peugeot speedfight i need help please
pedwhisperer
PostPosted: 11:26 - 23 Feb 2015    Post subject: peugeot speedfight i need help please Reply with quote
Got a problem with bike, jobs done so far to eliminate the problem, carb cleaned, fuel tank emptied new fuel and new vacuum pump and pipes fitted , new coil ,cap and plug and still the problem that some times the bike will run fine but then it starts missing the miss seems to be a chuffing noise and appears to be at the cylinder headmanifold gasket joint has any body any ideas what the problem may be because im at a loss.
if your not living life on the edge your taking up to much room
BMWilliams
PostPosted: 11:52 - 23 Feb 2015    Post subject: Reply with quote
if its only when its warmed up, could it be the choke?
if its stuck on then itl richen the mixture and make it run crappy after a few mins
A good long ride can clear your mind, restore your faith, and use up a lot of fuel.
Never ride faster than your guardian angel can fly.
Ride, eat, sleep...repeat.
pedwhisperer
PostPosted: 11:58 - 23 Feb 2015    Post subject: Reply with quote
it seems to be ok on start up from cold choke runs then cuts out but i suppose it could be cutting in again thanks will try it.
pedwhisperer
PostPosted: 18:29 - 26 Feb 2015    Post subject: Reply with quote
well put new electric choke in and its just as bad just dont know where to look
The last post was made 11 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 39.36 Kb
