Author |
27yo kid |
27yo kid Renault 5 Driver
Back to top |
Fire_Eyes |
Fire_Eyes Crazy Courier
Posted: 07:23 - 09 Oct 2004 Post subject: |
honda have a 2005 nsr50 looks very sporty its made for us youngsters that wanna learn how to knee down but its not allowed on the streets so i dont know anyone feeling risky ...guess not lol |
Back to top |
G |
G The Voice of Reason
Back to top |
Spiral |
Spiral Traffic Copper
Back to top |
Marc_Buck |
Marc_Buck Could Be A Chat Bot
Back to top |
Spiral |
Back to top |
Ste |
Ste Not Work Safe
Back to top |
Nath |
Nath World Chat Champion
Back to top |
Spiral |
Back to top |
Kye |
Kye Scooby Slapper
Back to top |
Ste |
Ste Not Work Safe
Back to top |
27yo kid |
Posted: 12:43 - 15 Oct 2004 Post subject: agree with ste |
Guys I have to say I agree with ste here.
Its like getting a kit car (which I have) and comparing it to a racing kit car.
I mean my cars great but the cars they race are more than just kit cars.
Same goes with truck racing.
(besides, I bet they dont whizz in and out of traffic and up on the pavement when they're racing them on the track!)
THAT WAS A JOKE BEFORE ANYONE GETS UPSET!!! |
Back to top |
DM |
DM Scooby Slapper
Posted: 19:31 - 16 Oct 2004 Post subject: |
I borrowed a friend's Runner SP50 for 2 months while he was in school and my engine was in pieces. It's a '99 model, original piston and cylinder, completely stock but derestricted and I managed 102 kph / 60 mph (indicated 110 kph, but the speedo's off) down a long, slight hill and was good for 88-90 kph on a flat if I was to duck breeze. It's the fastest stock 50 I've ever ridden, and I've ridden a lot of 50's .
Another friend of mine had an NSR 50 with carbon fibre reeds, a 21mm carb, cone air filter and performance exhaust and was topping 115 kph / 72 mph on a flat for a few months after buying it. Those are correct speeds as someone was following with a digital speedo the first night he opened it up proper.
My point is some of you have some strange ideas about what 50's are capable of. In Bermuda, when you turn 16, you get a 50, whether as a birthday present or from your own pocket. That's just how it is. You can imagine the competition between the guys with the faster bikes and the money dropped on performance parts . So, I've been to a lot of races, ridden a lot of tuned machines, etc, and some of them aren't bad for what they are. |
Back to top |
There is a gap of 10 years, 125 days between these two posts... |
SuperSpack |
SuperSpack L Plate Warrior
Back to top |
Clutchy |
Clutchy World Chat Champion
Posted: 00:45 - 17 Feb 2015 Post subject: |
100000000mph
Give or take. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
Back to top |
Bikeless |
Bikeless World Chat Champion
Back to top |
Rogerborg |
Rogerborg nimbA
Posted: 09:14 - 17 Feb 2015 Post subject: |
He's gone relativistic, probably only 5 minutes subjective time. ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
pdg |
pdg World Chat Champion
Back to top |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 15:27 - 17 Feb 2015 Post subject: |
SuperSpack wrote: | What speed increase will you get from changing from 11T to 12T or 13T |
1/ Don't dig up a decade old threads.
2/ Expect to get the piss ripped regardless
3/ Ask a full and proper question.
To answer what you asked.. a 13 tooth sprocket will be heavier than an 11 tooth sprocket... other than that.. sort of depends really... quite a lot actually... like whether that's the driving sprocket, or the drive sprocket, and how many teeth the 'other' sprocket has.. the gearing 'ratio' is the 'ratio' of teeth on driven sprocket to teeth on the drive sprocket... and you have only offered half the sum. THEN there is the small issue, that 'gearing' is merely the means by which you match engine speed to road speed. POWER = DRAG x SPEED.. so if you want to go faster, which we assume you do, you need to ether increase power, or reduce drag, or both... if you don't, you can do what you like with the gearing; all you will do is make it slower. If gears too low, engine will reach max revs at a road speed beneath that where Power matches Drag. If gears too tall, power will match drag before you reach max power revs; and most bikes with gears, to start with, have 'too tall' a ratio in 'top' gear and 'too low' a ratio in bottom gear, so messing about with the overall drive ratio by one or two teeth over 30 odd, rarely makes much odds; and tend to just moves your shift points around a bit. So what's the 'question'? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Back to top |
1198 |
1198 World Chat Champion
Posted: 21:37 - 18 Feb 2015 Post subject: |
Teflon-Mike wrote: | SuperSpack wrote: | What speed increase will you get from changing from 11T to 12T or 13T |
To answer what you asked.. a 13 tooth sprocket will be heavier than an 11 tooth sprocket... other than that.. sort of depends really... quite a lot actually... like whether that's the driving sprocket, or the drive sprocket, and how many teeth the 'other' sprocket has.. the gearing 'ratio' is the 'ratio' of teeth on driven sprocket to teeth on the drive sprocket... and you have only offered half the sum. THEN there is the small issue, that 'gearing' is merely the means by which you match engine speed to road speed. POWER = DRAG x SPEED.. so if you want to go faster, which we assume you do, you need to ether increase power, or reduce drag, or both... if you don't, you can do what you like with the gearing; all you will do is make it slower. If gears too low, engine will reach max revs at a road speed beneath that where Power matches Drag. If gears too tall, power will match drag before you reach max power revs; and most bikes with gears, to start with, have 'too tall' a ratio in 'top' gear and 'too low' a ratio in bottom gear, so messing about with the overall drive ratio by one or two teeth over 30 odd, rarely makes much odds; and tend to just moves your shift points around a bit. So what's the 'question'? |
To summarise Mike, unlikely to increase your top speed (by much, if at all). The engine is unlikely to have the ummph to propel you faster. |
Back to top |
Wednesday Biker |
Wednesday Biker Spanner Monkey
Back to top |
RhynoCZ |
RhynoCZ Super Spammer
Back to top |
There is a gap of 2 years, 164 days between these two posts... |
JAWA |
JAWA L Plate Warrior
Back to top |
M.C |
M.C Super Spammer
Posted: 20:34 - 05 Aug 2017 Post subject: |
So it's de-restricted then |
Back to top |
Tracer1234 |
Tracer1234 World Chat Champion
Back to top |
The last post was made 6 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
