TLC Required
Skudd
PostPosted: 10:51 - 18 Feb 2015    Post subject: TLC Required Reply with quote
https://i50.photobucket.com/albums/f324/skudd67/20150216_154505_zpsd0b13e2a.jpg[/URL]
nowhere.elysium
The Pork Lord
PostPosted: 11:00 - 18 Feb 2015    Post subject: Reply with quote
TLC? Abuse counselling, more like.
Fisty
PostPosted: 11:03 - 18 Feb 2015    Post subject: Reply with quote
Put it out of its misery.
Fatter and faster than Fret
wr6133
PostPosted: 11:08 - 18 Feb 2015    Post subject: Reply with quote
Torch it
pdg
PostPosted: 11:13 - 18 Feb 2015    Post subject: Reply with quote
If it runs, I'll give you £8.29 for it.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
c_dug
PostPosted: 11:14 - 18 Feb 2015    Post subject: Reply with quote
Is it coming to the bbq?
Praying Praying Praying Praying Praying Praying
Skudd
PostPosted: 11:21 - 18 Feb 2015    Post subject: Reply with quote
Fork seals, chain and sprockets, a good clean and a few plastics.
I have seen far worse on here and on the road.
Obviously the usual filter and oil changes as per any bike, but it is more reputation than actual issues.
It will be a run around for the other half while she gets her bike legs back as well as a starter for my lad to get on the road if jobs arrive. Just need to make it properly road worthy and reliable.
nowhere.elysium
The Pork Lord
PostPosted: 11:25 - 18 Feb 2015    Post subject: Reply with quote
Output shaft and seals? I predict that this will become more of a money pit than you think.
Skudd
PostPosted: 11:40 - 18 Feb 2015    Post subject: Reply with quote
Out put shaft £30 on e-bay (whole gear box for under £50) but seeing peoples projects on her it should be fine. I'm no master mechanic, but if I can do a clutch/radiator/sprocket & chain changes on my Varadero 1000 this little baby will be fine. I'm not looking for it to be show room condition when I finish as my bike isn't just a nice little run around for us.
nowhere.elysium
The Pork Lord
PostPosted: 11:46 - 18 Feb 2015    Post subject: Reply with quote
Plus gaskets, and the inevitable sheared/rounded bolts and such. I'm not questioning whether you're capable Skudd, merely giving you the heads up that it's not going to be as trivial as you make out. I've dealt with 125 shitters prior to now, and they invariably cost more than they're worth in the long run.
Either way, I'm looking forward to the writeup. Nothing quite like a horrorshow rebuild thread to follow. Thumbs Up
Matt B
PostPosted: 11:48 - 18 Feb 2015    Post subject: Reply with quote
https://www.housingwire.com/ext/resources/images/editorial/Miscellaneous-Items/trouble-ahead-sign.jpg
Fisty
PostPosted: 11:50 - 18 Feb 2015    Post subject: Reply with quote
Can I have some of what you're on please Skudd?
Skudd
PostPosted: 12:14 - 18 Feb 2015    Post subject: Reply with quote
The drugs are fine and working well.
If it does become a money pit then it will be at the BBQ, but it won't be. It is more a reputation of the bike than the actual bike it's self. There is nothing so far that I wouldn't have expected on a used 12 year old 125cc bike. Nothing that a stitch in time won't save.
By the way Body Guard is a nice lad in person(just like the rest of us lot) and I hope makes it to the BBQ this year.
PostPosted: 12:50 - 18 Feb 2015    Post subject: Reply with quote
This is a legend in the making.
Welded in the sorcerous fires of the Gar-Age of G'av, the Destroyer of Walls, the Bike That Would Not Die.
wr6133
PostPosted: 12:59 - 18 Feb 2015    Post subject: Reply with quote
The bike that somebody needs to take to the depths of Mordor and throw in to the fires of mount doom.
1198
PostPosted: 18:28 - 18 Feb 2015    Post subject: Reply with quote
Much respect is due to Mr. Skudd!
Awaiting updates!
1198
PostPosted: 18:29 - 18 Feb 2015    Post subject: Reply with quote
Awaiting updates!
Ps has Bodyguard been heard of recently? He's been really quiet, I noticed this a couple of days ago!
Skudd
PostPosted: 18:59 - 18 Feb 2015    Post subject: Reply with quote
I guess busy working and enjoying his new bike.
garth
PostPosted: 19:22 - 18 Feb 2015    Post subject: Reply with quote
Output shaft won't be that bad once you've split the cases. Give you a chance to see what it's like inside.
Might not even need any gaskets, I've split cases successfully without replacing them with no oil leaks.
andyscooter
PostPosted: 19:33 - 18 Feb 2015    Post subject: Reply with quote
Inb4 Skudds got bodyguard locked in his celler
Rob W
PostPosted: 19:36 - 18 Feb 2015    Post subject: Reply with quote
Rear cylinder says it all.
https://i1212.photobucket.com/albums/cc449/Rob-W-1983/1_zpszxc2sc7p.jpg
TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900
Skudd
PostPosted: 21:02 - 18 Feb 2015    Post subject: Reply with quote
Please don't guess from a dodgy photo as it is only a guess. It runs, starts first time and sounds ok, just like any other 12 year old 125 that has had youths on it.
Just a few bits and TLC really and that sprocket. lol
Commuter_Tim
PostPosted: 21:39 - 18 Feb 2015    Post subject: Reply with quote
Wait a minute... does that mean BodyGuard is a real person?! Shocked
I ride a Bandit 600... badly.
PostPosted: 22:02 - 18 Feb 2015    Post subject: Reply with quote
Bring it to BCF BBQ.
We play nice....We no lie.
Liar
We kill it...fix it and kill it again.
andyscooter
PostPosted: 22:31 - 18 Feb 2015    Post subject: Reply with quote
He drew PIC its sad
The last post was made 11 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 2.58 - MySQL Queries: 13 - Page Size: 130.01 Kb
