Argument
Jrod
Page 3 Girl
PostPosted: 20:23 - 27 Jan 2005    Post subject: Argument Reply with quote
Right I'm having a argument with Dom:
I think that If you redline a RS125 in 6th gear it will be going at the bikes top speed, If it was restricted it wouldnt redline in 6th? and IF It did then it would be going the same speed as one not restricted? Confused
Hope you understand what I mean. Razz
So whats the case? Can you redline a restricted rs125 in 6th and still be doing only 75.
Fortuna
PostPosted: 20:26 - 27 Jan 2005    Post subject: Reply with quote
Even unrestricted it would theoretically do the same speed unless you change the gearing.
Shaun
Likes 'em bent
PostPosted: 20:27 - 27 Jan 2005    Post subject: Reply with quote
I never managed to red line my RS125 in 6th and it was restricted, got an indicated 90 too.
Jrod
Page 3 Girl
PostPosted: 20:28 - 27 Jan 2005    Post subject: Reply with quote
This is what I think!
Dom
PostPosted: 20:30 - 27 Jan 2005    Post subject: Reply with quote
All I can say is when we were on a rideout yesterday I looked at my rev counter and it was just over the redline, so I backed off a bit. And that was at a piddly 75 odd. Course that's a guess, since my speedo had stopped working by then. Rolling Eyes
MattEMulsion
PostPosted: 20:38 - 27 Jan 2005    Post subject: Re: Argument Reply with quote
Yes I know what you mean and I think what you are saying is right.
This is one thing I have never understood when people have their cars chipped or their bike tuned and reckon it has increased their top end speed. How can it - unless you alter the gearing it will be doing exactly the same speed at the redline rpm. It may get there a bit quicker but it won't make it go faster top speed wise. If anyone can correct me on this or confirm this your comments are welcome.
Yamaha YZF-R6
Fortuna
PostPosted: 20:59 - 27 Jan 2005    Post subject: Reply with quote
No thats correct ^^.
Exactly why I changed the gearing on my R1 after the tuning.
hugo-a-gogo
PostPosted: 21:15 - 27 Jan 2005    Post subject: Re: Argument Reply with quote
yes but if you didn't have enough power to redline in top before tuning, you never got to that theoretical top speed. the tuning allows you to reach the redline
"There are some things nobody needs in this world, and a bright-red, hunch-back, warp-speed 900cc cafe racer is one of them - but I want one anyway, and on some days I actually believe I need one. That is why they are dangerous."
Hunter S Thompson
clicky 4 bikey
impaler
PostPosted: 21:15 - 27 Jan 2005    Post subject: Reply with quote
Assuming your speed perception isn't horrendous and you were actually doing 70-80, then presumably either your rev counter is stuffed or you weren't in top gear?
Monster m600
Web, blog, Bikepics page
An optimist will tell you the glass is half full. The pessimist, half empty. The engineer will tell you the glass is twice the size it needs to be.
Dom
PostPosted: 21:23 - 27 Jan 2005    Post subject: Reply with quote
Right this calls for a proper scientific investigation. Razz We'll do a run down the a3 tomorrow and I'll go flat out in 6th. zxr400er can clock me and we'll have a better idea.
18aprilia
I don't get it?
PostPosted: 21:29 - 27 Jan 2005    Post subject: Reply with quote
Er.... I cant seem to do it, it dont have the power to get there, not to mention that i alwasy seem to run out of road. i think the most i have had is 80mph, but like i said before always run out of road.
Supra King
PostPosted: 13:54 - 28 Jan 2005    Post subject: Reply with quote
Whatever power the engine puts out, a particular bike will do the same speed in the same gear at the same revs unless you change the gearing.
There is the exception of an automatic gearbox where this is not true, and also with a manual where the clutch is slipping.
For my RS125 the red line is at 10750rpm, and it is geared for an indicated 10mph / 1000rpm so it would be indicating 107mph. Most I have ever had out of mine was an indicated 115mph, at which point it was 750rpm into the red line in top gear. By the way, it has never been restricted Very Happy .
Getting an RS to hit the red line in top at (say) 80 would mean adding about 10 teeth to the rear sprocket.
loply
PostPosted: 14:02 - 28 Jan 2005    Post subject: Reply with quote
Maybe you were just in 5th gear not 6th.
Or you have a severely downgeared RS125.
Or your rev counter/speedo is broken.
Yamaha SZR660 Caution to the wind, the throttle pinned!
loply
PostPosted: 14:03 - 28 Jan 2005    Post subject: Reply with quote
Or your clutch is slipping.
Fortuna
PostPosted: 14:06 - 28 Jan 2005    Post subject: Reply with quote
Or I was towing him.
Dom
PostPosted: 14:57 - 28 Jan 2005    Post subject: Reply with quote
Lol, oh dear - perhaps by that point in the ride I'd spent so long slinging my arse off the bike around corners and desparately trying to overtake queues of lorries I'd totally lost the plot. Laughing
I must admit I'm still a bit confused by it all cause I've definitely had 10k in top gear out of it (11k redline on mine) without doing de-restricted speeds, which is confusing given that I thought the restricted bikes levelled off power-wise over about 8500rpm. Also I was definitely doing around 70mph odd at the time and I doubt it's capable of that in 5th, even if it is at the redline.
PostPosted: 15:22 - 28 Jan 2005    Post subject: Reply with quote
Assuming the gearing is standard and you were no slipping the clutch, then at 10k in top you were doing 100mph (or as near as matters).
Tends to suggest that either you were not in top or the bike is derestricted.
With the clutch not slipping there is a fixed ratio between revs and speed, and this certainly does not change when you derestrict the bike.
loply
PostPosted: 17:32 - 28 Jan 2005    Post subject: Reply with quote
Yeah as stated above there are only a few possible explanations:
1) The clutch was slipping (lever adjusted too far out?)
2) The gearing is dramatically altered (check your sprocket sizes compared to the manual)
3) Your speedo is broke
4) Your tacho is broke
5) You werent in top gear
The last post was made 21 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 100.33 Kb
