Fitting Tubeless tyre DIY
sutty86
PostPosted: 14:54 - 26 Feb 2015    Post subject: Fitting Tubeless tyre DIY Reply with quote
How hard is it to fit a new tyre???
Rang local garage earlier told his machine had packed in and would have yo do it by hand would cost an hours labour and told me at least £25
Tyre only cost £35 an me22 Metzler front tyre.
I think that's pretty dear and wondered if I could do it myself .I have a free afternoon this weekend.
Its a YBR custom
Tyre is 3.00 x 18
Cheers guys
garth
PostPosted: 15:25 - 26 Feb 2015    Post subject: Reply with quote
Easy enough with decent levers.
I get mine changed for £5 per loose wheel.
sutty86
PostPosted: 16:19 - 26 Feb 2015    Post subject: Reply with quote
Is it easy to remove front wheel I do have disc brakes on the front
sutty86
PostPosted: 17:39 - 26 Feb 2015    Post subject: Reply with quote
Front wheel easy just bolt .
Came apart easy
Speedo cable was tight
RhynoCZ
PostPosted: 17:40 - 26 Feb 2015    Post subject: Reply with quote
You can take the caliper off, it'll be way easier to re-fit the wheel again.
sutty86
PostPosted: 17:52 - 26 Feb 2015    Post subject: Reply with quote
Ha I'm hoping it will just slide back in
Am I wishing too much ha
WD Forte
PostPosted: 17:59 - 26 Feb 2015    Post subject: Reply with quote
As said, easy once you've broken the bead to get the old one off
and you have decent tyre irons and protect the rims.
I used to jack my old van up then drop the pin hitch to break the bead on
worn out tyres.
I suggest you inspect the rim before fitting the new tyre in case it has any
digs or oxidisation/crust to prevent you getting a good seal on the new one.
In place of the proper stuff, washing up liquid helps to slip the new tyre on.
Check you have the direction of rotation correct !
There are rumours I've often used the aerosol and lighter trick to get the new tyres to bead in prior to inflation.
No one saw me do, it you cant prove nuffin
Moi?
Do This sort of thing?
Tut tut!
https://www.youtube.com/watch?v=mHZ0_OIF0eE
bikers smell of wee
SQL
PostPosted: 18:54 - 26 Feb 2015    Post subject: Reply with quote
I use a shovel to break the bead
sutty86
PostPosted: 19:34 - 26 Feb 2015    Post subject: Reply with quote
[quote="WD Forte"
[/quote]
FML bike shop I went to with wheel shut early so had a drive to a local tyre place who did it manually
Only charged me a fiver but only just got home checked next to bike and its the wrong way..
My fault will visit him tomorrow
He started off saying bike tyres are easy took him best part of ten minutes poor lad
Well guess I've learnt my lesson
doggone
PostPosted: 19:54 - 26 Feb 2015    Post subject: Reply with quote
If you watch someone doing it manually you should spot some tips for trying yourself.
I usually do my own but tyres have tended to get very low profile - minimal sidewall - and breaking the bead is increasing difficult but not been beat yet.
WD Forte
PostPosted: 23:33 - 26 Feb 2015    Post subject: Reply with quote
SQL wrote:
I use a shovel to break the sod
FTFY
bikers smell of wee
SQL
PostPosted: 00:42 - 27 Feb 2015    Post subject: Reply with quote
WD Forte wrote:
FTFY
Install my own tires all the time, takes 20mins now.
PostPosted: 11:53 - 27 Feb 2015    Post subject: Reply with quote
It can be done but it is a CUNT of a job, I pay someone to do it every time now.
sutty86
PostPosted: 22:24 - 27 Feb 2015    Post subject: Reply with quote
Tyres right way round now
I'm such a knob
Put tyre back on bike
And brakes don't feel as responsive
Like I do eventually stop
Or do I have to wear tyres in a few miles
Or am I being a wimp
RhynoCZ
PostPosted: 23:30 - 27 Feb 2015    Post subject: Reply with quote
Squeeze the brake lever a couple of times. This is completely normal, if you pushed the pots back into the caliper. Thumbs Up
WD Forte
PostPosted: 23:44 - 27 Feb 2015    Post subject: Reply with quote
Late I know, but I've often put some masking tape on the wheel and used a black marker pen to add an arrow
showing the direction of rotation just to avoid mistakes later.
Especially if taking it to a shop
bikers smell of wee
The last post was made 11 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 85.72 Kb
