Chain question
finniee
PostPosted: 23:06 - 22 Feb 2015    Post subject: Chain question Reply with quote
I'm going to replace my chain in the next month or so, waiting for the crap weather to go before I do this.
What is it I'm looking for in buying a new chain?.
Same pitch?, same length?, I honestly have no clue.
To remove a chain without a split link do I specifically need a link breaker?.
When you buy a new chain does it come a link shorter for the rivet or the split to go into or would I need to remove some from the chain to make it the same length?.
Snod Blatter
PostPosted: 23:25 - 22 Feb 2015    Post subject: Reply with quote
You want the same pitch and length as is recommended for your bike by the manufacturer, the chain that is on there is probably correct but you can never trust previous owners!
To remove a chain without a split link you can do it nicely with the correct tool or you can take an angle grinder to one or two of the links (the pins that hold the plates together) and then slide it apart sideways.
If you buy a 100 link chain I suppose the actual lengthy piece would be 98 links and the soft links (on the same plate) make it 100, but you're starting to overthink it. Just buy the length you need Cool
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
Wull
PostPosted: 09:35 - 23 Feb 2015    Post subject: Reply with quote
A wee tip for you.......
When the new chain arrives after you cut the old chain attach the new chain to the old chain using a cable tie or by simply using one half of the new rivet link and pull the new chain through.
But its good practise to remove the front sprocket cover and give it a good clean,so if you go this route you don't need to fart about pulling the chain through as you'll be able to do it easily enough this way.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
mentalboy
PostPosted: 19:23 - 23 Feb 2015    Post subject: Reply with quote
Is it not the done thing to recommend replacing sprockets at the same time as the chain any more?
Chains wear out mostly because of road muck and as they wear the combination of the same muck and the chain (which is also 'stretching' and altering the way it sits on the sprockets). If you put a new chain on old sprockets you run the risk that the old chain has worn the sprockets to such an extent that they will have an adverse on your expensive brand new chain from day one.
Sprocket replacement may be a ballache but they are cheap and it always strikes me as a false economy to replace the chain without doing the sprockets at the same time. (It also gives you a chance to clean out the crud that accumulates under the sprocket cover)
Make mine a Corona.
RhynoCZ
PostPosted: 19:30 - 23 Feb 2015    Post subject: Reply with quote
If the sprockets are alright, then there's no need to change them. But I do think that it is ideal to change the sprockets when you get a new chain.
Well, if you've welded the front sprocket onto the shaft, for some reason, you know you won't be changing that any soon. Laughing
finniee
PostPosted: 20:03 - 23 Feb 2015    Post subject: Reply with quote
See I thought about doing it, but I have no access to Bodyguards tools.
I thought about replacing the Sprockets as well but when we had a look the sprockets looked fine. I will take them off and give them a wee clean and clean out all the crap that has accumulated over winter.
mentalboy
PostPosted: 21:39 - 23 Feb 2015    Post subject: Reply with quote
I've thought this in the past and then gone 'bugger it, for the cost of new sprockets I may as well replace them' and then been surprised when they've turned up at just how worn those fine looking old sprockets actually were.
Make mine a Corona.
PostPosted: 21:46 - 23 Feb 2015    Post subject: Reply with quote
For most bikes larger bikes a set of sprockets are dirt cheap compared to a chain. While I have reused sprockets many times on smaller bikes, with a larger bike I would normally just put new sprockets on at the same time.
By the way, most chains are the same pitch but there are different widths as well. With a normal chain with (say) a code of 520, the 5 refers the the pitch of the chain in 8ths of an inch. Hence 5/8" pitch.
finniee
PostPosted: 00:20 - 24 Feb 2015    Post subject: Reply with quote
I don't have a large CC bike, as of yet. I only have a 125 at the moment.
Anything that goes wrong I'm doing my best to figure out to try and fix myself.
I have been toying with the idea of getting a project bike and learning that way as well.
Skudd
PostPosted: 11:54 - 24 Feb 2015    Post subject: Reply with quote
That reminds me............... I will have to have a look at that sometime today. Or tomorrow. I'm hoping it was just welded because of a lack of the correct bolts and fixings so can be cleaned up and the bits a few pounds brand new. A gear box second hand is still only a few pounds, so no biggy, just time and mess, but that's pat of the fun.
The last post was made 11 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.66 - MySQL Queries: 13 - Page Size: 67.47 Kb
