1999 zx6r cutting out
chappy
PostPosted: 10:55 - 21 Feb 2015    Post subject: 1999 zx6r cutting out Reply with quote
Hello there just went to use my zx6r g2 whats been sat for few months put 5 pound petrol in jerry can as i drained tank before i gariged it .
Put petrol in she fired up loads battry let her walm up bout 15 mins why put bike gear on pulled away fine as soon as i get 4 meters up road it bogs and cuts out.
She starts again easy and revs fine just when i pull away it cuts out wont move at all needed to push back home . Could my carbs be blocked . I changed the spark plugs , coolent and oil the day it got stored so new plugs . Thanks
captain_ramshackle
PostPosted: 11:01 - 21 Feb 2015    Post subject: Reply with quote
There is a 99% chance I'm completely wrong here but this sounds exactly like what happens when I'm an idiot.
I've got a slightly leaky float on my carb so when I leave the bike I switch the petcock to off.
If I forget I did this I can start the bike, it will rev and pull away for a few metres before cutting out. I can then restart and repeat until I remember to turn the tap to on.
chappy
PostPosted: 11:07 - 21 Feb 2015    Post subject: Reply with quote
I tried it on both on and reserve same result
wr6133
PostPosted: 11:20 - 21 Feb 2015    Post subject: Reply with quote
Might have pulled some crap through to the jets. I always thought for short storage like that you were meant to drain the carbs and brim the tank.
chappy
PostPosted: 13:41 - 21 Feb 2015    Post subject: Reply with quote
I had the tank off to look at carbs bit to much work for me to get to jets i think . I blowed some air in the fuel lines and brown rusty water or petrol came out ..
so cleard that with air and reconeted tank and she started strait away but still cuts out . It lets me pull away but as im just settin of at low speed bogs and cuts off . .
misscrabstick
PostPosted: 14:20 - 21 Feb 2015    Post subject: Reply with quote
I have an F1 the carbs block real easy if the bikes left without draining the float bowls, had to remove and clean them out just last week actually, it's not a bad job when you done it a few times, I usually find i get one pilot blocked so it runs on 3 pots until 3000 rpm.
chappy
PostPosted: 19:13 - 21 Feb 2015    Post subject: Reply with quote
Right cleaned the carbs out put back gever all fired up took for a ride bit boggy at first then cleard now seams be working ok bit boggy somtimes but should clear self after long run ..
since puttin carb back tho the throttle dose not seam to snap back instantly and has bit of play i did need to dissconect at carb end to clean carbs so could of disrupted somthing . Any ideals on how to adjust thanks
The last post was made 11 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 51.7 Kb
