Bike weight when pushing up an incline
orangepeeleo
PostPosted: 15:34 - 23 Feb 2015    Post subject: Bike weight when pushing up an incline Reply with quote
Hey,
To get my bike into my back garden at the minute I need to push it up a slight hill and over 2 little steps (no more than 2 or 3 inches high) now this is easy enough with my little YBR weighing a massive 125kg
Thinking for the future I've been looking at specs of bigger bikes, CBR600, Hornet, ZX6R, and while the width of them shouldn't be a problem when coming through my back gate (all around 730-750mm, not much different to the YBR) they are all obviously heavier, about 50kg on average.
Is 50kg extra weight going to make a huge difference in the amount of grunts I need to spend getting them up my little hill, at the moment its barely any grunts with a small run up to the gate, as long as I keep the momentum up to the flat area where I keep it, but I'm worried I'll end up buying a bike and dropping it on my first attempt to get it into the garden :/ Is it worth getting the back gate made wider, a few lumps of wood to make little ramps for the 2 steps and just riding it up rather than pushing it?...Images of me giving it a bit too much up the hill and ending up through the kitchen wall come to mind though! Shocked
Bikes : HN125 (sold) - Lexmoto ZSX 125 (Stolen!) - Currently bimbling on : '10 YBR
PostPosted: 15:37 - 23 Feb 2015    Post subject: Reply with quote
Just ride it up?
Nash GT
PostPosted: 15:51 - 23 Feb 2015    Post subject: Reply with quote
TheBaldReverend wrote:
Just ride it up?
What he said
Suzuki GSF600N
Taught2BCauti...
PostPosted: 15:56 - 23 Feb 2015    Post subject: Reply with quote
Get someone with another bike to tow you.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Chuffin Nora
PostPosted: 16:01 - 23 Feb 2015    Post subject: Reply with quote
Just ride it up?
What he said
I'm inclined to agree.
And what's so bad about that?
All bikes, or filthy lumps thereof, end up in the kitchen sooner or later. Thumbs Up
There's a fine line between integrity
CaNsA
PostPosted: 16:13 - 23 Feb 2015    Post subject: Reply with quote
It will teach you clutch control.
Has anyone got any MTFU pills to give this guy?
finniee
PostPosted: 16:21 - 23 Feb 2015    Post subject: Reply with quote
https://www.bryanallain.com/images/mancard.jpg
Feet down and use the clutch. Thumbs Up
FlightRisk
PostPosted: 16:24 - 23 Feb 2015    Post subject: Reply with quote
Don't worry about it.
Other morning I went to ride up a 2-3 inch kerb facing a plate glass shop window, front wheel went up fine, back wheel started spinning like mad. 'Moar REVS!', I thought. 'Everything better with MOAR RE... um... no… nope.'
Engine off, stand up, push up kerb, engine on, go park.
Moar revs could have been a better story though. Confused
Honda CB500S
Baffler186
PostPosted: 16:25 - 23 Feb 2015    Post subject: Reply with quote
Yes, ride it up. After 3 or 4 tries it will become second nature. I have to reverse mine downhill through a narrow gate, and then freewheel backwards for 10 yards before bumping down a pavement. After a few times you get used to it.
The easiest way to drop a big bike is to push it uphill over obstacles. Your front wheel will hit the step and turn towards you (as your right hand pushes the far handle bar away from you), then you'll fall forwards on to the bike.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
ScaredyCat
PostPosted: 20:18 - 23 Feb 2015    Post subject: Reply with quote
Yup, as everyone else has said, ride it up - it's a hell of a lot easier. I have to do this in my garden. One thing you might want to add is some reenforcement in the grass. I've found it all too easy to dig a hole.
My bike weighs 225Kg - I'm not pushing that, and me anywhere.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
notbike
PostPosted: 21:57 - 23 Feb 2015    Post subject: Reply with quote
I see what you did there
https://i.imgur.com/wR0PKPi.gif
Sload
PostPosted: 22:29 - 23 Feb 2015    Post subject: Reply with quote
I used to ride mine up stacked slabs into a conservatory but the bars were wider then the door. Was always twitchy leaning it on the angle halfway through the door whilst holding it on the clutch and twisting the bars through, just get on with it Thumbs Up
I dropped mine rolling backwards downhill with no obstacles Sad
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
RhynoCZ
PostPosted: 22:40 - 23 Feb 2015    Post subject: Reply with quote
Lower the bars are, worse to push it is. Thumbs Up
Albigularis
PostPosted: 23:14 - 23 Feb 2015    Post subject: Reply with quote
Our garage has a very steep slope going up to it, I just ride it up. If you don't feel comfortable riding it up, start it up and put it in first, stand beside it then use the clutch as a way to help you push it forwards.
The bike will ride up over the two steps fine. I rode my Street Triple up a flight of stairs once.
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
PostPosted: 23:29 - 23 Feb 2015    Post subject: Reply with quote
I ride mine up a scaffold board into the back of my van just like in The Italian Job. Except the van's parked, and it doesn't then try to fall off a cliff, and there's no gold. Otherwise it's just like that.
orangepeeleo
PostPosted: 10:55 - 24 Feb 2015    Post subject: Reply with quote
Haha,
Thanks for all the encouragement... and mocking Smile
I will try and ride it up into the garden when I go home later and report back!
grr666
PostPosted: 11:32 - 24 Feb 2015    Post subject: Reply with quote
I 'ride' mine while I am walking alongside it as I have to traverse a couple
of ramps to get mine out into the road.
Obviously then the bike pushes itself up the ramp and all I do is steer.
Much easier to do than push.
XBIKER
PostPosted: 15:53 - 24 Feb 2015    Post subject: Reply with quote
Definitely agree with walking it in gear up over steps, narrow ramps etc as should the worst happen then you are still on your feet capable of "saving" it Laughing
Riding up steps IIFFF you get it wrong can leave you hanging over the precipice trying to avoid dropping it. Always found it easier to push a punctured bike in gear using gentle throttle while walking along beside it, sometimes even turning up the tickover speed to make that simpler.
Obviously it becomes easier with practice to ride up and down such obstacles and I even recall one biker going down sixty park steps to the street below only to find police round the corner Rolling Eyes
stevo as b4
PostPosted: 16:55 - 24 Feb 2015    Post subject: Reply with quote
Get Yo skinny ass down the gym and start benching some weights and doing dead lifts. After a while of that and eating every opportunity you get, you'll be able to push it up a 1in2 incline while stopping half way to do some push ups one handed while you hold the bike up.
This will look much more tough guy and hero than riding up the garden path, wobbling and then falling off in a heap while the bike tumbles back down and lands with the throttle jammed open screaming, as you try to die a little bit inside, probably as a fit girl walks past! Laughing
orangepeeleo
PostPosted: 17:54 - 24 Feb 2015    Post subject: Reply with quote
Got the bike in the garden tonight and didnt drop it, decided to go for a combination of advic and rode it up some of the hill before jumping off and walking it up over the last step using the clutch/throttle Smile
The cat was watching me the whole time, not sure he knows that there was a legit chance of a kitten dying
And yeah, I'm getting myself down the gym to prepare for a bigger bike lol
gbrand42
PostPosted: 19:54 - 24 Feb 2015    Post subject: Reply with quote
Fly to the Dagobah system, speak with a small green Jedi Master. Learn of the Force and serve a long apprenticeship to master it's mystical ways. Then fly back to your house, grow a pair, get on your bike and ride it up the path. There that wasn't so hard was it?
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
The last post was made 11 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.31 - MySQL Queries: 15 - Page Size: 112.57 Kb
