| finniee |
 finniee Spanner Monkey
| Snod Blatter |
 Snod Blatter Crazy Courier
 Posted: 23:25 - 22 Feb 2015 Post subject: |
You want the same pitch and length as is recommended for your bike by the manufacturer, the chain that is on there is probably correct but you can never trust previous owners!
To remove a chain without a split link you can do it nicely with the correct tool or you can take an angle grinder to one or two of the links (the pins that hold the plates together) and then slide it apart sideways.
If you buy a 100 link chain I suppose the actual lengthy piece would be 98 links and the soft links (on the same plate) make it 100, but you're starting to overthink it. Just buy the length you need  ____________________ 1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL |
| Wull |
 Wull Crazy Courier
| mentalboy |
 mentalboy World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
| finniee |
| mentalboy |
| Kickstart |
 Kickstart The Oracle
 Posted: 21:46 - 23 Feb 2015 Post subject: |
For most bikes larger bikes a set of sprockets are dirt cheap compared to a chain. While I have reused sprockets many times on smaller bikes, with a larger bike I would normally just put new sprockets on at the same time.
By the way, most chains are the same pitch but there are different widths as well. With a normal chain with (say) a code of 520, the 5 refers the the pitch of the chain in 8ths of an inch. Hence 5/8" pitch.
| finniee |
| Skudd |
 Skudd Super Spammer
The last post was made 11 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
