Hyosung gt 125 questions [few issues]
ko5i
PostPosted: 21:49 - 25 Feb 2015    Post subject: Hyosung gt 125 questions [few issues] Reply with quote
Hi, there
I have few questions about my bike hyosung gt 125 because everything is from 125 except forks, forks are from 250cc, i had many problems with it for example speed o meter didnt match headlight didnt match and everything that was attached to 125 forks didnt match. But the problem now is front brake that doesnt match, brake matches but the caliper mount bracket doesnt, and i dont wanna use homemade stuff as brackets and extend it or whatever because its break safety first Wink so it need to be durable.
My questions :
1. Where can i find just mounting bracket for 250 front brake Confused i think i looked everywhere around google and all i found was whole brake with the bracket and its around 50-90£
2.Where can i find something to make a thread inside old mounting bracket [ i made new holes in bracket from 125 and it fits but i can put nut on other side so i need to make new thread m6/1.25mm as stock holes had.
3. What should i do ? buy new caliper with mounting for 50/90£ [i have working caliper is just a mounting bracket i need ] or do that thread [but how. I tried with some 'tap' drill tool that makes thread but it was too soft and it melted that tool the thread was gone on that tap its for mild steel and aluminium and the bracket is heavy i think its steal hard steal or something.
4. Also another questions what parts also suits hyosung gt 125 ? because i would want to buy red brake and clutch levers and handle bars but i cant find any for this bike i found for kawasaki yamaha honda but not for this bike will parts from other bikes fit mine ? if yes what other bike parts will fit mine one ?
5.What are good website with parts for my motorbike ?
Many Thanks for helping guys !
Taught2BCauti...
PostPosted: 09:55 - 26 Feb 2015    Post subject: Reply with quote
I think you would be better off ( and a good deal safer) if you use stock parts to return the bike back to it's original spec - rather than use a jumble of incompatible, botched parts to make a fancy-looking death-trap.
In particular, brake parts, like mountings, back-plates, nuts and bolts, are usually made from hardened steel, to be able to cope with the stresses and forces involved, and shouldn't be replaced with unsuitable alternatives, or modded to fit something they shouldn't.
Try a general search on eBay for "Hyosung (Breaking, Spares)" because sometimes the parts you need aren't listed separately.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
ko5i
PostPosted: 20:31 - 27 Feb 2015    Post subject: Reply with quote
Hi, rear brake master cylider braked so i bought new one, mount it tried to bleed it and the bleeding hose/screw brake too, so i have 2 calipers front and rear with broken bleeding screw + front one doesnt fit + on top of all calipers in breaks doesnt really move they are rusty and move a bit but just a bit so i want to buy new caliper brakes rear and front one that will fit hyosung gt125 [250 on front], all i can find are used one, is there way i can buy new ones ? or which breaks from other motorbike brand will fit mine ? maybe kawasaki or honda ?
Wull
PostPosted: 21:29 - 27 Feb 2015    Post subject: Reply with quote
Best tip I can give you is,get rid!!
I've had one,and they're a heap of shite.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
ko5i
PostPosted: 21:38 - 27 Feb 2015    Post subject: Reply with quote
I think its the best sounding 125cc and best looking, i want to fix it pass MOT and maybe then i will sell it i dont know but first i wanna fix it, and im asking if you know what other bike parts fit this hyosung gt 125 because i saw once guy had red small clutch and brake levers from kawasaki or honda cant remember but he fitted it so it must be some other bikes parts that fit to this model i dont know kawasaki, honda , suzuki ?
Any one can help Confused
wr6133
PostPosted: 22:06 - 27 Feb 2015    Post subject: Reply with quote
Aren't the 250 parts you list identical to the 125? I thought the 250 was the same bike just a bigger engine.
ko5i
PostPosted: 22:30 - 27 Feb 2015    Post subject: Reply with quote
yes it is the most of parts from 250 fit 125 or other way around but both of these bikes has small range of items like only stock one black long ugly levers or bar handles there is not a lot i can chose thats why i asked if you maybe know what other bike brands fit hyosung gt125
For example i wanted to buy red handlebars and clutch and brake levers also red one but there are non for hyosung i found these https://www.ebay.co.uk/itm/191196115173?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and also handle bars
https://www.ebay.co.uk/itm/151493841670?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
but i dont know if it will fit mine one hyosung gt 125 what do you think guys Confused
PostPosted: 01:01 - 28 Feb 2015    Post subject: Reply with quote
i3arty wrote:
Hi, rear brake master cylider braked so gabble babble wabble
Urgh.
I worked on one of these to help out a chumrade.
The rear brake m/c was also seized. We unseized it, but the seals were shot and we couldn't find a recondition kit, so we got a salvage replacement. That was seized too. We unseized it and the seals also leaked, but it sort-of kind-of worked, and fuck it, we'd already sunk another £40 and two week's wait, it was only the rear brake, right? But it was a sod of a pig of a whore to bleed.
Insert much the same convoluted tale of woe for: the horn; the instruments; the exhaust, which led to us removing the cylinder head to drill and chisel it out; the rear tyre and rim; the swing arm; and other parts of which I have only a vague, nightmarish recollection. It was a Sisyphean task to keep unfucking it faster than it fucked itself.
His "bargain" bike cost more than its purchase cost to get through an MOT, then he dropped it and the price of sorting it yet again finally rendered it uneconomical. It's still sitting in his garage, too expensive to repair, but with nobody daft enough to take it on even as a Gumtree giveaway.
They're over-designed, over-priced, under-supported follys. You will never recoup a penny that you put into it and the best thing that you can do is to weigh it in for scrap.
This is helpful, although you'll only realise that with hindsight.
ko5i
PostPosted: 22:43 - 28 Feb 2015    Post subject: Reply with quote
so no one is helping...
I didnt came here to hear my bike is sh*t and best option is to scrap it
I came here to get help anyone ?
wr6133
PostPosted: 23:01 - 28 Feb 2015    Post subject: Reply with quote
When you needed to ask if grips will fit the bars, it became apparent that you were beyond help.
The last post was made 11 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 67.3 Kb
