| mudcow007 |
 mudcow007 World Chat Champion
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 10:58 - 27 Feb 2015 Post subject: |
I think it would be worth doing as much as you can whilst they are in this state. I would use an ultra-sonic cleaner if you can get hold of one - but you would probably have to separate them and do one at a time. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| A100man |
 A100man World Chat Champion
| mudcow007 |
| A100man |
 Posted: 21:19 - 27 Feb 2015 Post subject: |
| mudcow007 wrote: | basically it was running like a bag of spanners:
miss firing
sooted plugs
rough idling etc...
so, seeing as its a new year an all that jazz, thought i would treat it to a tear down.
ive already found (an replaced) a cracked inlet.
Carbs look a bit grubby, an ive found some stuff covered in green varnish looking stuff, but the jets look clear - to my untrained eye
will spray cleaner over stuff an see how it goes.
im hoping everything back to factory spec an it should be all rock n roll |
Good luck - choke circuirs can get over looked so don't forget those- keep us posted on how it works out ? BTW are valve clearances in spec ? ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
| mudcow007 |
| Pete. |
 Pete. Super Spammer
 Posted: 21:53 - 27 Feb 2015 Post subject: |
Nope, so long as the float measures 17mm from the sealing face of the float bowl to the top of the float with the carb held at 45 degrees so the spring-loaded needle isn't compressed. ____________________ a.k.a 'Geri'
| temeluchus |
| mudcow007 |
| orac |
 orac World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 20:47 - 02 Mar 2015 Post subject: |
Compass points: ____________________ a.k.a 'Geri'
| Mark65 |
 Mark65 World Chat Champion
| mudcow007 |
 Posted: 20:00 - 03 Mar 2015 Post subject: |
well...it didn't fire after refitting the carbs
couple of coughs then the battery started to croak.
pulled the plugs out an they were wet.
dried em off, an tried checking the spark.
No.1 was good
No.2 was sparking from the bottom of the electrode - im guessing this isnt good.
oh an the sparks i was getting wernt exactly bright blue...
not good me thinks |
| Ariel Badger |
 Ariel Badger Super Spammer
| Deathoctimus |
 Deathoctimus Nova Slayer
| mudcow007 |
 Posted: 21:11 - 03 Mar 2015 Post subject: |
funny you should mention the battery.....
how long should it last at cranking the engine?
as couple of minutes of trying an it was dying (slowing), the battery lives on a optimate charger an has done since I bought it last year
will check resistance in coils tomorrow (coils were new (chinky) last year)
fed up  |
| Ariel Badger |
| mudcow007 |
| Deathoctimus |
| Ariel Badger |
| Robby |
 Robby Dirty Old Man
| mudcow007 |
 Posted: 20:32 - 04 Mar 2015 Post subject: |
it lives!!!
had it on charge (like normal) again last night, removed the alarm took about 30 seconds of turning over a few backfires...
then it started
just had a few goes in the street an all seems well
alarm causing a drain on the battery...maybe?
cheers for the help though |
| A100man |
| mudcow007 |
 Posted: 20:26 - 05 Mar 2015 Post subject: |
bad news.....
just went out on it, about 2 1/2 miles to garage for fuel (on choke @ 3k revs)
as i leave garage i turn choke off an it cuts out.
stick choke on full it starts but idling at 4k - so lower the choke until about 3k
as im riding towards home it starts to feel like its miss fire again, kinda like a stutter
reckon its just cold? |
| A100man |
The last post was made 10 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
