Does anyone have any advice on removing this bolt
adam2013
PostPosted: 19:50 - 21 Feb 2015    Post subject: Does anyone have any advice on removing this bolt Reply with quote
So I bought a new exhaust for my XR 125 and I need to get the old one off and I dont really want to snap these nuts and bolts in my engine Crying or Very sad .
here is a picture:
Current: '04 Honda XR 125L
Project: '86 Yamaha DT 125LC
Nobby the Bastard
Harley Gaydar
PostPosted: 19:54 - 21 Feb 2015    Post subject: Reply with quote
1) hammer a socket a couple of sizes too small on it.
2 ) twist and hope for the best.
Triumph Sprint ST 1050
adam2013
PostPosted: 20:00 - 21 Feb 2015    Post subject: Reply with quote
do you know anything for the allen key?
CieL
PostPosted: 20:06 - 21 Feb 2015    Post subject: Reply with quote
I think it would be best to just take it to a mechanic. I had a similar problem a while ago with a nut on my brake caliper that I couldn't remove. In the end I gave up and took it to a mechanic, he removed it in 3 minutes. Knowledge and the right tools I guess. He didn't even charged me for it.
Semper Paratus
adam2013
PostPosted: 20:11 - 21 Feb 2015    Post subject: Reply with quote
I went to a motorcycle mechanic today and he told me chances are its going to take a good few hours but i suppose if hes going to get the job done i guess it my only option Crying or Very sad
Thanks for you help
Nobby the Bastard
Harley Gaydar
Centrepunch, on the side. Then angled in the right direction to undo it.
PostPosted: 20:14 - 21 Feb 2015    Post subject: Reply with quote
Start soaking it in Plus Gas as soon as you can. Best case it undoes, second best it unwinds the stud from the head, worst case it snaps and it might need drilling out.
adam2013
PostPosted: 20:16 - 21 Feb 2015    Post subject: Reply with quote
it sounding expensive for the mechanic to do
PostPosted: 20:28 - 21 Feb 2015    Post subject: Reply with quote
Weld a M10 nut over it, undo with 17mm spanner.
adam2013
PostPosted: 20:31 - 21 Feb 2015    Post subject: Reply with quote
would that no give it a better chance of snapping
PostPosted: 20:38 - 21 Feb 2015    Post subject: Reply with quote
The odds on that are very high anyway.
Actually if you have a new exhaust ready to fit I would simply cut off the old one at the pipe, grind off the nuts, remove the clamp flange then weld nuts to the stubs of bolt sticking out. That way you'll be guaranteed some stud to weld to plus you'll heat-shock the embedded part and the chances of removal become many times better.
adam2013
PostPosted: 20:54 - 21 Feb 2015    Post subject: Reply with quote
I think ill give that a go but if it does snap inside the engine how do I remove the stud then?
PostPosted: 20:55 - 21 Feb 2015    Post subject: Reply with quote
If it's flush, your only option is to drill. I can do it with a very high success rate but I couldn't when I was a teenager.
adam2013
PostPosted: 21:05 - 21 Feb 2015    Post subject: Reply with quote
well it need a new exhaust so it has to be done one way or the other
thanks for your help
andyscooter
PostPosted: 21:09 - 21 Feb 2015    Post subject: Reply with quote
Decent Allen key will help
I use Allen heads on a decent wrench and have got worse out
PostPosted: 21:13 - 21 Feb 2015    Post subject: Reply with quote
It's always worth a try. The worst that can happen is you shear the bolt off flush to the head.
john24ssj
PostPosted: 22:02 - 21 Feb 2015    Post subject: Reply with quote
Well this might sound stupid but what worked for me is taking an old alan key and putting it and welding to the bolt.
Once off use angle grinder and your done. Only take few minutes, that's of course if you got a welder.
Bikes: Honda CBR600Fi, Kawasaki ER5
adam2013
PostPosted: 22:03 - 21 Feb 2015    Post subject: Reply with quote
Ill get started on it tomorrow hopefully all goes well Thumbs Up
PostPosted: 23:28 - 21 Feb 2015    Post subject: Reply with quote
You should have cleaned it up and been soaking it in PlugGas or acetone-and-ATF for days. Give yourself half a chance at least.
PostPosted: 23:33 - 21 Feb 2015    Post subject: Reply with quote
Your exhausts will last a lot longer and look a lot better without that ridiculous heat wrap on them.
stirlinggaz
PostPosted: 00:03 - 22 Feb 2015    Post subject: Reply with quote
hi,
i'd be tempted to hammer in a torx bit rather than an allen key or hex bit.
hammer it well in & the "shock" might help loosen it off. (its the corrosion thats the issue here)
then loosen with ratchet & replace bolt combined with a dab of those new fangled chemicals that stop bolts seizing.
cheers,
GAZ
adam2013
PostPosted: 00:04 - 22 Feb 2015    Post subject: Reply with quote
The bike is my daily transport and it need to pass its MOT so i put the heat wrap on to hide the holes Wink
I might of helped but i have been soaking them in wd40
Pigeon
PostPosted: 00:40 - 22 Feb 2015    Post subject: Reply with quote
If you struggle to get hold of Plusgas, GT85 is also very good for this job. You could try mixing up (30% white spirit, 50% parafin, 20% engine oil)
I had a similar problem on my SV. On the advice of others, managed to get it sorted. But that was stud + bolt and I dremelled off the remains of the bolt, got the exhaust flange off then spent hours with plusgas + blowtorch + ice cold water and hitting the stud with a VERY small/light hammer to shock break the rust bond.
I had just enough stud exposed to get a socket stud extractor on it which cracked the stud / it rotated 1/2 turn then rounded off. But that crack was enough to get the molegrips on and spin it out.
Llama-Farmer
PostPosted: 01:04 - 22 Feb 2015    Post subject: Reply with quote
Lots and lots and lots of Plus Gas.
Not WD40, not GT85, not anything else, but proper penetrating fluid. i.e. Plus Gas is hands down the best thing I've ever used.
Heat can help too. Getting a blowtorch onto it can help expand the metal which can make it free off easier. Also tightening it ever so slightly to crack it off before undoing it often works well.
If you're really struggling, using a chisel and a lump hammer can work to just smash the bolt round and round until its loose enough for some mole grips.
Or if there is room, stilsons... they're self tightening, so as you turn them they grip more and more. Mole grips and adjustable spanners and sockets and that have all failed me multiple times... my pair of stilsons have a record of about 14 wins and 0 losses.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
adam2013
PostPosted: 10:22 - 22 Feb 2015    Post subject: Reply with quote
Where is the best place to buy plus gas?
The last post was made 11 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 126.16 Kb
