
Quite possible.
My quick test is talc, turn engine on and give the talcum powder a few huffs near the exhaust. Watch for it blowing away from one header, possibly more. If it does, defo a leak Thumbs Up
Jefr0
PostPosted: 14:38 - 18 Feb 2015    Post subject: Reply with quote
It wasn't the exhaust. Took to a bike shop just to get their opinion and they said cam chain.
So I looked through the Haynes procdure and what might need replacing.
If I do the cam chain which isn't bad at £42, I could be looking at replacing the sprockets...guides and then theres' the gaskets.
I got a quote from david silver for the parts Pale
Cam chain £35
Sprockets x2 at £46 each
Lower sprocket £39
Guide blades at £48 & £47
Gasket £5
Rocker cover gasket £36
£302 before VAT, £362.40 with VAT.
Has anyone replaced JUST the cam chain and it's been ok? Or maybe replaced one or two of the guides or has it been sprockets as well?
I was going to strip down Saturday, see what's worn, but it's looking expensive Sad
Nipedley
PostPosted: 15:24 - 18 Feb 2015    Post subject: Reply with quote
I had the exact same problem with my 1988 FH, I think the engine in yours was a development of mine?
I had a serious rattle going on (worse when warm, for whatever reason) and got a replacement original CCT which made absolutely no difference. It was clear from the original CCT how far into the engine it was extending which was nowhere near out of adjustment of the cam chain or the tensioner (and the engine was only on 40k), I got a manual CCT from APE, easy enough to fit and the rattle is gone, both cold and warm, sounds great.
Perhaps you can see from your original CCT how far it is extending, if it is out of adjustment or still within adjustment?
They are also much longer than the original CCT, so even if your cam chain was out of the OEM CCT's adjustment spec it could still be tensioned (but obviously this would murder several kittens and I'd only do it if the engine was otherwise junk)
CBR600 (1988) | GS500 (1989)
Scootaloo
PostPosted: 16:10 - 18 Feb 2015    Post subject: Reply with quote
How good of a condition is the rest of the bike?
If the rest of the bike is mint, find out how much a newer engine is on Flee Bay. I would be tempted to leave it as it is and just wait for it to blow then fit new Engine.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
fatjames
PostPosted: 16:25 - 18 Feb 2015    Post subject: Reply with quote
Same. I had a rattle from cold that got quieter as the engine warmed up. Chucked an APE in the motor and the noise went away completely.
They're very easy to fit and cost about £40 on ebay.
Jefr0
PostPosted: 12:43 - 01 Apr 2015    Post subject: Reply with quote
So after all of the above, I stripped it down as a new cam chain tensioner didn't fix the problem.
Turns out the cam chain was worn, along with all 3 guides and 2 of the 3 sprockets.
Was a big job but I managed to replace the cam chain, 2x cam sprockets, 3 guides. Not a job for the faint hearted!
Biggest job done by far and I enjoyed doing it, now done about 500 miles or so trouble free and no rattle Very Happy
cb1rocket
PostPosted: 14:06 - 01 Apr 2015    Post subject: Reply with quote
like the good news, shame you didnt take any pictures!
Jefr0
PostPosted: 15:22 - 01 Apr 2015    Post subject: Reply with quote
I did Razz I'll see about uploading some. It wouldn't be a step by step guide that's for sure, way too long. Haynes did me well.
Pigeon
PostPosted: 20:27 - 01 Apr 2015    Post subject: Reply with quote
Congrats dude! Mega job!!
How did you know the guides were worn?
cb1rocket
PostPosted: 11:39 - 03 Apr 2015    Post subject: Reply with quote
ooooooh pictures plz!!! this thread is worthless without pics Wink
There is a gap of 241 days between these two posts...
Jefr0
PostPosted: 18:57 - 30 Nov 2015    Post subject: Reply with quote
Just realised I never actually replied on this thread! The guides are a mix of plastic and metal and the plastic had worn away quite a bit and split in a couple places.
This whole job was done with a Haynes manual but I wrote it down into easy steps as there's a lot in the Haynes.
It takes a lot of time and patience and working in small places can be frustrating!
Here's some pics, my list:
https://i.imgur.com/2ZgHMDKl.jpg
One cam removed, both upper cam chain sprockets removed, cam chain hanging in place:
https://i.imgur.com/jgYgjaYl.jpg
Guides removed, cam chain being removed after lower sprocket removed:
https://i.imgur.com/aaWLoLEl.jpg
New parts from Honda waiting to go in:
https://i.imgur.com/OA5gDPdl.jpg
New guides and cam chain in place:
https://i.imgur.com/G4EtYkCl.jpg
Ariel Badger
PostPosted: 19:22 - 30 Nov 2015    Post subject: Reply with quote
What does the big dished washer with the tabs at the bottom of the chain do?
Edit. it throws oil I think.
Burnzy1989
PostPosted: 19:38 - 30 Nov 2015    Post subject: Reply with quote
Looks easer than mine iv got to completely strip the engine and the cam chain is the last thing to come out of it lol. 1990 honda cbr 600 fl
PostPosted: 22:52 - 30 Nov 2015    Post subject: Reply with quote
It's a trigger wheel for the electronic ignition Wal.
Ariel Badger
PostPosted: 23:33 - 30 Nov 2015    Post subject: Reply with quote
Cheers Pete Very Happy
mysterious_rider
PostPosted: 08:13 - 01 Dec 2015    Post subject: Reply with quote
How can you tell wear on sprockets? I have the 94 cb1000 and mine rattled loads too. New chain alone wouldnt fix? Ive inspected the sprockets and they look good. On 60k.
KAWASAKIIIII
Jefr0
PostPosted: 11:17 - 07 Dec 2015    Post subject: Reply with quote
The sprockets looked like they had lost a bit of their size on the sides of each tooth rather than the top which was fine. They didn't sit in the chain quite right, had a bit of play compared to the new sprockets.
You may get away with not replacing the sprockets, 2 of 3 needed replacing on mine.
But if they are worn and a new chain goes on then it may wear the chain more (I'm sure you know this anyway)
For the amount of stripping down and messing about I wouldn't want to do it again too soon for not replacing the sprockets.
The last post was made 10 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 106.46 Kb
