Bandit Carb cleaning
mudcow007
PostPosted: 10:41 - 27 Feb 2015    Post subject: Bandit Carb cleaning Reply with quote
So, last night was spent stripping my carbs again...
https://i25.photobucket.com/albums/c81/mudcow007/20150226_210634_zpsb6dhugpe.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20150226_210858_zps3jm9ovmr.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20150226_213819_zpsz2y4zd8x.jpg
i really dont want to split the individual carbs, but is it worth "dunking" the carb bodies in something to make sure they are all clean inside all the passageways?
or would you just use an airline with carb cleaner?
Taught2BCauti...
PostPosted: 10:58 - 27 Feb 2015    Post subject: Reply with quote
I think it would be worth doing as much as you can whilst they are in this state. I would use an ultra-sonic cleaner if you can get hold of one - but you would probably have to separate them and do one at a time.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
A100man
PostPosted: 12:27 - 27 Feb 2015    Post subject: Reply with quote
I wouldn't bother breaking the rack unless you have known issues with air leaks on throttle shafts or fuel leaks on the joining tubes - else you will be into new seals on these parts.
Carb cleaber and air should be sufficient in the most part.
What was the symptom that prompted the strip down ?
mudcow007
PostPosted: 13:54 - 27 Feb 2015    Post subject: Reply with quote
basically it was running like a bag of spanners:
miss firing
sooted plugs
rough idling etc...
so, seeing as its a new year an all that jazz, thought i would treat it to a tear down.
ive already found (an replaced) a cracked inlet.
Carbs look a bit grubby, an ive found some stuff covered in green varnish looking stuff, but the jets look clear - to my untrained eye
will spray cleaner over stuff an see how it goes.
im hoping everything back to factory spec an it should be all rock n roll
A100man
PostPosted: 21:19 - 27 Feb 2015    Post subject: Reply with quote
miss firing
sooted plugs
rough idling etc...
Good luck - choke circuirs can get over looked so don't forget those- keep us posted on how it works out ? BTW are valve clearances in spec ?
mudcow007
PostPosted: 21:35 - 27 Feb 2015    Post subject: Reply with quote
plungers cleaned, valves checked about 300 miles ago - so should be good
Does it matter which way the float valve goes on the float?
PostPosted: 21:53 - 27 Feb 2015    Post subject: Reply with quote
Nope, so long as the float measures 17mm from the sealing face of the float bowl to the top of the float with the carb held at 45 degrees so the spring-loaded needle isn't compressed.
temeluchus
PostPosted: 02:50 - 28 Feb 2015    Post subject: Reply with quote
Pay particular attention to the air jets in the mouth of the carbs and that the chokes move freely. The choke actually causes the slides to lift slightly, look in the top of the carb bodies for the opening.
Check the float needles to see if they are fucked.
Probably worth getting carb kits whilst you have it apart, particularly if you rely on the thing.
mudcow007
PostPosted: 20:16 - 02 Mar 2015    Post subject: Reply with quote
right, carbs rebuilt.
float heights were all over the place, so sorted them (with help from G's guide)
now, the pilot screw needs to be 1 7/8 turns...how the funk do you do 7/8s of a turn?
am i being a potato?
orac
PostPosted: 20:22 - 02 Mar 2015    Post subject: Reply with quote
use your imagination and divide the circle into 8, and then count it round. it maybe helpful to use a small dab of tipex on both the head of the screw and adjoining face so that you know where you started.
PostPosted: 20:47 - 02 Mar 2015    Post subject: Reply with quote
Compass points:
Mark65
PostPosted: 09:27 - 03 Mar 2015    Post subject: Reply with quote
7/8 ths would be nearly 1 full turn I believe, so it would really be nearly 2 full turns.
mudcow007
PostPosted: 20:00 - 03 Mar 2015    Post subject: Reply with quote
well...it didn't fire after refitting the carbs
couple of coughs then the battery started to croak.
pulled the plugs out an they were wet.
dried em off, an tried checking the spark.
No.1 was good
No.2 was sparking from the bottom of the electrode Shocked - im guessing this isnt good.
oh an the sparks i was getting wernt exactly bright blue...
not good me thinks
Ariel Badger
PostPosted: 20:21 - 03 Mar 2015    Post subject: Reply with quote
Fully charge your battery.
Deathoctimus
PostPosted: 20:24 - 03 Mar 2015    Post subject: Reply with quote
your coils mite be duff also, if you have a multimeter check the resistance.
oh and the spark leads etc etc.
my gsx carbs are not to far off the same my factory setting for the air screw is 2 3/4 turns.
Shaun
Current Rides Fireblade 900 RRN / DL1000 past: ZX9R B1 / GSX 600F K3 / YBR125
mudcow007
PostPosted: 21:11 - 03 Mar 2015    Post subject: Reply with quote
funny you should mention the battery.....
how long should it last at cranking the engine?
as couple of minutes of trying an it was dying (slowing), the battery lives on a optimate charger an has done since I bought it last year
will check resistance in coils tomorrow (coils were new (chinky) last year)
fed up Sad
Ariel Badger
PostPosted: 21:15 - 03 Mar 2015    Post subject: Reply with quote
Longer than a couple of mins, can you hook it up to a car battery? Chinky coils are cheap for a reason IMHO.
mudcow007
PostPosted: 09:18 - 04 Mar 2015    Post subject: Reply with quote
my car is a ball ache to get to with the bike, an reluctant to take its battery off.
may sound stupid this but...i have access to UPS/ Alarm batteries which are 12v, could i try one of them?
Deathoctimus
PostPosted: 18:04 - 04 Mar 2015    Post subject: Reply with quote
at a complete guess id say won't it depend on the current? But I guess a fuse would blow if it was to much.
Shaun
Ariel Badger
PostPosted: 18:33 - 04 Mar 2015    Post subject: Reply with quote
They will not have the power to crank the motor, voltage yes, amperage no.
Robby
Dirty Old Man
PostPosted: 19:51 - 04 Mar 2015    Post subject: Reply with quote
If the battery is a traditional (transparent casing) type, I would check the fluid levels. If it's a sealed one, I would hazard a guess that it was cheap and it shit.
mudcow007
PostPosted: 20:32 - 04 Mar 2015    Post subject: Reply with quote
it lives!!!
had it on charge (like normal) again last night, removed the alarm took about 30 seconds of turning over a few backfires...
then it started Smile
just had a few goes in the street an all seems well
Mr. Green
alarm causing a drain on the battery...maybe?
cheers for the help though
A100man
PostPosted: 22:30 - 04 Mar 2015    Post subject: Reply with quote
Good news !
Regards checking teh spark -with these two plug coils both plugs on a given coil pair have to be in the circuit to get a decent spark
mudcow007
PostPosted: 20:26 - 05 Mar 2015    Post subject: Reply with quote
bad news.....
just went out on it, about 2 1/2 miles to garage for fuel (on choke @ 3k revs)
as i leave garage i turn choke off an it cuts out.
stick choke on full it starts but idling at 4k - so lower the choke until about 3k
as im riding towards home it starts to feel like its miss fire again, kinda like a stutter
Sad
reckon its just cold?
A100man
PostPosted: 22:13 - 05 Mar 2015    Post subject: Reply with quote
Earlier on you mentioned that one of the inlets was cracked but replaced - sure all the others are really ok ?
The last post was made 10 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 128.32 Kb
