drop in performance after valve adjustment
RidingBear
PostPosted: 21:27 - 24 Feb 2015    Post subject: drop in performance after valve adjustment Reply with quote
hi, I adjusted the valves of my Ninja 300. all the exhaust were too tight, so I changed the shims by as much as 0.10mm to be in spec. Afterwards, I had a loss in the top end of about 10mph (from 115 to 105). Now, I think 115 is more than what normally users report as the top speed of a Ninja 300, so probably it was as high because of the tight valves.
it is my understanding that tight exhaust valves increase performance because of the increased overlap between in and ex valves.
I also noticed the engine runs some rpm higher at the top end, compared to before, when sitting at top speed in the highway.
The only other reason I could think of is that I misplaced the cam chain by 1 roller. I did count the number of rollers between the two cam sprockets, and it corresponds to the manual value, so I am sure that the tension between the two cams is correct. But, the chain might have moved with respect to the engine bottom sprocket (not sure how it's called).
Now, I don't think the chain moved, and I think it's just the valves, but I'd like to know if my thought on the valves and performance is right.
I did align the marks of both cams at TDC, but those rollers are small, not sure I can tell the difference of just 1 roller as the TDC mark is pretty large.
thanks!
Fisty
PostPosted: 21:31 - 24 Feb 2015    Post subject: Reply with quote
So your question is what?
Fatter and faster than Fret
Paddy Blake
PostPosted: 21:52 - 24 Feb 2015    Post subject: Reply with quote
I think you are imagining things tbh.
Shims at the right setting when cold are close to no gap when hot.
So tight shim gap when cold would lead to valves not closing all the
way with reduced performance and maybe pitted valve seat.
RhynoCZ
PostPosted: 21:55 - 24 Feb 2015    Post subject: Reply with quote
What forced you to check the valve clearances?
RidingBear
PostPosted: 22:59 - 24 Feb 2015    Post subject: Reply with quote
this is not a direct question it's more trying to understand how the engine works and the reason for the drop in speed. I was hoping somebody who has a lot of experience with valves would know.
I am not imagining the drop in speed, it's definitely there, although it's not a big deal as I don't usually go 115mph on the freeway.
I check my valves around each 7.5k as per manual, to avoid damage for example like Paddy Blake said, which can develop if you don't adjust the valves for a long time.
I did read that racers like to keep the exhaust valves tight. it has to do with that time during which both the ex and in valves are open, which is the overlap. the amount of overlap affects performance. so, tight shim ex valves have increased overlap, I believe, as the ex valves are open for longer.
cb1rocket
PostPosted: 02:37 - 25 Feb 2015    Post subject: Reply with quote
Could be Down to the fact that as you have made the clearances bigger, the valves don't open as much as they used to. I wouldn't worry about it
garth
PostPosted: 06:33 - 25 Feb 2015    Post subject: Reply with quote
How can it 'run higher revs' at the top end but go slower?
Sure you were in top gear? Laughing
monkeybiker
PostPosted: 09:40 - 25 Feb 2015    Post subject: Reply with quote
Is this what you meant or did you mean the other way round?
If it is reving more with no increase in speed then your clutch is slipping.
PostPosted: 10:01 - 25 Feb 2015    Post subject: Re: drop in performance after valve adjustment Reply with quote
Explanations:
You accidentally changed the drive sprockets without noticing.
Your rear wheel is spinning at 105mph.
Your tyres are flat enough to significantly reduce their diameter, but without shredding at 105mph.
Your clutch is slipping.
You're imagining things.
RidingBear
PostPosted: 19:37 - 25 Feb 2015    Post subject: Reply with quote
well it seems that at least somebody agrees that it could be either the change in valve clearance, or an accidental change in the drive sprocket by 1 roller, which is what I thought.
my rear tire is new, and hopefully nothing is spinning or slipping.
and yes I am sure I am in 6th gear, if I'm not, it can rev up to the limiter at 90-mph, it's not something that escapes your notice, the limiter kicking in. if there's a small drop in performance, it makes sense that, to reach the same high speed, the engine has to be at a higher rpm - to move the bike at a given speed you need X work. less work production per cycle, the higher number of cycles you need to produce X work, hence a higher rpm at the same high speed.
thanks everybody
monkeybiker
PostPosted: 19:43 - 25 Feb 2015    Post subject: Reply with quote
thanks everybody
Could you please explain how? The only way to achieve what you said would be to use a lower gear.
PostPosted: 19:54 - 25 Feb 2015    Post subject: Reply with quote
No it really doesn't.
Speed, gear and revs are directly related. Doesn't matter if your engine is putting out 10bhp or 100bhp.
Either your clutch is slipping, your aren't in top gear or you are just wrong.
pdg
PostPosted: 20:27 - 25 Feb 2015    Post subject: Reply with quote
Roger was referring to a change in the DRIVE sprockets - the thing attached to the rear wheel or engine that transmits DRIVE....
As said...
No, that makes no sense at all. Not in the slightest, or the least. Not even a bit.
The engine speed is directly proprtional to rear wheel rotational speed in each gear. That ratio is fixed. It is fixed using gears. It does not waver. It does not alter.
Unless: (some reasons courtesy of the borg)
You have an automatic and the torque converter isn't locking properly.
You don't actually have gears but instead have a CVT. Which is faulty.
Your tyre is spinning (or the wheel is spinning within the tyre).
If you are still unsure of how engine 'revs' correlate to road speed, I'm sure we can assist further with potato-level explanations.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
RidingBear
PostPosted: 21:46 - 25 Feb 2015    Post subject: Reply with quote
Ah thanks. it is clear now. see, I was looking at the engine as a black box delivering energy, something I generally do as a physicist - making approximations (I have a PhD in physics from Cambridge).
However, I was blind in not realizing that there is a simple, continuous mechanical link: with the same gear and drive sprocket, a certain rpm in the engine corresponds to a certain rpm in the wheel - hence a certain speed.
Nexus Icon
PostPosted: 22:23 - 25 Feb 2015    Post subject: Reply with quote
A PhD in physics, yet you don't understand basic engines, gearing and drive principles? No wonder Oxford is rated higher than Cambridge.
Greetings from Shitsville!
RidingBear
PostPosted: 23:43 - 25 Feb 2015    Post subject: Reply with quote
that is easy to say if you don't know the level of knowledge required to attain a PhD - it is very specialized. Hence, I may know about subatomic particles and how to do complex maintenance on a machine worth half a million pounds (as I did during my PhD), but not know much about how an engine works. Especially because in Cambridge you go around with a bicycle : )
Now I have a motorcycle and I'm learning on my bike.
By the way, not that I care much about rankings, but Cambridge is consistently ranked within the first 3 Universities worldwide, together with Harvard and MIT. Oxford is a little lower : )
Nexus Icon
PostPosted: 00:04 - 26 Feb 2015    Post subject: Reply with quote
I was only pulling your leg Wink
PS. Oxford 3rd, Cambridge 5th, currently.... Southampton 135th.
Not that I went to Southampton or anything Smile
Musketeer
PostPosted: 01:30 - 26 Feb 2015    Post subject: Reply with quote
Regarding the valve clearances, increasing gaps between cam lobes and tappets reduces the distance and time by which the valves open. So yes, within spec higher gaps will likely slightly reduce power compared to the being on the tighter side of spec. But not by the margin you describe. Are you sure the gaps are just not too big?
As for the REV to SPEED ratio if you gear ratio / sprockets remain the same it wouldn't change.
PostPosted: 01:37 - 26 Feb 2015    Post subject: Reply with quote
Our future monarch chose St Andrews, is all I'm saying on that.
On your valves, how confident are you that you measured them correctly? Would it be unfair to suggest that you may have gone in there looking for trouble, and therefore found it?
At this point, I'd suggest that getting a second opinion might be useful.
Or try some science. It works, bitches. Have you got or can you obtain a compression tester?
MaybeGuy
PostPosted: 01:46 - 26 Feb 2015    Post subject: Reply with quote
You know... from my experience, the more expensive machines are the simple ones. (and in the industrial grand scheme of things, 0.5M is nothing).
RidingBear
PostPosted: 01:55 - 26 Feb 2015    Post subject: Reply with quote
I know, BUT, Oxford pulls ahead because they have this thing called 'humanities'. now in the only two subjects that matter, physics and rowing, Cambridge is better. in the subject of physics, Cambridge is currently 3rd, Oxford is 6th.
RidingBear
PostPosted: 01:58 - 26 Feb 2015    Post subject: Reply with quote
there's some truth to that. some things in my bike are more complex than my old chamber in the lab. but my chamber was no walk in the park either - especially because you cannot call any engineer, technician or expert on these custom-made things. if you can't figure it out on your own, you're done for.
RidingBear
PostPosted: 02:04 - 26 Feb 2015    Post subject: Reply with quote
maybe he liked Scotland. it has its own beauty.
I am 100% confident I put the valves in spec. see the first time I had the valves adjusted by a professional mechanic who came at my house and showed me how to do it. it's not difficult, and my feeler gauges agree with my micrometer and the nominal values of the shims I removed and the shims I put it. there's no way I screwed that up. I know the 'dragging' feel measuring the gap is somewhat subjective and experience is useful, but they were too tight, just like they were too tight when he first adjusted them.
although I did say I lost about 10mph at the top end, it may be less. enough less to just be explained by the change in valve clearance. see, it's not like in california you can zoom by above 100mph anytime you want. cops can put you in jail if you go 100mph. so who knows, maybe the wind was in my favor when I did 115, and against me when I did 105. probably the difference is not 10mph but less.
it is not a problem so I don't think I have the time to go measuring compression and things, but the discussion has been useful to me to understand my bike a bit better
PostPosted: 09:47 - 26 Feb 2015    Post subject: Reply with quote
Humanities and humanity are worthless, but at least Oxford and St Andrews alumni use capitals at the start of their sentences. Tut Tut
Compression testing is a lot quicker than whipping the head off and fiddling with shims. Whatever happened to scientific method? Crying or Very sad
Tweaking aside, unless you're putting in stellar mileages, I'd be wondering why your valves keep tightening up. Bikes can and do go tens of thousands of miles without needing adjusted once, let alone twice.
wr6133
PostPosted: 11:10 - 26 Feb 2015    Post subject: Reply with quote
Ignoring valves briefly isn't 115 Mph total all out, voodoo in your favour speed on those 300 twins? If so "losing" 10 Mph is probably down to other factors. My 400 IL4 can just pass 130 if the stars align correctly and I do the correct form of human sacrifice prior to riding but on days where it only makes 115 I don't worry about it.
The last post was made 11 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 137.14 Kb
