Damage Identification - Photo Guessing Game
Commuter_Tim
PostPosted: 20:43 - 24 Feb 2015    Post subject: Damage Identification - Photo Guessing Game Reply with quote
Could somebody identify how or why a previous owner might have damaged the outer rim of these forks where the dust seal sits? Confused
https://www.bikechatforums.com/download.php?id=94653
I'm assuming with it being confined to the outer rim, it shouldn't cause damage to any new oil seals at least?
I ride a Bandit 600... badly.
PostPosted: 20:46 - 24 Feb 2015    Post subject: Reply with quote
Steve McQueen might have done that smashing through that roadblock.
Nemo
PostPosted: 21:05 - 24 Feb 2015    Post subject: Reply with quote
Probably pitted pretty badly so he tried to clean them up so it's less obvious for you to see.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Snod Blatter
PostPosted: 21:11 - 24 Feb 2015    Post subject: Reply with quote
Do you mean the screwdriver marks in the top of the fork leg? It was because he used a screwdriver to pry the dust seal off Very Happy
Shouldn't affect the oil seal, wouldn't really expect it to affect the dust seal as long as the top edge allows the seal to sit flat.
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
mudcow007
PostPosted: 21:19 - 24 Feb 2015    Post subject: Reply with quote
im going with flak when he fought ze germans.....
Commuter_Tim
PostPosted: 22:08 - 24 Feb 2015    Post subject: Reply with quote
That was my initial theory, discounted because I thought nobody could be that negligent. Shocked
I mean't the bits around the leg 'lip' not the sideways scratches over the pitting.
Although you are right, they did me up the wrong'un, wont be checking the next bike over in dusk!
Snod Blatter
PostPosted: 22:22 - 24 Feb 2015    Post subject: Reply with quote
I know right, anyone in their right mind would use a wider screwdriver than that Mr. Green
WD Forte
PostPosted: 22:50 - 24 Feb 2015    Post subject: Reply with quote
Scratches? pfft!
You bloody philistines !
Its obviously a runic inscription carved in the legs to
ask the norse gods to look kindly on the rider and prevent
the mischievous Loki from causing breakdowns.
You lot don't know nuffin you don't
bikers smell of wee
iooi
PostPosted: 10:24 - 25 Feb 2015    Post subject: Reply with quote
I would not worry about them little scratches....
Now all the pits (read craters) on them. Now that's a different story Laughing
PostPosted: 12:55 - 25 Feb 2015    Post subject: Reply with quote
For those craters in your fork legs.
Clean them out with white spirit and then fill them with fast drying Araldite. Smooth to correct profile and then your new seals might last longer than 10 minutes. Laughing
Triumph Trophy Launch Edition
Nemo
PostPosted: 14:04 - 25 Feb 2015    Post subject: Reply with quote
Teach me to read the post properly next time!
Commuter_Tim
PostPosted: 20:02 - 25 Feb 2015    Post subject: Reply with quote
Aye it appears the previous owner got about 1500 miles out of the last set of seals, granted that was with a pillion.
I'm going to replace the fork stanchion in the picture, thankfully the right hand side one is nowhere near that level ...yet!
What grit sandpaper is recommended for sanding down bubbled up chrome initially?
I've tried 0000 wool but its not making an impact. Neutral
PostPosted: 20:15 - 25 Feb 2015    Post subject: Reply with quote
Now I might be making this up, but isn't the slow drying Araldite meant to be better for this job?
No experience of it myself but seem to remember reading that people have not had much luck with this using the fast drying stuff.
stickybackbob
PostPosted: 20:22 - 25 Feb 2015    Post subject: Reply with quote
I agree that the slow cure araldite is used for this bodge, fsat drying stuff will fall out in no time. Especially if the area is washed in white spirit (leaves an oily residue behind).
To bodge it proper, use some brake cleaner to degrease the area, then fill the craters with 24 hour araldite. Allow to cure (24 hours) before rubbing back.
The last post was made 11 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 2.74 - MySQL Queries: 13 - Page Size: 84.07 Kb
