| Jefr0 |
 Jefr0 World Chat Champion
| Jefr0 |
 Posted: 23:05 - 15 Feb 2015 Post subject: |
I had hunted on BCF and google before posting but nothing so much on replacing the cam chain.
But this has thrown a spanner in the works from Robby...exhaust header gaskets?
| Robby wrote: | A worn CCT tends to show up as a rattle at idle, a touch more pronounced when the engine is cold but there all the time.
If the noise is a metallic tick, then exhaust gaskets are a possibility. You would expect them to sound more like air escaping, but in reality they tick a bit like a hot bike cooling down after a hard ride, just constantly.
Valave clearance way open would also be a possibility, but they go gradually.
Get your ear over to the exhaust headers with the bike idling when cold and see if you can hear the exhaust gasket going.
Also, a worn CCT is a fairly rare thing in modern engines. The only one I can think of that was fairly well known for it was the 90s CBR6, and I think the hornet had moved on from this engine by 2006. CCTs giving up was a fairly common problem in the 70s and 80s, but mostly fixed by the 90s. There's no good reason for one to give up, nor for a cam chain to stretch so much that the adjuster runs out of adjustment, it should take over 100k for a camchain to wear that much.
Check the exhaust gaskets, if you can still hear it then give it a really good oil change (engine very hot, drain for a long time, alter the angle of the bike a bit while it drains, maybe even turn it over once using the crank end bolt while draining to help expel any last old oil). Avoid engine flushing things, the oil contains enough detergent to clean up the engine.
If you do change the gaskets, a few tips:
1. Give the old studs a good soaking in proper penetrating oil for a few days before attempting the job.
2. When you take the old gaskets out, clean up the area they sit in. There will be some crap around the area that they sit in to scrape out, and around the area on the front of the head that they bolt to.
3. Get new studs before attempting the job, mild steel, not stainless. They don't need to be genuine Honda, I buy cheap car ones off ebay. Tends to be about a tenner for a set.
4. Reassemble with brass nuts. This is the most important bit. Brass nuts won't rust in place, nor will they put enough torque onto an old rusted stud to snap it on disassembly.
5. A bit of general purpose grease on the gaskets helps them stay in place while you manoeuvre the exhaust into position. |
____________________ Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95) |
| P.addy |
 P.addy Red Rocket
 Posted: 23:14 - 15 Feb 2015 Post subject: |
Quite possible.
My quick test is talc, turn engine on and give the talcum powder a few huffs near the exhaust. Watch for it blowing away from one header, possibly more. If it does, defo a leak  |
| Jefr0 |
 Posted: 14:38 - 18 Feb 2015 Post subject: |
It wasn't the exhaust. Took to a bike shop just to get their opinion and they said cam chain.
So I looked through the Haynes procdure and what might need replacing.
If I do the cam chain which isn't bad at £42, I could be looking at replacing the sprockets...guides and then theres' the gaskets.
I got a quote from david silver for the parts
Cam chain £35
Sprockets x2 at £46 each
Lower sprocket £39
Guide blades at £48 & £47
Gasket £5
Rocker cover gasket £36
£302 before VAT, £362.40 with VAT.
Has anyone replaced JUST the cam chain and it's been ok? Or maybe replaced one or two of the guides or has it been sprockets as well?
I was going to strip down Saturday, see what's worn, but it's looking expensive  ____________________ Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95) |
| Nipedley |
 Nipedley Scooby Slapper
| Scootaloo |
 Scootaloo Could Be A Chat Bot
| fatjames |
 fatjames World Chat Champion
| Jefr0 |
 Posted: 12:43 - 01 Apr 2015 Post subject: |
So after all of the above, I stripped it down as a new cam chain tensioner didn't fix the problem.
Turns out the cam chain was worn, along with all 3 guides and 2 of the 3 sprockets.
Was a big job but I managed to replace the cam chain, 2x cam sprockets, 3 guides. Not a job for the faint hearted!
Biggest job done by far and I enjoyed doing it, now done about 500 miles or so trouble free and no rattle  ____________________ Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95) |
| cb1rocket |
 cb1rocket World Chat Champion
| Jefr0 |
| Pigeon |
 Pigeon World Chat Champion
| cb1rocket |
There is a gap of 241 days between these two posts... |
| Jefr0 |
| Ariel Badger |
 Ariel Badger Super Spammer
| Burnzy1989 |
 Burnzy1989 Nitrous Nuisance
| Ariel Badger |
 Posted: 23:33 - 30 Nov 2015 Post subject: |
Cheers Pete  ____________________ Bikers make great organ donors, get 115 on your licence today. |
| mysterious_rider |
 mysterious_rider World Chat Champion
| Jefr0 |
The last post was made 10 years, 285 days ago. Instead of replying here, would creating a new thread be more useful? |
