| RidingBear |
 RidingBear Derestricted Danger
 Posted: 21:27 - 24 Feb 2015 Post subject: drop in performance after valve adjustment |
hi, I adjusted the valves of my Ninja 300. all the exhaust were too tight, so I changed the shims by as much as 0.10mm to be in spec. Afterwards, I had a loss in the top end of about 10mph (from 115 to 105). Now, I think 115 is more than what normally users report as the top speed of a Ninja 300, so probably it was as high because of the tight valves.
it is my understanding that tight exhaust valves increase performance because of the increased overlap between in and ex valves.
I also noticed the engine runs some rpm higher at the top end, compared to before, when sitting at top speed in the highway.
The only other reason I could think of is that I misplaced the cam chain by 1 roller. I did count the number of rollers between the two cam sprockets, and it corresponds to the manual value, so I am sure that the tension between the two cams is correct. But, the chain might have moved with respect to the engine bottom sprocket (not sure how it's called).
Now, I don't think the chain moved, and I think it's just the valves, but I'd like to know if my thought on the valves and performance is right.
I did align the marks of both cams at TDC, but those rollers are small, not sure I can tell the difference of just 1 roller as the TDC mark is pretty large.
thanks! |
| Fisty |
 Fisty Super Spammer
| Paddy Blake |
| RhynoCZ |
 RhynoCZ Super Spammer
| RidingBear |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 02:37 - 25 Feb 2015 Post subject: |
Could be Down to the fact that as you have made the clearances bigger, the valves don't open as much as they used to. I wouldn't worry about it ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| garth |
 garth World Chat Champion
 Posted: 06:33 - 25 Feb 2015 Post subject: |
How can it 'run higher revs' at the top end but go slower?
Sure you were in top gear?  ____________________ You ain't a has been if you never was |
| monkeybiker |
 monkeybiker World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| RidingBear |
 Posted: 19:37 - 25 Feb 2015 Post subject: |
well it seems that at least somebody agrees that it could be either the change in valve clearance, or an accidental change in the drive sprocket by 1 roller, which is what I thought.
my rear tire is new, and hopefully nothing is spinning or slipping.
and yes I am sure I am in 6th gear, if I'm not, it can rev up to the limiter at 90-mph, it's not something that escapes your notice, the limiter kicking in. if there's a small drop in performance, it makes sense that, to reach the same high speed, the engine has to be at a higher rpm - to move the bike at a given speed you need X work. less work production per cycle, the higher number of cycles you need to produce X work, hence a higher rpm at the same high speed.
thanks everybody |
| monkeybiker |
 Posted: 19:43 - 25 Feb 2015 Post subject: |
| RidingBear wrote: | well it seems that at least somebody agrees that it could be either the change in valve clearance, or an accidental change in the drive sprocket by 1 roller, which is what I thought.
thanks everybody |
Could you please explain how? The only way to achieve what you said would be to use a lower gear. |
| chris-red |
| pdg |
 pdg World Chat Champion
| RidingBear |
| Nexus Icon |
| RidingBear |
| Nexus Icon |
| Musketeer |
 Musketeer World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 01:37 - 26 Feb 2015 Post subject: |
Our future monarch chose St Andrews, is all I'm saying on that.
On your valves, how confident are you that you measured them correctly? Would it be unfair to suggest that you may have gone in there looking for trouble, and therefore found it?
At this point, I'd suggest that getting a second opinion might be useful.
Or try some science. It works, bitches. Have you got or can you obtain a compression tester? ____________________ Biking is 1/20th as dangerous as horse riding.
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 01:46 - 26 Feb 2015 Post subject: |
| RidingBear wrote: | | Nexus Icon wrote: | A PhD in physics, yet you don't understand basic engines, gearing and drive principles? No wonder Oxford is rated higher than Cambridge. |
that is easy to say if you don't know the level of knowledge required to attain a PhD - it is very specialized. Hence, I may know about subatomic particles and how to do complex maintenance on a machine worth half a million pounds (as I did during my PhD), but not know much about how an engine works. Especially because in Cambridge you go around with a bicycle : )
Now I have a motorcycle and I'm learning on my bike.
By the way, not that I care much about rankings, but Cambridge is consistently ranked within the first 3 Universities worldwide, together with Harvard and MIT. Oxford is a little lower : ) |
You know... from my experience, the more expensive machines are the simple ones. (and in the industrial grand scheme of things, 0.5M is nothing). ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| RidingBear |
| RidingBear |
| RidingBear |
 Posted: 02:04 - 26 Feb 2015 Post subject: |
| Rogerborg wrote: | Our future monarch chose St Andrews, is all I'm saying on that.
Or try some science. It works, bitches. Have you got or can you obtain a compression tester? |
maybe he liked Scotland. it has its own beauty.
I am 100% confident I put the valves in spec. see the first time I had the valves adjusted by a professional mechanic who came at my house and showed me how to do it. it's not difficult, and my feeler gauges agree with my micrometer and the nominal values of the shims I removed and the shims I put it. there's no way I screwed that up. I know the 'dragging' feel measuring the gap is somewhat subjective and experience is useful, but they were too tight, just like they were too tight when he first adjusted them.
although I did say I lost about 10mph at the top end, it may be less. enough less to just be explained by the change in valve clearance. see, it's not like in california you can zoom by above 100mph anytime you want. cops can put you in jail if you go 100mph. so who knows, maybe the wind was in my favor when I did 115, and against me when I did 105. probably the difference is not 10mph but less.
it is not a problem so I don't think I have the time to go measuring compression and things, but the discussion has been useful to me to understand my bike a bit better |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:47 - 26 Feb 2015 Post subject: |
Humanities and humanity are worthless, but at least Oxford and St Andrews alumni use capitals at the start of their sentences.
Compression testing is a lot quicker than whipping the head off and fiddling with shims. Whatever happened to scientific method?
Tweaking aside, unless you're putting in stellar mileages, I'd be wondering why your valves keep tightening up. Bikes can and do go tens of thousands of miles without needing adjusted once, let alone twice. ____________________ Biking is 1/20th as dangerous as horse riding.
| wr6133 |
 wr6133 World Chat Champion
The last post was made 11 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
