Best chain lube/rust protection?
finchy95
PostPosted: 21:28 - 26 Feb 2015    Post subject: Best chain lube/rust protection? Reply with quote
Hey bcf, any recommendations for what chain lube to use? I commute 60 miles a day and I find my current titanium gel stuff just isn't staying on too great. Only done 1000 miles (had the bike a little over three weeks) and I've already got some pretty bad surface rust on the chain, which I have tonight wire brushed off and relubed. Any advice on treating the rust properly would also be great, Cheers!
2005 suzuki van van - Sold. -> 2015 honda cbr 125 r - current bike.
Now's not the time for fear. That comes later.
Northern Monkey
PostPosted: 21:29 - 26 Feb 2015    Post subject: Re: Best chain lube/rust protection? Reply with quote
An automatic oiler
finchy95
PostPosted: 21:31 - 26 Feb 2015    Post subject: Re: Best chain lube/rust protection? Reply with quote
Alans Snackbar wrote:
An automatic oiler
One of them scottoiler things? How easy is it to set up and such cos I'm pretty mechanically useless.
cb1rocket
PostPosted: 21:32 - 26 Feb 2015    Post subject: Reply with quote
engine oil.......and wipe off excess, have been for the last 13 years, never fails to let me down. An auto oiler like a scott oiler would be good for high distance riding
finchy95
PostPosted: 21:35 - 26 Feb 2015    Post subject: Reply with quote
Any particular kind or just what I put in the bike (10w40)
Islander
PostPosted: 21:42 - 26 Feb 2015    Post subject: Reply with quote
EP90 gear oil. It's heavier and less likely to fling plus it's cheap. Thumbs Up
Fisty
PostPosted: 21:43 - 26 Feb 2015    Post subject: Re: Best chain lube/rust protection? Reply with quote
An automatic oiler
Very easy.
Fatter and faster than Fret
Islander
PostPosted: 21:48 - 26 Feb 2015    Post subject: Reply with quote
I have a Scottoiler and a PDOiler. Of the two, the PDOiler is easier to install and set up. They both do the job though. Thumbs Up
Fisty
PostPosted: 21:51 - 26 Feb 2015    Post subject: Reply with quote
If you fancy a ride to Bristol I will happily fit one for you if you supply it. Show you how to use it and set it up etc.
finchy95
PostPosted: 21:57 - 26 Feb 2015    Post subject: Reply with quote
Cheers islander, I'll have a look for a PD in a second and cheers fisty! I'll see what I can afford and get back to ya.
stuartt
PostPosted: 22:34 - 26 Feb 2015    Post subject: Reply with quote
i've always wondered if chainsaw oil would do & at £35 for 5 gallon ..
i usually use carlube chain oil at £2.50 a can , every 2 or 3 hundred miles
ADSrox0r
PostPosted: 22:41 - 26 Feb 2015    Post subject: Reply with quote
I used to use chainsaw oil, perfectly fine just very gunky.
I use a Scottoiler nowadays, top notch chain is perfectly lubed up and I ride through all the 'orrible shite the British winter throws at us. Oh and no fling either, because it's properly set up....unlike a lot of bellends that whinge about them.
finchy95
PostPosted: 22:44 - 26 Feb 2015    Post subject: Reply with quote
I did think about chainsaw oil oddly enough but I get it all over me at work "anti fling" my arse.
cb1rocket
PostPosted: 23:46 - 26 Feb 2015    Post subject: Reply with quote
any cheapo oil you can find will do, i currently recycle my engine oil for lubrication. Just wipe off the excess
RidingBear
PostPosted: 01:52 - 27 Feb 2015    Post subject: Reply with quote
I use Bellray chain wax on my 30+30 miles daily
finchy95
PostPosted: 07:13 - 27 Feb 2015    Post subject: Reply with quote
I'll try some engine oil/maybe some of that wax until funding permits a scottoiler I think.
DrDonnyBrago
PostPosted: 09:57 - 27 Feb 2015    Post subject: Reply with quote
Clean engine oil in a scottoiler is my preferred lubricant/lubricator.
I am working my way through the 10L or so of cheap diesel car oil I bought when I owned a cheap diesel car, but never bothered to use.
finchy95
PostPosted: 10:06 - 27 Feb 2015    Post subject: Reply with quote
Scottoiler it is then. Cheers guys!!
The last post was made 11 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 98.06 Kb
